Question about Price Pfister Bedford 4 inch Centerset Faucet with 50/50 Pop-up Drain
I have a Bedfrod CF motorhome with a holden blue 202 engine retrofitted with an aftermarket temp gauge which only has the temp displayed but no blue green and red zone for overheating. How hot is overheating?
  • 3,051 Answers
Hello there:
overheating is normally in the range after 190-200 if you have a 180 degree thermostat it shouold lift at 180 and the engine temp will go down if not the thermostat should be replaced also if you get a handheld thermometer gun you can monitor the engine temperature this way too
but if i were you i would get the right temperature guage and install it.you should be able to get this from any motorhome dealership or parts center ok?
best regards michael
Posted on Sep 30, 2009
Radiator sensor holden vectra
For temp. gauge check the theremostat housing near the top hose enters the engine.
May 28, 2014 | Air Intake Hose Holden Vectra 2 Gts Hump...
Red 6 holden motor
you could if both engines have the same rear main seal, there was rope and neopreen rear main seals in blue motors
also would need to use same bearings as whats in the blue motor
marking on main bearings on the back eg STD, 010, 020
thats so you know what new main bearings you should then get & use, as well as the 2 thrust bearing peices
you should then check all clearance specs as you assemble crank into block with plasi gauge and your feeler gauges or the thrust bearings
Jan 26, 2014 | Holden Cars & Trucks
Coolant boiling after short drives but not showing any change on temp gauge or using any water
you could have a faulty temp gauge(air in the system) was my problem let it cooldown all the way....open radiator cap turn your heater on so water circulates all around the engine add coolant if needed it helps to gun the engine a little watch for flow of coolant then cap it.a closed thermosthat would also cause you car to overheat.
Mar 22, 2013 | 1998 Holden VT Commodore
Temp gage on 94 bounder motorhome does not work
cant tell where sensor is, but when you find it if you connect the sender unit wire to ground the gauge should read hot with ignition turned on (with engine not running) this will tell you sender unit is at fault not gauge
May 31, 2012 | Chevrolet 3500 Cars & Trucks
Coolant Boiling over but engine temp. is fine??
The engine thermostat may be sticking closed. However the temp gauge itself or temp sending unit or wiring is defective, start with the sending unit as it is cheapest part to replace and follow the wiring into the harness and the harness itself up to the firewall. If the gas gauge is reading accurately, the dash regulator should be okay.
It is possible the electric fan thermostatic switch may not be operational, or relay intermittent/defective, or even the retrofit wiring may be questionable. You would need to run it so it fully warms up and thermostat opens.
If it was a retrofit to a "Sable" 70 Amp cooling fan, is your alternator up to the challenge?
The way to simply check for a head gasket issue is with engine cold, if you remove the cap where you fill directly into the cooling system of the engine, not the reservoir, start the engine. If you get a geyser out of the opening, you blew a head gasket or cracked a head. If you let it warm up a little bit, but not to the point where the thermostat opens, it will reveal if there is head gasket issue to be looked into. Doing this allows for the parts to begin to expand and a sealed spot cold might leak at 110 degrees F. You might also see a white cloud behind the car.
Dec 20, 2011 | 2000 Lincoln LS
1984 FIERO 4 CYL STICK. had a aftermarket elec temp gauge mounted on console, replaced with a mech temp gauge. after replacing temp gauge is when the fuel gauge messed up. now when you turn on the key or...
I assume you replaced the temperature sending unit when you installed the aftermarket gauge? You need to put the proper sending unit back in for the OEM gauge to work.
You can find a sending unit here (and a gauge if needed):
http://www.fierostore.com/
Hope this helps
Nov 06, 2010 | 1984 Pontiac Fiero
TEMP PROBLEM
If you folow the top radiator hose toward the engine, that will lead you to the thermostat and you should find the temp sensor close by.
Nov 24, 2009 | Cars & Trucks
Oil temp gauge goes low middle high
probably clogged ports... there is a tsb that says not to use any aftermarket oil filters on the 5.4l engine... peices of the gasket on aftermarket filters break away and clog passages in the engine. always use motorcraft filters for that engine...
Jun 24, 2009 | 2004 Ford F150
Torque wrench settings
please understand there are a lot of items on a car that require torque settings every thing from the lug nuts to every engine bolt, and transbolt. please be more specific
Jul 03, 2008 | 1999 Ford Taurus
Price Pfister Bedford 4 inch Centerset Faucet with 50/50 Pop-up Drain Logo
98 people viewed this question
Top Price Pfister Plumbing Experts
john h
Mike
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
