Question about Maytag MER6772 Gemini Electric Kitchen Range
Heat in lower oven will not exceed 185 degrees
Mer 6772 bcw lower element in lower oven will not work
Posted on Oct 11, 2009
    Guru:
  • 310 Answers
Several possibilities:
1. Bake/broil elements are bad - can you see them glow red?
2. Temperature sensor is out of wack - does the temperature displayed agree with the actual oven temperature? The sensor can be tested by measuring its resistance.
3. If the elements and sensors check out and the oven "thinks" it is hot when it's not, then it is probably your control board. In this case we may be able to help you, we repair these at www.fixyourboard.com.
Posted on Sep 30, 2009
Kenmore plt083-2 won't heat above 200 degrees
Please check that model number again. The one you posted comes up as a refrigerator. Look inside the oven door or the lower drawer.
Feb 03, 2014 | Kenmore 91112 / 91114 / 91117 Electric...
Heating problems for Mitsubishi Galant 2000
1) The "heat" cycle on a vehicle depends on the engine's operating temperature when "heat'' desired," as well as the "external temperature of the atmosphere; colder days will create "lower" internal temperatures for the vehicle's passenger compartment as related to the amount of cooling of the radiator fluid through the radiator.
2) One option exists as to place "a 'piece of cardboard' in front of the radiator itself," especially in very cold areas of the country.
3) The other problem may involve your "thermostat" of the vehicle being "bad" (they fall apart sometimes), versus being of the wrong temperature variety; In this case your "automotive technician" should be consulted so as to replace your vehicle's thermostat with a different thermostat.
4) Lower temperature thermostats (185 F) open the system to the engine at 185 degrees; with 195 F opening the system at 195 degrees.
5) One of these solutions (the cheapest being the cardboard) may be of assistance (just remember to remove the cardboard in the summer/spring).
Jan 22, 2013 | 2000 Mitsubishi Galant
I set the oven at 350 degrees and after 3 hours it has only reached 185 and won't go any higher. The oven is approx. 8 years old.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jul 25, 2011 | Ovens
It takes 28 minutes for the oven to reach temperature of 375 degrees. The ready buzzer goes off in about 15 minutes. The temperature is 300 degrees. Is there any adjustments to be made.
what is your oven if is gas or electric, if is gas easy to preheat by using lower heating element, if electric? that your unit have convection? or not? coz some probelm of the oven is, 1 if the oven is no convection or your oven is single heating in upper element,if your oven have a timer and cut off in 15minute? dont use timer,use a manual timer by it your self,if you want to reach the degrees that you want check your oven if der a lower and upper heating element with convection function,that the one is the most easy way to reach the degree that you want to reach.
Dec 17, 2010 | Ovens
What temp for turkey done ?
Always use an oven bag is used to promote even cooking.
Microwave on MEDIUM (50% power) for 7 to 9 minutes per pound rotating dish every 15 minutes. Not recommended for turkey over 12 pounds
Use an instant-read thermometer after cooking. Turkey is done when thermometer reads 180 degrees to 185 degrees F for whole turkey or 170 degrees to 175 degrees F for turkey breast. Insert thermometer through **** in oven bag into inner thigh for whole turkey or into thickest part of breast for turkey breast.
For easy slicing, let stand 10 minutes after removing from microwave oven. To open, carefully cut or **** top of oven bag. NOTE Microwave directions were tested in 600 to 700-watt microwaves. Higher or lower wattage ovens may need adjustment in cooking times.
Nov 21, 2010 | Microwave Ovens
After cleaning the top half oven with a self-clean cycle the oven will not pre heat past 100 degrees. The bottom oven will heat. What might be causing the top to malfunction? The serial number is...
usually it is the thermal cut off( TCO) ,a kind of themal fuse which goes out if the temp exceeds certain limit and cuts off the power to the elemnts.it is to protect the cavity from over heating.it needs to replaced or reset depending the model. u will need a tech to fix this.
Aug 21, 2009 | Electrolux Ovens
Oven heats to 185 degrees in a hour on preheat
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Mar 23, 2009 | Jenn-Air JGW8130DD Gas Single Oven
Maytag MER6772 Gemini Electric Kitchen Range Logo
262 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
