Question about Plumbing
Need a wiring diagram for a hdy.dump trailerpump 3 wire
    Problem Solver:
  • 16 Answers
Most of those are simple diagrams that have one ground and two hot wires. One wire will make it go up and the other down by reversing the electric motor. You can usually identify the ground by its color (black). Find you a good 12V source and hook it up to one of the other wires and see which way that the cylinder/bed moves. Hook that wire up accordingly to your switch.
Posted on Oct 12, 2009
Where can I get a wiring diagram for a 1984 L9000 dump truck
Hi Larry:
That's a tall order.
I have a 1980 L8000 and a friend has a 1976 L9000.
We both do most of our own maintenance.
The question that I have for you is, "what problem are you trying to solve?". Maybe we can help.
Cheerfuls.
Gotta keep that old iron running!
Sep 17, 2015 | Cars & Trucks
Spark plug wire to distributor cap diagram 291 mack truck 1961
If you haven't removed the wires yet don't. The best way to replace ignition wires is to remove ONE at a time and replace with a new one before moving on to the next. That way you won't get the firing order mixed up. Hope this helps
Oct 11, 2014 | Cars & Trucks
2002 fxdl no power white wire high beam indicator on dash indicates high beam is on still no power
Well, electricity is electricity and wiring circuits are wiring circuits. I do not have a 2002 fxdl electrical service manual either so cannot help there. On a 2003 the white wire goes from the headlight to four pin connector 38B and from there to four pin main harness connector 38A pin 2 and from there to connector 20A pin 4 and from there to (fxdl only) connector 21A pin 2 to connector 21B pin 2 to high beam indicator light which has BK wire ground going to 21 B pin 6 to 21B pin 6 after which it joins other BK ground wires to speedo and to 20B pin 12 and then to 20A pin 12 to TS/TSM pin 12 (ground)
POWER from ignition switch into lighting 15 amp fuse by connector 38 pin C R/BK and out from fuse by BE to connector 24A pin3 and out connector 24B pin 3 BE into handlebar switch then out from handlebar hi/lo switch into connector 24A pin 4 W and then out from 24B pin 4 W to connector 20A pin 4 W (which joins to speedo connector 20B W and also goes to connector 38A pin 2 W which goes to 38B W pin 2 to the headlight high beam element on the right side pin with the low beam element connection on the left side (on the wiring diagram) (Ground wire is also on the (diagram) right side and goes also to HDI position lamp is on the bike and HDI position light power is from connector 38B pin 1 O/W etc.
Connector 20 is a 12 place Multilock is console gauges connector located under the console on fxdl
Connector 21 is a 10 place Multilock console gauges connector located under the console on fxdl
Connector 24 is a 6 place Deutsch left hand controls and horn connector located on the frame backbone
Connector 38 is a 4 place Multilock headlamp connector located on the frame backbone
Jun 19, 2014 | Harley Davidson Motorcycles
I need a wiring diagram for a 79 ford f700 ,the alternator only has 2 wires going to it and it looks like it needs 3 its a 360 bb auto
no 2 wires is correct i think one big one and one thin one for the light ,other connection could be for a suppressor
Aug 17, 2010 | Ford F Cars & Trucks
I am trying to find the wiring diagram for my 2002 FXD. I am installing a trunk and need to know the light wiring diagram in order to hook up the tail and turn lights on the trunk.
Connector 7 is under the seat. It is the main harness to tail lite connector. The wires from main connector are:
2002 All DOM and INT Including FXDWG
Connector 7 pin 1 goes to tail lite 94 connector pin 2 = BW
pin 2 goes to 94 pin 1 = O/W
pin 3 goes to 94 pin 5 = V
pin 4 goes nowhere = empty
pin 5 goes to 94 pin 6 = BK
pin 6 goes to 94 pin 4 = R/Y
pin 7 goes to 94 pin 3 = BE
pin 8 goes nowhere = empty
Connectors 93, 94, 18, 19 are all in the tail lite assembly.
19 = Rt Turn pin 1 = V/BN pin 2 = BK
18 = Lt Turn pin 1 = V/BN pin 2 = BK
93 = Brake and running lites pin 1 = BE = Dom running pin 2 = O/W = HDI running pin 3 = R/Y = Brake pin 4 = BK = ground
Jul 25, 2010 | Harley Davidson FXD Dyna Super Glide...
1995 Ford F350 5spd. distributor cap wiring diagram/layout!!!
1) #1-4 pass side front to rear #5-8 drivers side front to rear
2) 1-3-7-2-6-5-4-8
3)#1 is usually marked on cap wires go ccw
4) TDC #1 cyl you must remove the shorting plug before timing
it is located by the dist plug or the ignition module small gray plug
Jul 17, 2008 | 1995 Ford F350
Plumbing Logo
352 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
