Question about Canon PIXMA iP1700 InkJet Photo Printer
Its saying paper jam and its no paper in the printer for it to be jam. I check the printer inside and out and its no paper no where in the printer and every time i try to print its says paper jam.
  • 103 Answers
Check front and rear paper sensors. Maybe they damaged. Clean optical sensors.
Posted on Sep 30, 2009
Keeps saying there is a paper jam
Unplug the printer and open all the access panels. Using a small flashlight may help. Carefully check all areas inside the printer for a stray piece of paper logged somewhere inside. You may need a small pair of pliers or tweezers to remove the piece of paper.
When clearing jams ensure you find the entire piece of paper that was jammed in the printer.
When your done, be sure to securely replace all parts removed from the printer and properly close all the access panels.
Jan 01, 2013 | Brother MFC-465CN InkJet Printer
A piece of paper jammed up. I took the paper out but the alarm keeps on saying "Carriage jammed"
Hi there !
Check again your printer and maybe there is still paper jammed inside. Turn off your printer. Open the door cartridge and remove the cartridge. Check for paper jammed. After that return the cartridge and turn on your printer. Sometimes there is paper jammed inside that printer. Just press the power off and turn it on to roll over any paper jammed inside. Turning off on your printer also make your computer refresh the memory of your printer paper jammed.
To make hard reset of your printer. Turn off your printer and remove the power cable to your printer, leave it for five minutes and connect the plug and turn it on again. That will refresh the memory of your printer.
I hope it helps you.
Jan 25, 2011 | HP Officejet 7310 All-In-One Printer
Our printer is not picking up the paper from the tray and is saying it is jammed. There is not jam.
Hi there !
Is your printer had jammed before and it stop printing in the middle of printing? For some reasons, paper can jammed due to printing interruptions, printer turn off, improper loading or feeding of paper, roller feeder had problem and others.
If jams before and paper have let inside the printer, please do the following first:
1. Check th paper tray, see inside if the paper is jammed inside that compartment. If there is paper jammed, remove, turn off your printer and turn on. This will solve your problem.
2. If not, open the printer cartridge door, remove the toner cartridge and look for paper jammed inside. If these is paper inside, remove it, turn off the printer and turn it on.
3. If you cannot see the paper jammed inside, the paper maybe inside the heating area. To remove paper, just turn off your printer and turn it on to roll over the paper jammed inside of it.
4. If the printer is blinking and saying there is paper jammed. You have to check the cartridge toner by opening the cartridge door, remove the cartridge and return it back but be sure it is well firmly fitted.
If following the 4 diagnostic procedure and you cannot locate the jammed paper, the problem lies on the toner cartridge itself. When toner cartridge is not rolling over, it will stop feeding the paper and it will cause printer to jammed.
To diagnose the problem, put old printer cartridge and if no toner power, just shake it well and I am sure there is still small amount of powder inside it and if it prints, the toner cartridge you purchase is defective. Reason, factory defect or improper refilling and part is not working well.
I hope it is helpful and thank you for using FixYa !
Jan 06, 2011 | HP LaserJet P3005n Printer
Go to print and status say paper jam, checked rollers and inside, but no jam
i lost my cd of Hp Deskjet F380 and i want to install now to my cp, secondly it use to show me red light blinking saying paper jam while there is no paper jam inside the printer for now she is not working
Nov 23, 2009 | HP PSC 1210 All-In-One InkJet Printer
Canon imageclass mf6530 paper jam error wont go away
check where that u removed the paper and see if one of the sensors is stuck or out of place. also look for a piece of paper. you may have to get a flash light to see better
Aug 05, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
Stuck on paper jam
check your printer paper sensor it is inside the printer it might has shifted from the normal position or damaged
May 30, 2009 | HP PhotoSmart P1000 InkJet Printer
Paper jam-2
samsung scx-4521f paperjam2 check inside
Mar 22, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Printer says paper jam but there is none
Look Inside of each cover on the printer & see if there is a small piece of paper inside. Also, check if there is loose dust from the paper built up by the sensor switches. If none of these work, try flipping the sensor switches manually. Sometimes these get stuck in a particular bad paper jam.
Feb 11, 2009 | Canon Pixma MP500 All-In-One InkJet...
Canon MX300 Paper Jam
I have the same problem - every time I turn on my printer now, the alarm signal shows up with "Paper jam" but when I check for jammed paper, there is none. So I think there's something faulty with the printer. Is there any way to reset it? I've looked everywhere but can't find it.
Jan 16, 2009 | Canon MX300 Office All-In-One Printer
Says paper jam, no paper inside
If you are getting a paper jam error, but no paper inside- Check your Pick Up rollers in the paper tray and then check for any stuck flags in the printer.
Sep 20, 2007 | HP Color LaserJet 2600n Printer
Canon PIXMA iP1700 InkJet Photo Printer Logo
719 people viewed this question
old marine
old marine
