Question about MPC Computers ClientPro 545 S (9043751) PC Desktop
I have a MPC clientpro 385...I went to restart the system and it did not pwer back up. The power button is flashing green every 2 seconds or so...pressing the power button does nothing...I unplugged the power cord and waited a minute or so and when plugged back in the power light started flashing the same way again...any ideas whats wrong??
  • surveyor3790 Sep 30, 2009
    Thanks for your help I tried unplugging everything and still had blinking light no power-up..ordered a replacement power supply...I was able to get my data off hard drive using an external reader...hopefully it is indeed the power supply...I'll find out in a couple days...
    Thanks
Best of luck!
Thanks
Posted on Oct 01, 2009
    President:
  • 1,015 Answers
It sounds like it could be the power supply but you will need to do some trouble shooting first. Do you get anything on the monitor? I assume that you are not. What you need to do first is verify that a hardware problem is not the cause. I would start by disconnecting one piece of hardware at a time them plug the clientpro back in and try it. Start by disconnecting the cd-rom drive. Then any floppy drives. Then the hard drive or drives. Then any pci cards or video cards. Then the memory dimms and any usb connectors on the motherboard. By doing this you are making sure that none of the hardware components are causing a short in the motherboard's electrical system. If you disconnect all of these things and power button continues to flash then I am pretty sure it is the power supply. If you have another power supply from another computer you can install it into the clientpro as long as the atx connectors are the same. Let me know if you need more assistance.
Posted on Sep 30, 2009
  • muebe Oct 01, 2009
    It sounds like it is the power supply. I you put a new power supply in and the problem continues then it is the motherboard. I wish you had another computer to use a power supply out of to verify it is the problem. I repair computers at home and I always keep a cheap ATX power supply around just for testing. Let me know if it works.
Change boot order in bios on a client pro 385
Hi Jennifer. According to my research, these are Intel based PC's When you switch the PC on, keep tapping the 'Del' key to get into the BIOS. If it goes into windows, just restart the PC and try again - if the Del key doesn't work, try tapping F2 as that is also used by some manufacturers to get into the BIOS.
Once in the BIOS, just go through the menus until you find the boot priorities screen and make the necessary adjustments. Hope this helps
Apr 14, 2014 | MPC Computers ClientPro 365 PC Desktop
Pins in power adaptor will not insert into place where adapter is to plug in
HI
The port of the power adapter for your MPC Computers ClientPro 414 All-In-One PC MUST be the same below
Dec 07, 2011 | MPC Computers ClientPro 414 All-In-One PC...
How do I remove the front cover for an MPC Clientpro 365 tower so I can add another optical drive?
There should be two Aqua colored tabs on the back diectly under the side panel, press them both at the same time and swing the cover out and it should slide off. Install the optical drive and replace the cover back on...
I have one of these systems and they are easy to work with, relatively speaking!
Sep 08, 2011 | MPC Computers ClientPro 365 PC Desktop
Screen if full of green lines, appears video card is going. Which video card can I get and how do I replace it
The MPC all-in-ones came with a couple different options. Most were sold with onboard Intel graphics, so if that's what you have, there's really no other option but to get a replacement computer (since MPC went out of business back in 2009.) Some were sold with removable ATI video cards, though. If you have one of those (just take a look in Device Manager to find out) then you can look for a replacement card on eBay
Mar 01, 2011 | MPC Computers ClientPro 414 All-In-One PC...
I have mpc clientpro d865 2.8 ghz 1gb Ram this pc not boot usb no option in bios for usb boot kindly solve my problem thanks
If memory serves (I used to work in tech support at MPC until they went out of business) that model did not have the feature. USB booting came out after this unit came to its end of life, so no update was ever provided to add the feature
Feb 05, 2011 | MPC Computers ClientPro 345 S PC Desktop
Need an MPC ClientPro 155 power supply
For most computers, there isn't a power supply made specifically for each. Take the power supply out of the computer, and find out what type of power supply it is. Search for a new one on Google or eBay. Solution-givers cannot sell you merchandise.
Hope I helped
~Aeoryth~
Dec 16, 2009 | MPC Computers ClientPro 155 PC Desktop
The clientpro 385 was recently restarted and now the power button flashes green every one to two seconds. Unplugging the computer and plugging it back in changes nothing.
You may want to check your manufactuar's manual, but usually a flashing green/yellow/orange power light on a desktop computer means a PSU (Power Supply Unit) failure.
If that verifies through your manual and/or their technical support department, contact the company you purchased it through or you can go on a 3rd party site like www.tigerdirect.com or www.newegg.com or even locally at Best Buy and purchase a new PSU.
Dec 14, 2009 | Computers & Internet
Powers on MPC comes on screen. One short beep. Hard drive light and another light flicker, then it hangs.
PUT INA WINDOWS DISK OR THE SYSTEM DISK THAT CAME WITH UR CPU AND RESTSRT,,, FOLOW THE DIRECTIONS
May 11, 2009 | MPC Computers ClientPro All-In-One PC...
MPC ClientPro 1.6 GHz system unit won't power off
Usually, when you hold an ATX power button down for more than 3 seconds, it forces the system to power down. If this is not the case, there may be a hardware problem.
This is a type of hardware problem that I have encountered when one of the cables in a system is stuck on incorrectly. I've encountered this when people:
a) don't have the extra 15v cable correctly inserted on their mainboard.
b) have the flat cable of a floppy disk drive or LS drive inserted the wrong way around,
c) a harddrive or ROMdrive cable incorrectly inserted and / or
d) when the cables between the pc housing and mainboard are incorrectly connected.
If you have just recently installed hardware or someone has just recently worked on it, read the manual of the mainboard and check the settings of the connected cables on the mainboard and drives.
A power light on a PC often turns red when a disk drive is active. That's not a good state in which to constantly power down the PC, because one shouldn't often turn off the computer while it is reading the hard disk, otherwise data corruption or even worse, hard disk damage may occur.
Mar 28, 2009 | MPC Computers ClientPro 345D PC Desktop
MPC Computers ClientPro 545 S (9043751) PC Desktop Logo
423 people viewed this question
Top MPC Computers Computers & Internet Experts
Lee Durbin
Lee Durbin
Bee Santiago
maverick4lye
Level 1 Expert
Are you a MPC Computers Computer and Internet Expert? Answer questions, earn points and help others
