Question about McCulloch Garden
I have a mcCulloch ms1436nav will go dead when giving the fuel
I have a mcCulloch ms1436nav Been running great, but today after cutting for couple of hours, it would start right up but when giving fuel it would die. I checked and cleaned the carburetor twice with no change. It seems like it is not getting fuel..
    Guru:
  • 597 Answers
DId you check the fuel filter?. If you can reach down inside the fuel tank you will find a fuel hose with a filter on the end of it.
Posted on Oct 01, 2009
  • 3 Answers
Check the fuel cap. Sounds like a vapor lock in the tank from an unvented cap or a blocked cap. If it runs with the cap off or loose, replace the cap.
Wont run unless you run it on half choke,also very hard to start.
Thats is definately a lean condition. Can be caused by one or more of the following problems: clogged fuel filter, rotten fuel lines, stiff diaghrams, and clogged carb screen.
Todays fuel is a large cause of the problem so I advise that you go ahead and service the entire fuel system... replace the fuel lines and filter and rebuild the carb. Also if the primer bulb is discolored ( brown, they are clear when new) it should be replaced too.
This is not a difficult task as long as you are patient and take your time. Carb kits run from 7-12 bucks, a filter is about 3 bucks and fuel line is about 2 bucks a foot and a primer buld is just a few bucks.
I reccomend getting extra fuel line. It needs to be very snug in the tank to prevent leaking so cut an angle on the end of the fuel line to get it started then reach in and grab it with hemostats and pull it though the fill opening; then cut it off even and insert the fuel filter; then pull the line back into the tank to desired position making sure that filter lays loosely on the bottom of the tank, then cut to length to attatch to carb
Oct 22, 2012 | McCulloch Garden
How critical is the oil/petrol mix ratio in terms of starting and maintaining engine running for a McCulloch 2 stroke chain saw?
All the lubrication for the engine comes from the oil mixed with the fuel, so it is VERY important that you use good quaility two stroke oil designed to be used in a chainsaw, and mixed as per the manufacturers recommendations, if you are not too sure then run a 25.1 fuel oil mix, if the egine lacks lubrication the piston will start to scuff around the exhaust port ( the hottest part of the engine ) lose compression and become difficult or impossible to start. A quick check is to remove the muffler and take a look at the piston skirt through the open exhaust port.
Mar 06, 2012 | McCulloch Garden
I have a Mcculloch 16in maccat 35cc chain saw
Does the chain turn freely by hand? Is it being oiled properly? Check the fuel filter, air cleaner, and muffler for plugging. Does 'feathering' the choke make any difference? If it helps, try turning the H jet needle CCW about 1/4 turn which should make it run more rich and 4-stroke until you are cutting which should immediately cause the engine to 2-stroke. Hope some of this helps!
Jul 21, 2010 | McCulloch Garden
Mcculloch EM250-14 RPM Slowed suddenly
The chain must be properly sharpened to cut efficiently and the oil pump must be feeding oil to the chain/bar. Check the oiling by running the saw with the bar tip near some cardboard for a few moments--it should throw off a thin line of oil on to the cardboard. If not, remove the bar and chain and run the motor for a few moments--it should ooze oil out of a side port that exits near the drive end of the bar. If still nothing, check the oil tank filter for plugging, then the oil pump itself--it may have a plastic gear that has stripped it's teeth. Once you get oil from the side port, clean the oil passages in the drive end of the bar, and reinstall the bar and chain. Hope this helps!
May 26, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
How to run the fuel hoses for the MAC 3516. Most of the hoses have fallen apart so retracing the hoses is problematic
A McCulloch Mac 3516 model 21-600032-83 IPL example follows (may not be your saw):
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
http://www.ordertree.com/modelinfo/MCC/22-600032-83-Mac-3216-IPL-211229-01/139.22-600032-83-Mac-3216-IPL-211229-01.1.59.1.html
If the above is not your saw, yours can be located here:
McCulloch IPLs
http://www.ordertree.com/modelinfo/McCulloch/139.59.html
A typical fuel system and a couple of tips follow:
http://www.fixya.com/support/r3706813-_cycle_fuel_system_repair
If properly plumbed your saw will run with carb to primer hose capped off.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 13, 2010 | McCulloch Garden
Chainsaw runs great initially but stalls after 1-3 minutes
If is seems very hot STOP. It is probably running lean and continuing will destroy it (what fuel/oil ratio are you using? 32:1 probably safe). When it starts to sputter if necessary roll it to the side and loosen the fuel cap. Did it smooth out (plugged fuel vent)? Please give me the model and serial numbers (small tag usually on underside) and I can probably find an IPL (exploded parts list) to help us both. Lou
Jan 18, 2010 | McCulloch Garden
Mcculloch 14'' ms1436nav. chainsaw I need an owners manual. I can find a parts list but I want the actual owners manual
Afternoon Jaches; Mac Operators Manuals are hard. Please try here if enough of us try maybe it will be fixed.
McCulloch Manuals
Operators Manuals: are much more difficult. I have dialed this number many times (Contact Us - All McCulloch Products 1 (800) 521-8559) and have yet to get a satisfactory response. Please try this! If enough of us try they will fix it! If unsuccessful with McCulloch try here:
Beg for manuals thread (ArboristSite - free to join). Please use the search function first, it has probably been asked and answered.
http://www.arboristsite.com/showthread.php?t=72322 HTH
Lou
I searched for 1436, Mac 1436, McCulloch 1436, & MS1436NAV without a hit. Post your need someone may answer. This is where I got my Mac 110 and Power Mac 320 (through a contact made on FY) operators manuals. Good Luck
Nov 28, 2009 | McCulloch Garden
My mcCulloch mini mac 25 starts, runs, and cuts, but when it warms up it dies and will not restart
It sounds like the fuel cap is clogged. The fuel cap must be able to breathe in order for the carburetor to operate properly.
One way to be sure that it is the fuel cap is: The next time the chainsaw starts to die, loosen the cap for a second or two, it should start running properly again.
Jim
Jun 19, 2009 | McCulloch Garden
Mcculloch super 6-10 chain saw
the throttle stop had worked loose and would drift from low to high while running. Reset and tightened.
Jan 16, 2009 | McCulloch Garden
Carb adjustment on McCulloch 32cc?
the l is for idle and the h is for top end but thats not ur problem it sounds like ur carb is clogged there is a screen inside of the carb the fuel gets crystalized and blocks off some and sometimes all of the fuel ill bet thats the problembut u can try the adjustments first give the unit full throttle and turn the h adjustment screw in and or out till it sounds great and at full power if that dont work then do the screen in the carb
Nov 12, 2008 | McCulloch 26cc Backpack Blower with Dual...
Garden Logo
190 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
