Question about Bosch Tools & Hardware - Others
After replacing the brushes in my old Rockwell belt sander there is excessive arcing between the brushes and the oommutator and the unit doesn't come up to full speed.
  • 5,603 Answers
Did you dress the brushes to the contour of the commutator?
You wrap the commutator with fine sandpaper and rotate under the brushes till the curve conforms.
If this does not reduce the arcing, then you may have an armature with a bad winding.
Posted on Sep 30, 2009
Testimonial: "Sounds logical. I'll try it."
I would like a pdf copy of the manual for a Rockwell 361 belt sander?
this covers the 361
some one loaded the instuction booklet side ways
page 6 is the belt fitting
14 pages
http://www.manualguru.com/rockwell-sonicrafter/361c/users-manual/page-4
Apr 29, 2016 | Tools & Hardware - Others
How to replace the sanding belt
Google the model number and "manual".
Mar 24, 2014 | Rockwell RK7866 Belt Disc Sander
Electric sparkle
Sparking on the armature when running is normal in electrical tools. It should be small sparks with little intensity. If they are heavy arcs and the case gets hot then there is a problem with brushes, armature shorting or field winding shorting out or excessive dust and dirt on the armature.
Apr 10, 2013 | Tools & Hardware - Others
How to clean a clogged belt sander
I assume you mean you want to clean the belt itself? You can use a rubber stick made for this. It looks and smells like a giant pencil eraser, about 1 inch square and about 10 inches long. However, if the belt is clogged with melted paint, that won't do much - but a stiff wire brush works OK. If the wire brush doesn't work, get a new belt. You can avoid the melted paint buildup (or at least reduce it) if you keep the sander moving rapidly over the surface, and use a good quality scraper to remove as much paint as possible before sanding.
Sep 19, 2012 | Makita 9404 4'' x 24'' Belt Sander
Ihave replaced the brushes on my 9404 belt sander and it is running as if it still needs the brushes changing. Any ideaS?
If there is excess sparking from the brushes then the armature is shorted. Also a bad field can make a tool run slow.
Aug 07, 2012 | Makita 9404 4'' x 24'' Belt Sander
Rockwell 361 belt sander wont run i have power to switch switch good bad brushes?
Brushes wear out often. Unscrew the brush caps and see if they are worn really low or if the springs are broken. If there is any burning on them, then replace them. Also those brushes sometimes stick in the brush holders because of the amount of dust. When you remove the brush caps, blow out all the dust you can.
The wires that go to the brush holders have springs that wrap around the inside of the brush holder (see picture). Check and see if those springs are broken or if those wires are not connected. Sometimes the fields go out in those but it's not too common. Almost never is it the armature (unless a bearing causes it but that's a mechanical failure, not an electrical issue).
Apr 13, 2012 | Tools & Hardware - Others
The belt on the sander doesn't turn. The sander has power when plugged in and the motor runs when you press the button. But the Belt and track don't turn.
Likely the gear belt that drives the drive rollaer has failed. Either it is totally gone or the teeth in a spot have been destroyed and the motor is just spinning the sprocket in the belt. The belt is about 1/2 inch wide and is covered by a belt guard.
Jun 13, 2010 | Makita 3 x 24" Belt Sander
Porter cable sander lost power.
Similar problem with my 7500 2x18" belt sander. Replaced the brushes today (didn;t look bad{ had sander 3 months to sand pistol grips. Sparks were flying from motor so replaced the brushes. Skil runs very slugis like its booging down, I think the only other possible solution is new bearings for me and perhaps you..
Apr 08, 2010 | Porter Cable 505 Factory Reconditioned...
Brushes on my sander are wearing out within 10mins
the armature could be the problem, when you replace them do you notice a lot of arcing around the commutator, it might be bad or just need to have the surface cleaned. let me know.
Jan 22, 2010 | Makita 9404 4'' x 24'' Belt Sander
Tools & Hardware - Others Logo
290 people viewed this question
Top Bosch Tools & Hardware - Others Experts
Jim Parker
Jim Parker
Awesome12
Are you a Bosch Tool and Hardware - Other Expert? Answer questions, earn points and help others
