Question about Cameras
Camera saves pictures with the same name - how do i correct this
    Brigadier General:
  • 11,967 Answers
Use a card reader to download your pictures to a folder you create on your desktop. Then, you will have to manually rename the pictures with the duplicate names.
Posted on Oct 03, 2009
My Scandisk Ultra 2GB shows pictures on laptop, yet not on camera...the pictures are on the card. I did download them on my computer, removed them from the card, zoomed, cropped etc on Windows, then...
It is possible that when you edited the pictures on your computer, that you might have changed the file format when you resaved them.
Check the names of your picture files on the computer and compares the endings (.JPG or .BMP or whatever) between new pictures that come directly from your camera and pictures that you have edited and resaved.
If the formats are different at all, then your camera will probably not be able to read them. Cameras usually save pictures in one specific format and can only read them if they are in exactly that format. A computer on the other hand is much more flexible and can usually read or save pictures in many different formats.
Your computer should give you the option of saving a picture file in a different format if you want. When you edit and save the pictures on your computer next time, use the SAVE AS feature, this should give you the option of changing the name of the file as well as the file extension from a drop down list. Then just try saving the picture files in different formats until you find the one that your camera can read. Or just look in your cameras Owner's Manual and find out exactly what format the pictures need to be in for the camera to recognize and display them from a memory card.
Good luck.
Apr 14, 2011 | SanDisk Ultra II 2GB Secure Digital Memory...
After I put a picture on my computer, how do i save a picture in JPEG
Yur camera would take pics in JPG format; if not, in the PC, open the picture witj some editor program and "save as" name file dor JPG extension.
Hope helps.
Feb 06, 2011 | Fuji FinePix A820 Digital Camera
Save a zoomed in picture
Save the picture to your computer.
Before you "edit" your picture, copy the picture to another folder (name the folder "backup" or something similar). Now you may edit the original picture (not the one in the backup folder).
Use the Picture Motion" software that came with the camera. The software will allow you to "crop" the picture...
Oct 07, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Help
If a file is already saved, a computer will not save it again in the same location. If you want to save the same files at different locations, just start a new folder. I use the download date for a new folder, each time I load from my camera. Check the pictures in question. You'll see that they are the same picture, with the same identifier number, or name.
Sep 01, 2009 | Kodak EASYSHARE M1063 Digital Camera
TRYING TO UPLOAD TO COMP.
In order to transfer photos from your camera to your computer, you need to
1- Install the drivers for your camera. The drivers are located in the CD which came with your camera. If you do not have the CD, go to Kodak web site and download the drivers for your cam
2- Connect your cam to your PC.
3- if the drivers are installed correctely, click start, and then the computer icom. There should be an icon with name name of your cam...., double click that and you probably see one or more folders with your save pictures.
4- Now you can copy or cut and past one or more pictures from your camera to your computer. I hope it helps you.
Good Luck!!!!
Jun 07, 2009 | JVC GR-D290 Mini DV Digital Camcorder
SD card and camera
Hi nomi_101,
The option that you're lookig for is usually found in the camera's menu. As I remember for Samsung digital camera this option is under "Setup Menu 4" and under that there is the option for "Copy to Card" just highlight that option in your camera select it and select "Yes".
Basically, ALL images, and movie clips and voice recording files (if any) saved in the internal memory are copied to the SD memory card after the "Processing!" message is displayed. Note that when you move images that are stored in the internal memory to the memory card, the next number of file names will created in the card to avoid duplication of the file name. So it won't copy over any picture with the same name/number in your memory card.
Try this out first. Otherwise if you don't see this option I think it's best to check your camera's user manual for the correct procedure, since most camera's have different menu layout and option names. If you don't have the manual you can donwload a copy at http://www.samsungcamera.com/customer/download/cus_down_main.asp just pick the correct camera manual.
Hope this helps!
Peace! :)
Oct 22, 2008 | Samsung Digimax S500 Digital Camera
How do I load pictures from my computer to the memory card in my camera?
You have to first download the images to your computer and Save them in a folder. Then connect the USB cable from the digital photo frame to the computer and transfer the photos you want onto the frame. Some time you have to change the photos name to alphabetic order so you photoframe will display the pictures in the correct order.
Feb 20, 2008 | HP Photosmart 635 Digital Camera
Cannot access pics
Once you took pictures without a memory card, all pictures taken will automatically be saved on the INTERNAL MEMORY of the camera.
When taking pictures with a memory card, all pictures are just saved on the memory card itself.
If you are seeing 100-757 on the LCD screen. It means that there are already 757 pictures taken from the first time you've used the camera.
It is possible that some of the pictures are in the internal memory and some are in the memory card.
STEPS to DOUBLE CHECK:
1) Remove memory card out of the camera
- Turn on camera
- View pictures on the internal memory
by just pressing on the PLAY mode button
(lowest of the 3 little buttons)
- Pictures seen are just the ones saved on the internal memory
2) Return memory card back in the camera
- Turn on camera
by just pressing on the PLAY mode button (
- Pictures seen are just the ones saved on the memory card itself
*** If you want to transfer pictures on the internal memory of the camera to your MEMORY CARD, you just have to follow the steps below:
- Make sure there is a memory card inside the camera
- Turn on camera
- Press on PLAY mode button to view pictures
- Press MENU/OK button
- Keep scrolling to the right until you see COPY TO CARD
- Select YES using the arrow keys
- Press MENU/OK to confirm
* When you've done these steps, all pictures from the INTERNAL MEMORY of the camera will be copied to your MEMORY CARD but it depends on the space left on your memory card
** If still, you could not view the pictures, it's possible that the pictures are really gone when you have transferred the previous pictures to your computer.
** Once you have transferred pictures to your PC, and you have deleted those on your camera, the FILE NAME of the pictures will not start from 100-001 again unless you have reset the file name on the settings of your camera.
In example, i already have 256 pictures on my camera so the filename reads 100-256 for the last picture taken. And then i decided to transfer those 256 pictures to my PC and i deleted those immediately after being transferred. So, as i took another picture, FILENAME will start with 100-257 if i have not reset
the FILE NAME settings to 100-001.
Hope i've helped you enough.
Jan 02, 2008 | Samsung Digimax S630 Digital Camera
"The device is not ready"
This error message means that the preferences in EasyShare software are set to save pictures to the CD-ROM drive or some drive other than your hard drive. To correct this, follow these steps: Start EasyShare software. Select Tools > Preferences. Select the Transfer tab. Below "Select the location on your hard disk where you want to copy transferred pictures," select Browse. Browse to the desired location on the hard drive where you want to transfer your pictures. The default location is: For Windows 98/Me Operating Systems: c:/My Documents/My Pictures/Kodak Pictures For Windows 2000/XP Operating Systems: c:/Documents and Settings/user name/My Documents/My Pictures/Kodak Pictures Select OK to return to Preferences, then click Apply and OK to save and close the Preferences. Reconnect the camera, and transfer the pictures.
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
Transferring pictures from my Kodak EasyShare digital camera to my computer
Aug 29, 2005 | Kodak EasyShare One Digital Camera
Cameras Logo
19 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
