Question about Acer Aspire One A150-1006 Notebook
My cat laid on my keyboard and now my mouse pad is not responding I've tried holding the Fn, Ctrl, Shift, key with every other key with no luck. I've turned it off and restarted
The function-f7 button toggles the mousepad on & off. maybe your furry pal hit the function & the f7 button & turned it off?
Posted on Oct 24, 2009
  • 439 Answers
What you should do is one of two things. Look around the pad, some computers have a button that turns on and off the mouse pad. If there is no button, you need to connect a USB mouse and go into control panel, then the mouse folder and make sure the pad is on. This will fix your problem.
Posted on Sep 30, 2009
  • 25 Answers
Try unplugging all the chords and then back in. Maybe the chord input got knocked loose?
How to activate/deactivate the alternate keys(blue font) on keyboard
Ctrl + fn + right shift key twice
So hold ctrl + fn + right shift key then release the right shift key but keep holding the ctrl + fn keys down then push the right shift key again and that should deactivate it
Dec 30, 2013 | Computers & Internet
My mouse pad doesent work
Locate the function key on your keyboard (F1 through F12) that has an icon of a touchpad. This is often a rectangle with two smaller rectangles below it, representing the touchpad and its two buttons.
Press and hold the "Fn" key, usually found in the lower left area of your keyboard.
Press the touchpad function key and then release both keys.
If this does not enable your touchpad, try holding the "Fn" key down and pressing the touchpad function key twice in a row.
Shortcut Key Method
Press the Windows icon key on your keyboard and hold it down until the Start menu pops up. If your keyboard doesn't have a Windows icon, press "Ctrl-Esc" at the same time.
Use your arrow keys to locate the Control Panel and press "Enter."
Navigate to "Mouse" with your arrow keys and press "Enter" to open the mouse control dialog box. Then, press "Alt-F" together to access the tabs at the top of this box.
Navigate using the arrow keys to "Device Settings" or "Touchpad" or the similar option on your system and press "Enter."
Press the "Tab" key until the "Enable" option or a check box next to it highlights and then press "Enter." Press "Tab" again until you are highlighting "OK," and press "Enter."
Your touchpad will be re-enabled.
hope this helps
Nov 28, 2012 | Acer Aspire 7741Z-5731
I want to know how to use the function button
The function button, or FN button, is used just like the shift key or ctrl key. Hold the FN button down and press the key with the pre programmed function you desire to use. For instance, on an HP 1245 the function or short cut key to put the computer in sleep mode is FN+F5. The Keys with functions have that feature indicated by a symbol for the function in a squared circle. Most of these are your F keys at the very top row of the keyboard. Some are on the number pad keys.
Oct 27, 2011 | IBM ThinkPad R31 2656 Notebook
My mouse is not working on my laptop, it wont move
Hello debbiestar34,
Typically on a laptop computer there is an extra set of keys called the function keys. You will notice these keys are identified (usually) by a different colour of text on the keys of your keyboard.
You can probably find a key labeled "Fn" or "Function" in the bottom left of your keyboard, between the "Ctrl" and "Alt" buttons. Once you've found that key, look at your other keys and you should see one that somewhat resembles the touchpad on your computer or a simple rectangle with a mouse cursor inside it.
If you've found both of those keys, start by pressing and holding the "Fn" key, then press the one for your touchpad then release both keys. That should work.
May 25, 2011 | Dell Latitude D410 Notebook
I have an Acer Aspire 5517. Just the other day, my touchpad and keyboard stopped working. What do I do?
1 . Look for Fn function key - Most laptops have this special key Fn that is next to the Ctrl key on the keyboard. It should have a blue or green color, easy to find.
2 . Look for F1 to F12 functions keys, they are on the top row of the keypad. Look for one has an icon that looks like the touch pad, which is to control the touch pad of your laptop. It maybe F8 or F9 depends on each make of your laptop. These function keys also control the brightness, sound, wireless etc.
3 . Now hold down the Fn key and the F10 key to enable the touch pad, in this example, the Toshiba laptops. You press them again to disable it
4 . If none of the above works, plug in an USB mouse, then check into the Control Panel -> touch pad or mouse configurations. Also, check Device Manager if the touch pad driver is installed and working properly.
Thanks.Have a great day.
Oct 17, 2010 | Acer NSK8458AN Keyboard
I cant use my mouse pad anymore...what keys did my cat presswhen she walked on it...so i can unlock the mouse pad again
Try pressing the Fn button (between Ctrl & Alt) and while holding it down press F9 to toggle the mouse off /on. Hope it helps.
Oct 11, 2010 | Toshiba Satellite A105 Notebook
HP G60-235DX keyboard not working at all
Try to press Fn + Num Lock or Fn + Scrl lock to check if they keyboard will respond. If it doesnt. try to turn off the computer, remove the cables and battery, press/hold the power button for 8 secs. Reinsert cables and battery then turn on the pc. Press again Fn + Num Lock or Fn + Scrl lock. If the keyboard still did not respond, go to the device manager . Click Start > right click My Computer > Properties > Hardware > Device Manager . Then click the (+) on Keyboards, right click the device and uninstall it. Then, go back to the device manager and right click Keyboard then click Scan for hardware changes. Then press FN + Num Lock or Fn + Scrl lock. If symptom persists, call HP to replace your keyboard.
Aug 22, 2010 | HP G60-235DX Notebook
How to turn off blue keys for an Compaq mini cq10??
if you are refering to the blue letters or alphabets which are present on the keyboard. HP designs keyboard with a billingual layout in some Notebook models.
The HP "Blue" keys are indeed the "French" input keys or other language keys.
How to use the Blue Symbols or keys on a HP Notebook:
We can activate them by pressing Ctrl+fn+right Shift.To deactivate, press Ctrl+fn+right Shift twice, i.e. Ctrl+fn+right Shift then let go off Shift while still holding Ctrl and fn, then press Shift again.
When you press Ctrl+Fn+Right Shift it will switch to the the billigual layout. That means the blue characters become prioritie.
For example, if you are in the billingual layout, when you press shift+6 you will get a '?' but not the '^' sign.
Mar 19, 2010 | HP Pavilion dv2000t 14.1" Notebook Laptop...
My toshiba laptop cursor doesnot move when i touch the tray pad
Hi!
I had the same problem after my fat cat sat on my keyboard. This is how I fixed it. At the top of the keyboard there is a F9 key. If you look closely at this key, it also has two pictures of the mouse pad. This key is a toggle that turns the mouse pad on and off. Down near the lower left corner of the keyboard is a key marked FN. Hold down the FN key and press the F9 key. That will turn the mouse pad back on.
BTDT, HTH
Jun 13, 2009 | Acer Aspire 5610-4648 Notebook
Alternate keys on HP Keyboard
Activate:
Deactivate:
so hold ctrl + fn + right shift key then release the right shift key but keep holding the ctrl + fn keys down then push the right shift key again and that should deactivate it
Jun 09, 2008 | Intel Dot Station (INTC300AIO) PC Desktop
Acer Aspire One A150-1006 Notebook Logo
298 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
