I purchased a 32'' Westinghouse LCD HDTV from walmart on 02/16/08. I watched it last night and it was working fine then when I turned it on tonight I get sound but no picture.
WalmartShop all · No-Contract Phones · Unlocked Phones · Prepaid Minutes & Data ..... Seiki 32" Class LCD 720p 60Hz HDTV, LC-32G82 ... 1-20 of 45 total reviews ... for an inexpensive 32" TV for our guest bedroom and came across this one and ... Walmart is sending me a replacement and if it works well, I will update my review.
WalmartSeiki 32" Class LED 720p 60Hz HDTV, (2" ultra-slim) SE321FB .... I bought this as a gift for my girl friends home bar...we were booth very happy with the tv.
? 1:42
https://www.youtube.com/watch?v=OZlNRxBe1fg
Feb 28, 2014 - Uploaded by Kevin Davidson
+Kevin Davidson Uhm how do I manually set my dns settings? ....Can u help me can u go on amazon and type in seiki 32 inch tv if its the same one as yours ... Can you help me purchase SEIKI LED SMART TV and would like to change .... Seiki SE50UY04 50-Inch 4K UHD 120Hz LED HDTV Initial Setup ...
This problems is the board call the T-CON decoder board is the causes and the problems.This board is dying.The T-CON decoder board sit in the middle at the bottom of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoder board for the replacement.
The power supply module may have gone out, need to check and see if you do have 5vdc standby voltage at the power supply module, also check the fuse in the power supply.
Unfortunately, this would be the mainboard that has died. You can purchase a new one online for around $150 or maybe cheaper on E-Bay. Hope this helps.
Try leaving the TV unplugged for 30 minutes so theTV can reset itself.
If that doesn't work, most likely the TV has a power supply board is the problem. Or, it's just a fuse that blown inside the TV.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20. And most cases the new part cost less than $15.
