Question about GE Dishwashers
Food at bottom of GE dishwasher (GHDA485N00CS)
I have a GE dishwasher (GHDA485N00CS) and the cleaning performance is slowly getting worse. There is often food still on the dishes and at the bottom of the tub (around the water intake). I can take the main rotor off, but I can not get the intake grid off to inspect things because of the water tube supplying the upper rotors. Any help would be appreciated.
kachbibi1
  • 979 Answers
SOURCE: Kitchen Aid dishwasher - top shelf not getting dishes clean
Is the top sprayer clean and not clogged so that the water can flow through? The top may not be functioning properly.
Posted on Jan 17, 2009
SOURCE: specks of "sand-like" food on my dishes; water not draining
I bought a replacement filter and that dramatically cut down on the amount of "specs." Now there are only a few in some of the glasses. I also cleaned out the drain underneath the screen, there were peas and corn in there, I just used a shop vac to **** them out. Seems to be much better now, I think a good inside cleaning of the washer will help out too. Hope this helps...
Posted on Mar 21, 2009
MNTECH
  • 1543 Answers
SOURCE: Poor wash performance with GE Profile PDW9280 dishwasher
Check the holes in the spray arms for obstructions.
Posted on Mar 28, 2009
  • 423 Answers
SOURCE: Dishwasher rinsing with dirty water-help
Now is a good time to remove the spray arm and the filter/strainer underneath it. Clean everything you remove in the sink. With a flashlight, inspect everywhere in the sump area and remove debris (watch out for broken glass!) Inspect the impeller, making sure it is not broken and that is spins freely. While you are in there, look carefully at the heating element for damage and breaks.
Reassemble and test. If it continues to leave a film on the dishes (especially visible on the glassware) suspect the heating element (no kidding) If it is not heating during the final rinse and drying cycle, that is your main problem.
If problems continue when the heating element is working, then the wash motor is failing and needs to be replaced.
Good Luck, please post back here with what you find, OK?
Posted on Apr 11, 2009
SOURCE: Hotpoint Aquarius DF61 Dishwasher & Food residue remaining
i have cleaned the filter on my hotpoint aquarius DF61 on cant put it back together.
Posted on Sep 02, 2009
Soap (?) residue on dishes; also not getting them clean--food on
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Jul 26, 2010 | GE Nautilus 24" Built-in Dishwasher
Food is stuck in the bottom wand holes
I personally use a metal croquet hook to pull debris out out of mine
Jul 22, 2010 | GE 24 in. Profile PDW8280JSS Built-in...
When I open the dishwasher, I can see gunk on either side of the door. When the door is shut, these areas are covered up so of course they remain gunky. What is causing this? How do I get rid of it,...
This is semi normal, worse if people insist on putting food laden dishes in the dishwasher....
Think about how food gets off ...... spraying water, and most particulate matter eventually falls to the pump area, but some makes its way to the door seal area.
This is not a fault, just clean it up and you should be good to go.
Doc
Sep 20, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher water draining????
Make sure the odor is coming from the dishwasher.
Pull the bottom basket out and check for food that might be stuck in it. And check for food particles in the bottom of the dishwasher.
Then pour some baking soda into the dish liquid compatment. Run it through a complete cycle. This should deodorize and clean the dishwasher. i hope it helps. Please remember to leave rating.
Jul 19, 2009 | GE 24 in. GLD5860LSS Stainless Still...
TOP RACK WILL NOT GET CLEAN
look in the owners manual on how to clean the food particle grate on the pump.....
Dec 27, 2008 | GE Nautilus 24" Built-in Dishwasher
GE GHDA485N00CS model dishwasher has no power
I have the same problem with my GE dishwasher. The model number is GDS640P-25BA. Any help for this problem !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!.
Nov 02, 2008 | GE Dishwashers
GE dishwasher Quiet Pro 3 middle washing arm
Try unscrewing it from the bottom, remove it and give it a clean. If it is full of food it will not turn.
Check the funnel on top of the basket is free of food too.
Jun 10, 2008 | Dishwashers
No Spray
Wow, you've done a lot of work. I wouldn't break the seal around the bottom. If water gets in the motor then your in big trouble. You can try to clean the spray arms out. I was just in my kitchen trying to get the dishwasher to work with the door open to see the arms spray water, but I couldn't do it. Just a little experiment I wanted to try. I told my wife I was trying to help solve a problem and you can image what happened from there .... Let me see if I can find a manual.
Jul 14, 2007 | KitchenAid 24 in. KUDI02IR Built-in...
Dishwashers Logo
281 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
