Question about Kenmore Washing Machines
How do i expose the inner tub and moving parts to check the source of a loud noise on spin cycle
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Is this a top loader or front loader?
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
See the following for removing the cabinet.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
The loud noise could be the Motor Coupler between the motor and gearcase or the agitate gear in the transmission / gearcase.
If your washer is the basic Whirlpool / Kenmore top load direct drive, see the following for the operation and maintenance of the washer.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Posted on Oct 01, 2009
Kenmore HE Washer 100-21302010 makes loud, grinding noises, especially during spin cycle
First of all, the model is 110.21302010. The splined clutch called a splutch is slipping. Replace W10315818 cam, and W10006355 actuator. This is a very common problem with transmission-less top load washers. Tip the machine on its front to expose the under side which contains the motor, pulley, and red actuator motor. To get the splutch off from underneath you must remove the agitator disc when it is upright, and the inner tub. This will expose the inner tub bearing/seal, which also could be worn. Look at searspartsdirect.com to get an exploded view for more clarity.
Sep 11, 2014 | Washing Machines
Maytag Top Load Washer MVWB850YW making loud noise in spin cycle.
If it's a roaring noise, the tub bearing is probably wearing out. Spin the tub a little with your hand, if you hear a little of the roar, that's it.
Nov 26, 2013 | Maytag Bravos Series MVWB850YW 28"...
When it goes into the spin cycle it makes a loud knocking noise like a gear or belt is bad. what can i do, it is only 1 1/2 years old.
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle.If the bearing is getting out of its way then its faulty weak motor causing this.Check out both the bearing and the motor. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 30, 2010 | Washing Machines
Maytag Neptuen Washer makes loud noise when spinning. Sounds like an airplane taking off.
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle.Get the spin bearing and motor checked.Replace the faulty. You can get required parts from www.repairclinic.com
Aug 30, 2010 | Maytag Neptune Washer
Washer making loud noise and wont spin
Check and see if the inner drum is loose and floppy.if it is, it's likely the bearings have collapsed, and require replacement...If the drum feels stiff and tight, it could be that something is jammed between the inner and outer drums. Both situations could be costly...Get quotes....Good luck...Nomess
May 22, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool cabrio loud noise during spin cycle
The inner bearing will be faulty kindly replace the inner bearings as well as water seal before that kindly check whether the drum is freely moving with out any shaking If you find any shaking means you are suppose to change the drum only
May 15, 2010 | Washing Machines
Fridgidaire Washer has a loud knocking noise during spin cycle.
You need to replace your washer, the Inner tub Spider broke.. I repaired mine, With me doing the labour, $285 just for the part alone. plus about 3 to 4 hours labour.
Mar 14, 2009 | Frigidaire FWTBB30DS Front Load Washer
Frigidaire front load washer model GLTF1670ASO
Check the shocks on the bottom of the drum. I had the same problem and had to replace the shocks because they were broken in half.
Mar 02, 2008 | Frigidaire GLTF1670A Front Load Washer
Whirlpool top load washer
Check to be sure inner tub is not spinning freely on spin tube. It can be noisy when this happens. When it's spinning and stops it may continue spinning for a bit when this happens. You usually need to replace spin tube, because the tabs that key into drive block for inner tub break off. Also replace drive block.
Nov 08, 2007 | Washing Machines
Washing Machines Logo
62 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
