Question about Insignia Digital-to-Analog Converter for Analog TVs
Old tv has only one connection . How to connect to new vcr
I have an old TV that has its only signal in via a coaxial cable.
I have a new vcr with audio/video cord.
Is there an adapter? How can I continue to use my old TV.
  • 530 Answers
There are several methods you can use for your hook-up. It really just depends on your existing equipment. Usually the issue is that the TV only has RCA inputs. It would be surprising if your new device did not have both RCA and coaxial cable out connectors. If it does then just use the coaxial connector as this will carry both the audio and video signals.
If this is not the case and your new device has only the RCA type connectors then you will need an RF modulator to connect between the two devices.
You can also use a cable tuner box to connect the two devices as most cable boxes are equipped with a variety of connectors such as coaxial, RCA and S-video.
If you have cable box check the rear connections. If it has multiple connections just use the a/v coming out of the player to the a/v in on the cable box. Then to the TV by the coaxial cable. Accessing the player depends on the cable box. It may require you to switch the source from the remote or it may switch automatically when the player is powered up.
If you have other devices in the system or you have any problems or are just unclear on something please let me know and I'll try and help.
Hope this helps
Posted on Sep 30, 2009
  • 557 Answers
Go to walmart,radio shack, or electronics store. You want to purchace a RF modulator. Not expensive.
I have an older tv with only a coaxial cable connection on the back, no others. I have a Magnavox dvd/vcr combo that does have RCA connections available and also a coaxial cable connection on the back. I...
First make sure you have the cable connected properly.. on the vcr it should be connected to the OUT coaxial connector.
Second.. the VCR usually has a VCR/TV setting..
Most TV's must be set to channel 3 or channel 4 to output the signal from the VCR when getting the signal via Coax.
So..insert a tape...hit play..tune the tv to channel 3 if you are not getting the playback signal..press the VCR/TV button on the vcr or vcr remote.
Repeat this on Channel 4
Check your cable to make sure the connections are tight.
Finally check your television menus for Input settings..make sure it is set to COAX/ANT
Make sure your VCR's output is not on some alternate output like L1 or L2 (line one or line two)
Best of luck!
Apr 22, 2011 | Televison & Video
I am having trouble connecting dvr to dvdvcr to older tv
This can get tricky sometimes. It depends if you're connected the DVR to the tv via RCA cables or coaxial cables. For coaxial, connect from the TV's in to the DVD/VCR combo out. Coaxial from your DVD/VCR in to your DVR out. set your VCR/DVD to channel 3/4 depending on your manufacture as well as your tv. If this doesn't work, usually your tv provider may be able to help you out.
Mar 01, 2011 | Televison & Video
What do i need to buy to get it to work on my new tv
How to Connect Your Old Videogame System rca_cable.jpgIf you've just dug your old videogame system out of the attic, you might not remember exactly how to connect it. They're not quite like modern game systems, and may require something extra to connect it to that brand new TV you have. To the left is the cable you should see attached to your videogame system. It is typically called RCA, and you will have to use some sort of adapter before you connect it to your TV. While it looks like it should fit into one of the composite jacks (and it will actually fit), that will not work because the audio and video signals are being carried in the same cable. In order to use the composite jacks on your TV, you will have to separate the audio and video signals somehow (described below). The following instructions are relevant to most vintage videogame and computer systems that connect to a television. Specifically, the Atari 2600, 5200, and 7800. However, if you have the 4-port (four joystick ports) version of the 5200, you need a special switchbox. Try eBay or Best Electronics (catalog item) for this proprietary switchbox. If you have the 2-port version of the 5200, you can use the methods described below. coax_jack.jpg composite_jack.jpg Coaxial CompositeThe first thing you need to do is figure out what type of connection you're going to make. Look at the back of your TV and compare to the pictures to the left. It's much easier to connect to a coaxial jack, and this is what most people will do. Composite will give you better audio and video quality, but you must perform a hardware modification.
