Question about Kenwood KDC-MP232 CD Player
Power cuts out for approx. 3 seconds when volume is turned up above 20, the must be turned down or will cut out again.
It looks like you have a speaker going bad disconect all four speakers and conect one by one
Posted on Sep 30, 2009
Power button wont turn
Soft reset by removing the battery, wait 20 seconds and reinsert.
If this does not solve the problem...
1. Remove the battery, wait for a few seconds, then reinsert the battery to turn off your Merge.
2. Press and hold the VOLUME DOWN button, and then briefly press the POWER button.
3. Wait for the screen with the three Android images to appear, and then release the VOLUME DOWN button.
4. Press VOLUME DOWN to select FACTORY RESET, and then press the POWER button.
If none of this works, get a new phone, hopefully you have the insurance.
Dec 17, 2013 | HTC Cell Phones
Why wont my asus tablet turn on
Try this: press the power button and the volume UP button at the same time, then release at the same time. The recovery menu should appear when you release the buttons. Sometimes it can be a little finicky. Try to make sure you're pressing the buttons exactly at the same time. I think it can work as well if you press the volume UP button first, and then the power button immediately after, holding both down at the same time, then releasing.
If all else fails, take off the back cover and disconnect the battery from the main board for 20 seconds. Re-connect the battery and try above again.
Post back if succefull or for futher help.
J
Dec 09, 2013 | ASUS Eee Pad Transformer TF101A1 Tablet...
Technics S600 Mk 3 Amplifier suffering cut out afer approx
sounds as if amp is clipping.do you have the gain hi, turn it down.are the amps getting good air.are they drawing alot of power from batt alt...do the big 3.
Sep 04, 2009 | Audio Players & Recorders
PC wont boot up after power cut
probably the power cut shorted one of the components on the computer.
Jan 02, 2009 | HP Compaq ProLiant DL380 G4 Server
Dryer gets hot and turns off timmer still going,wont restart for approx 20 min
there is a thermal switch it cuts out the heater element when its at temp. also so has a thermal switch that cut out the unit if it gets to hot. there will be two thermal switches or a combined one. it will have 2 to 3 wire on it and is directly connected to the the drum. one of these is the problem the thermal switch is working as its cutting out the unit. to stop a fire.
Jun 18, 2017 | Whirlpool GEW9878LW Electric Dryer
Speakers cut off when bass goes up...
sounds like you hava a load problem.if your'e running your woofers at 1ohm,make shure your amp is 1ohm stable.....
Jul 03, 2008 | Car Audio & Video
Amplifier power cutting out
not enough power to amp and or amps location is too hot might want to invest in a couple cooling fans from computer store and attach where needed
an amp should take up to 3/4 load but when not enough air to it to cool it off it will shut down
try this turn gain all the way down and slowly work up too desired amp volume setting
May 07, 2008 | Audio Players & Recorders
High volume cut out
power amplifier circuitry problem,you need a qualified serviceman.
Oct 04, 2006 | Sony STR-DE595 5-Channel Amplifier
Kenwood KDC-MP232 CD Player Logo
74 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
