Question about Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis MAV6451 - The machine buzzed and stopped. Now it wont run. Dont think its the lid switch
  • 34 Answers
Does it fill with water?
Does it not do anything after it fills?
If this is the case than it is most definitely the lid switch.
I recently had the exact same problem. Easy fix if you are handy.
Remove back of control panel to access the mounting screws. this will give you hand access to the lid switch. Try manually activating it after letting it fill. Replace switch or repair if able.
Good luck
Posted on Sep 30, 2009
The cycle stops in the middle of the wash, rinse, etc. You have to push down on the lid to make it run again.....this is a pain resulting in the laundry taking hours to get done and close monitoring.
This is usually caused by a bad lid cam and plunger. The lid cam is located on the back of the lid which pushes the plunger into the lid switch. Replace these parts and your all set.
Mar 01, 2011 | Maytag Atlantis MAV6451 Top Load Washer
Wont start agitating
check the lid safety switch if its bad it wont allow the washer to do anything but fill with water,its located underneath the lid
Nov 25, 2010 | Maytag Atlantis MAV6451 Top Load Washer
Washer not working
you may have broken the lid switch needs to be checked
Apr 22, 2010 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis washer
is the smell rubber or electrical? the pump could be seizing on it and burning the belt. check this out first.
Oct 25, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis 6451 noise when on and agitator doesn't work.
it does sound like a bad motor.
they are rather expensive on that machine,
you would be looking at 300 or so
May 28, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis 7700 - Noisy agitation/wash cycle from motor
Your drive motor may be fine. Check the water pump that is located in the back behind the small metal door on the left bottom corner and see if thats where your noise/water is coming from. These extraction pumps have bearings casing that gets mangled and locked up. Look right above the flywheel that the belt rides on in the W-pump.
May 09, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis washer will not drain and spin unless you lift the lid
The cheaper thing to check first is is your lid bent? The lid switch is in the center of the lid. If it "droops" or has been bent, it shaft on the back of the lid cant hit the switch. Open the lid and apply pressure in the bottom, center of the lid. This usually corrects the problem without replacing the switch.
May 31, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Defective lid switch I think
Sounds like your lid switch is ok .. u need to replace or adjust the plunger for the switch... below is a pic of the plunger.. sometimes u can get a little adjustment on the clip that pushs the plunger thats attached to the lid.. pic below
sounds like this is the part that has wore and shorten some...
also check the lid cam maybe able to wedge something behind to get more length out of the plunger heres a pic
Oct 27, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Washer stopped
Sounds like might be the lid switch... these washers are  well know for lid switch problems,
Sep 21, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis MAV6451 Top Load Washer Logo
201 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