Coaxial
Coaxial (F-type) to Female RCA Adapter
Radio Shack part #278-276
Manual TV/Game Switchbox with Coaxial Output
300 to 75 Ohm Matching Transformer
Coaxial is by far the easiest way to connect your old game system, and the method most people will use. This is the 'cable ready' input that is found on every TV made today (and for some time now). If you don't at least have this connection, you have our sympathy. There are several methods you can use for this connection.
The best way is to get a Coaxial to RCA adapter (left). It is cheaper, smaller, and provides a better signal than the traditional TV/Game switchbox. This is a small plug that will cost you about $3 at Radio Shack. It is called a "Gold-Plated Phono-to-F Adapter" and the Radio Shack part number is 278-276. Just connect it to the RCA cable of the game system, then plug the other end into the coaxial ("cable") jack on the TV. Set the TV to the channel that the game system is set to (usually 2-4), and your're ready.
If you still have an old TV/Game switchbox and you don't want to buy something new, you can use that. You can also purchase these at Radio Shack for about $5, but if you're going to go buy something we recommend the adapter described above. Some TV switchboxes have built-in coaxial output, some do not. If yours does not, you will need to buy a 300 to 75 Ohm matching transformer (again, about $2 at Radio Shack). If you you do have coaxial output on your switchbox, just plug the game system's RCA cable into the switchbox, connect the switchbox to your TV's coaxial ("Cable In") jack, and push the switch to "Game" or "Computer". Note - you cannot use the 'automatic switching' boxes that newer game systems like the NES use - the signal in most old systems is not strong enough to trigger the automatic switching, so be sure you buy a manual switchbox.
Most new TV/Game switchboxes will allow you to connect your Cable TV and Videogame system at the same time, but the picture is often less than ideal. We recomend a coaxial selector - this will allow you to choose between inputs (game, cable, whataver) at the touch of a button. We found this one at Parts Express for about $6.
av_switchbox.jpg AV Switchbox
Composite composite_jack.jpgAny way you slice it, generating composite output takes more work. How much more depends upon exactly what you want to do. To get true composite signals, you will need to be handy with a soldering iron and modify your Atari 2600 internally. If you've never soldered anything before, it might be a little tricky, but it's worth it for the clean signals! You may also notice that modern equipment has left and right audio jacks - this is for stereo sound, but you can't get stereo sound from your 2600 unless you make further hardware modifications. So if you make the mod, you'll just have one audio cable in use. vcr_composite.jpgNow if you don't want to do that, but you're using a monitor or tv without a coaxial input (for example, a Commodore monitor), there are other options. You will still have to convert the signal to coaxial first (see Coaxial section). Then, if you have a VCR handy, you can run the coaxial connection into the VCR, and then use the composite outputs from the VCR. This will not give you the true signal clarity of composite audio/video, but it will allow you make that composite connection. If you don't have an extra VCR for this, you can probably go buy a junker at the local thrift store - the tape mechanism doesn't need to work, just the demodulator. Demodulator's rarely go bad on VCR's, they're usually thrown out because of the tape mechanism. Speaking of demodulators, you can simply use one of these instead of taking up all that space with a VCR. Unfortunately, these are much more expensive ($100+) and you're not likely to find one in a thrift. Unless you're going to make a hardware modication, we really recommend using a straight coaxial connection, because going through a VCR/demodulator defeats the purpose of a composite connection.
Feb 15, 2011 | Atari Video Game Consoles & Games
How to connect a sv5000 on a very old tv?
Does the SV5000 have a coaxial (Channel 3 or 4) output? Connect that output to the antenna input to the old TV. If your TV is so old that it has only a 300 ohm antenna input (2 screws), just use one those old adapters that has 2 scew lugs on one end and a coaxial receptacle on the other, connect a coaxial connector between that and the VCR's coaxial output.
