Question about Sony PlayStation 2 (PS2) Console
PS2 consule says read disc error for every game inserted
No matter what game I insert, I get a message across the screen that says read disc error or disc error.
Thank you.
  • 3 more comments
  • savemyps Dec 19, 2007
    Thanks so much will try it tonight.
    I forgot to add that the unit also makes a clicking sound while I am receiving the error message.
  • Anonymous Dec 19, 2007
    my game is not reading
  • coltzone555 Sep 14, 2008
    my ps2 games always say disc read error
  • bcox716 Jan 02, 2009
    constant disc read error message. After several tries, occassionally it works. But loads very slowly. Thanks.
  • 205 Answers
I helped a friend fix his PS2 with these symptoms using this webpage:
http://arstechnica.com/articles/paedia/hardware/ps2.ars
This is not to say yours has the same problems, but it's probably worth a try.
Good luck.
Posted on Dec 19, 2007
  • ohiotom Dec 19, 2007
    The clicking sound is the read mechanism trying to find the starting point on the disk.
    If this works I hope you'll reconsider your rating.
How can u fix error 80010516?
To solve this error :
Never eject disc while game is in use.
Delete all your messages.
If playing a game on disc, clean the disc off and ensure disc is inserted properly.
Upgrade your firmware to the latest version.
Under Game settings, set PS/PS2 Upscaler to Off.
Restart your Playstation 3 and try again.
If all else fails, the disc might be defective.
Mar 01, 2011 | Sony Playstation 3 (PS3) Console
My playstation 2 consule says to insert a format disc
Sounds to me you got 1. a dirty drive 2. a bad laser optic
try to get a cleaning disk and run it if that does not work replace the drive that is all there is to it. There is no special buttons to push its the drive.
please do leave positve feedback and ratings for your free answer today.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Nov 07, 2009 | Sony PlayStation 2 (PS2) Console
Playstation 2 won't play DVDs
if it's a fat PS2 and
model SCPH 30001, SCPH 35001
(not including the models with an 'R' after the model #.
these models need the following to play DVDs:
- PS2 DVD remote with IR unit
- PS2 DVD disc player (sold with DVD remote w/ IR unit)
- PS2 memory card
you copied the DVD disc to the memory card. you used the memory card to play DVDs.
later models didn't need the memory card to play DVDs.
hope this helps :D
Jul 16, 2009 | Sony PlayStation 2 (PS2) Console
My ps2 Cant read my disc!
clean the disk with disk cleaner clean the lens of your ps2 with a cd cleaner meaning a cd with brushes on the other side of it or with some rubbing alcohol then it should let you read your games
Jun 19, 2009 | Sony PlayStation 2 (PS2) Console
Ps2 format disc
Dirty laser / or a damaged disk.
Open it up and use a Q-tip soked in windex
wipe , then try it again should fix the red screen of death.
Jun 04, 2009 | Sony PlayStation 2 Slimline Console
Please insert ps2 format disc?
Try inserting the disc in your computer. If it reads its fine. Then look if the Slus...... is compatible.maybe thats why it doesn't play. your ps2 must have an old bios system even if slim.
Mar 05, 2009 | Sony PlayStation 2 (PS2) Console
Disc read error
Disc Read Error generally means that the game disk cannot be read by your console.
Reasons for Disc Read Error
1. Disk surface scratched or smudged.
2. Disk surface dirty.
3. Lens surface dirty.
Here is what you can try doing.
1. Check the game disc for any scratches or smudges on the surface of the game disc, try to clean them off by using a non-abrasive cotton cloth.
2. If the PS2 console is lying down, please set the console to on its side or if it's on its side set it to flat position, restart the console and then try game again. Always ensure the PlayStation 2 is in a cool, well ventilated place.
3. Remove and reinsert the Memory card of your PS2, restart the console then try running the game again.
Other troubleshooting that you can try.
Change the Disc speed of the PS2 DVD and then try again.
Start the PS2 with no disc in a drive. Press the "triangle" button on the controller.
Use the up and down buttons on the controller to select "Playstation Driver” and press the "triangle" button on the controller.
Select Disc speed. If it is set to "Fast," select "Standard"; if it is set to "Standard", select "Fast" and press the "X" button on the controller. Press the "O" button on the controller. Insert the game disc and restart the PS2. Try running the game again.
Turn the Diagnosis On for PlayStation2 to auto detect the best settings.
From the Browser and System Configuration menu. Press the triangle button to select Version. Highlight the Console from the list and press the triangle button - this accesses the next menu option. The Diagnosis will be highlighted. Press the X button to access the options available. Highlight "ON" and press the X button to affect the change. Restart the console and try the game again.
If the above steps does do not solve the error then you would probably have to replace the disc.
Note: If you are using the Slim version of PS2 make sure that the console is properly ventilated and that it should always be in the standing position, as the slim version of PS2 no fan or any other cooling unit unlike the normal PS2.
Oct 13, 2008 | Video Game Consoles & Games
Disc Read Error ( slim PS2)
Ah yes the dreaded DRE... time to replace your ps2 dude, this is the easiest and least headache solution.
Logged too many hours on those poor machines ;)
Aug 18, 2008 | Sony PlayStation 2 (PS2) Console
Disc error on games only
The old PS2 had lazer calibration issues, which could differentley affect the discs.
How to tune
56K WARNING!!!
Feb 16, 2008 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
97 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
juanmireles1
David
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
