Question about iLO 2600 Television
I have an Ilo 2706. Do I need a converter box?
3 Suggested Answers
Shuttle83
  • 1139 Answers
SOURCE: ILO Model 2706
Hello redrury,
This sounds like an IF problem or it could be a tuner issue. Since it only occurs on channel 21. You are going to need an RF/IF signal generator and an Oscilloscope to troubleshoot this problem. If you do not have these tools and or do not know how to use them I would suggest taking this set to a qualified TV repair facility.
I hope this helps, Thank you, Shuttle83
Posted on Jan 24, 2008
  • 2335 Answers
SOURCE: ILO 2706 TV WONT TURN ON
This TV might have been affected by the power outage even if it was not ON at that moment. There is a standby voltage still present even when OFF and connected to the AC line.
There might be different failures on this TV:
1. The power supply might be defective after the power outage.
2. The main board could also be defective since the power supplies for today's TVs are not well regulated and once the voltage getting to the power supply increases, the standby voltage voltage will also increase damaging voltage sensitive components like the microprocessor or memory circuitry.
Let me know if you require further assistance.
Posted on Dec 18, 2008
Is this system set up with a converter to run off and external roof-top antenna or does it need a digital converter box?
This model will require a digital converter box to receive the digital OTA channels since it has an NTSC instead of an ASTC tuner.
Sep 21, 2010 | iLO 2600 Television
I need a manual fo an ilo TV 27" model IWF 2706 thanks..... jpdobbs
you just need to look around a bit but i'll find 1 for ya
ok all ya have to do is type in ur details and they'll look for a manual 4 ya. use this link. keep looking back though because i might find the actuall document online. goodluck!
http://www.manualsnguides.com/search.php?cmarque=ILO&modele=IWF2706
Apr 30, 2009 | Televison & Video
Getting alot of "no signal"
You will need a digital antenna for reception. You do not need a converter box for your tv. I have a digital antenna and get a bunch of channels in.
Apr 05, 2009 | iLO IWT3206 TV
Dec 18, 2008 | iLO 2600 Television
Recording on DVD using converter box
I have my video outs from the converter box going to the inputs on the ILO recorder, and then from the outs on the ilo to the ins on the tv. Yes, box must be on and used to tune in what I want to record. I have successfully recorded this way. I never use the timer on the ILO anyway, it never works so If you want it to change from one channel to tape another you will have to be there. Also one of my box automatically turns off at a set time on non use so that is another problem. Maybe the newer recorders are differently programed but most cheaper ones don't have tuners in them so I assume they are about the same as what we have. Mostly for people who have paid tv now I guess. I refuse to pay, converter box is great.
Sep 16, 2008 | iLO DVD Recorder DVDR05
Dvd player and analog tv
You're not trying to use the "Tuner" in the ILO are you? Bypass it and use the A/V cables from the "out" of the converter box. I think mine also has the coax type cable from the "to tv" to the ILO, then from the "to tv" on the ILO to the television. Either way should work. Mine works great, its a zenith and I have successfully recorded to discs in my ILO. Just change the Source back to the DVD source to watch a dvd or select the corresponding A/V connections that are hooked to your convertor box to watch/record television.
Aug 12, 2008 | iLO DVD Recorder DVDR05
Ilo DVD player/recorder
> jfthr - Tv convertor boxes transfer digital signals into ANALOG. So when it goes to the dvd recorder it IS ANALOG. I have my antenna hooked to my convertor box, the converter hooked up to the ILO (A/V connections) then, the output on the ILO to the input of my analog tv. (Video selection on my tv). It works great to watch tv and/or record. I switch to the "DVD SOURCE" to watch dvds. Maybe you have the conv box hooked to the tv then the outs on the tv to the dvd. That would explain why you can get a picture but not watch dvd? The ILO has to go between the box and the tv in order to watch dvd.
Aug 07, 2008 | iLO DVD Recorder DVDR05
Can't record from tv or disc,
shouldn't need one, If you can't get the tuner source of your ilo to record, try using A/V cables (output) from tv to (Inputs) on ilo. set tv on channel you want to watch and it should come through to the ilo (selecting the correct source input of course) If your tv is really old and doesn't have A/V then you will need RF Modulator. This way of hooking tv up will also work with recording DIGITAL signal from a Digital converter box type tuner (the tuner in Ilo soon to be no longer operatable).
Mar 30, 2008 | iLO DVDR05 DVD Recorder
ILO Model 2706
Hello redrury,
Jan 24, 2008 | iLO 2600 Television
Televison & Video Logo
83 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