May 13, 2010 | Samsung SV5000W VHS VCR
Dvd without coaxial, old tv without RCA, passthrough VCR died
http://www.ellies.co.za/v2/index.php?id=492
@ tihis link above you can see it. It takes the av SIgnal Your Sound and picture and convert it RF making it possible for your tv to tune it, its just like tunning into a station. I do sell these for R199 South African Rand excluding postage
Thank you for using FIX YA
Jan 04, 2009 | Televison & Video
Connecting VCR to TV
Oh man dont shoot your stuff instead use your remote and go to your menu and select your input. You tv is looking at your coaxial input but you can select which input you want. 1, 2 front back whatever you need. channell 3 or 4 has nothing to do with connecting up your dvd if you connect and choose the front connection in your menu.
Oct 21, 2008 | Televison & Video
Coaxial to component
You may need an extra HD tuner for your TV. The only problem that you may have would be the original signal running through the coaxial cable. If it's just regular TV stations, the tuner should fix the problem.
May 22, 2008 | Sony BRAVIA KDL-52W3000 52 in. LCD...
How to connect my (old) vcr to my sony tv
if you connect via SCART lead, then you will need to select your AV channel or channels on your tv.
If its via arial, you will have to tune your tv to find it.
Mar 04, 2008 | Akai VS-X800EGN VCR
How do we adjust our tv
You didn't mention anything about a cable box, VCR, etc. which might be connected. A snowy pic. means simply, inadequate signal is reaching the tuner, or the TV tuner itself is bad. If the first is so... check your cabling. If you have a VCR or DVD player hooked in between the cable box or outside antenna (whichever is the case), VCR (RF or ant.) out should go to the TV, VCR antenna (RF or ant.) input to the cable box. Also check the cable wire itself. If you look at the end of the cable, you should see a relatively thin center wire. This center conductor is what carries the signal. If it is missing, bent over, or too short to make contact with whatever it is connected to, you will have a very snowy pic. If you have a spare TV, connect it in place of your "new" TV, to narrow down the problem. Lastly, if all is well with hookup, cabling, etc. the TV might have a problem. Sometimes the tuner has a component defect, or the coaxial connector can be broken.
Sep 25, 2007 | Televison & Video
Multiple video inputs
Unfortunately, you cannot use the connectors at the same time. The S-Video connector overrides the standard video connector. This is why they share common audio left/right inputs. If you could use them separately, they would each have their own set of audio inputs. (S-Video does not carry audio signals on the cable.) I'm assuming that you are connecting your Satellite as an input to your VCR, and then your VCR to the TV via a video connection. The VCR passes the satellite signal through unless you are watching a tape, then it overrides the dish signal. You have a few choices here: 1. You can connect the coaxial (RF) output from the VCR to the TV, and watch the satellite and VCR on channel 3 (or 4). You can then connect the DVD via S-Video, and watch it on "video". This is the simplest solution, and provides the best picture quality for the DVD (with this TV), but lower quality for the dish and VCR. 2. You can connect the DVD player via RF (if it supports that), watch the DVD on channel 3, and connect the VCR via video. This will make the DVD picture quality terrible. 3. You can replace the VCR with a combo DVD/VCR unit. You can then connect the S-Video out from the combo unit to the TV. This is a more expensive solution. 4. You can replace the TV with a model that includes more inputs. This is the most expensive solution, but will allow you to watch your DVD over component cables (very high quality) and VCR and dish over S-Video. Ironically, the obvious choice, connecting the DVD as an input to the VCR (as a pass-through) simply WON'T WORK. The signal put out by the DVD player is "copy protected" (using a system called MacroVision) which the VCR will refuse to play, even as a pass-though. Best of luck with this. Given that you are trying to make this all work without replacing equipment, I recommend option #1, until you decide to break down and buy a shiny new HDTV. They are coming down in price every week, but only you can decide when the time is right.
Mar 22, 2007 | Sony KV-32S26 32" TV
Insignia Digital-to-Analog Converter for Analog TVs Logo
63 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
Curt Larson
Level 1 Expert
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
