Question about Sony KDF-E42A10 42 in. LCD Television
My KDFE42A10 has a very loud fan noise comming from the light bulb area, but neither fan (the 2 fans you can see with the back off) is causing the noise
SOURCE: pitched noise coming from the fan
When I first got my PS3, It had the annoying high pitched fan sound as well, but went away after a week and has worked fine ever since, no problems at all. I have the 60 gig version, so. Maybe if yours is new you just need to break it in?
Posted on May 04, 2007
  • 15 Answers
SOURCE: loud fan noise
i had the same problem once make sure that the ps3 is not on a carpet, or move it to a hard suface and a more ventilated area,, that is probably the best solution since the ps3 requires alot of cooling down.
Posted on Apr 03, 2009
preachw996
  • 1179 Answers
SOURCE: over heat cooling fan load noise remove and replace
A bearing more than likely has went bad causing your fan to stop properly cooling your unit. Replace with a compatible fan and you should be all set. Hope this helps.
Posted on Jun 03, 2009
BlacMamba
  • 215 Answers
SOURCE: Sony Vaio with loud fan and switches off
take it to an expert... the fan is faulty
Posted on Nov 07, 2009
ladywinn
  • 5138 Answers
SOURCE: replaced bulb in kdf50e2000 ,got a red lamp light,
Ballast Board it is what powers Lamp.
Encompass Parts 1-800-638-3328
Posted on Mar 26, 2010
I have a broan ceiling light and exhaust fan. We changed the light bulbs now the fan is really loud and makes noise it didn't before?
Did you use the recommend wattage bulb (or that was in there)?
If you used the same or a higher wattage bulb it may burn hotter. When bulbs "burn" (are on) they actually do burn-out and may get cooler (and not as bright).
Changing the bulbs may also have shaken dust loose, allowing the fan to turn more freely and quickly, and if the bearings/lubricated points which may have been worn now shake about causing more noise, or, dust got onto the fan blades causing them to be heavier on one part than another which will definitely cause it to shake about and make a lot of noise (like unbalanced clothes in a washer's spin cycle).
Sep 27, 2014 | Dryers
Mitsubishi mighty max 3.0 v8 loud noise coming from the fan area
If the fan is attached to the water pump tahe hold of a blade and try back and forward towards the motor. If there is movement there it will be either a fan hub failing or a water pump bearing. Second check remove the fan belt and check for noise.( idle engine for short period of time) If it is gone confirm pump by spinning any adjuster pulleys and check for noise or rough movement
Jan 12, 2013 | 1994 Mitsubishi Mighty Max
Bulb went out for the 2nd time in less than a year on Mitsubishi WD52327. Also making a loud grinding noise. What is my problem?
the grinding noise is from the cooling fan that cools the bulb. It needs to cleaned or replaced. You will need to take the back cover off the set to get at it. If the cooling fan is not doing its job that would cause the short bulb life and the noise
Jan 03, 2011 | Mitsubishi WD-52327 52" Rear Projection...
My side by side has a LOUD whining noise coming from behind the freezer area that lasts for up to an hour.
This noise is most likely comming from the fan motor. The main board often causes the fan to be noisy but it could be a bad fan motor as well. http://www.appliance-repair-it.com/refrigerator-fan-motor.html
Sep 10, 2010 | GE Refrigerators
The fan that is behind the bulb is making a loud noise for a few minutes and then the noise stops. We tried spraying the fan with WD40. ?? We can't seem to find a way to remove/replace this fan. Can't...
sometimes dust accumalates on fins of fans and causes rotation to deform and gets fan off balance causing noise .Also heat from lamp causes deformaties on fan and causes fan bearing to make noise.These fans can be replaced fairly easily
Jul 30, 2009 | Akai PT50DL24 Television
Loud noise
The compressor fan is making the noise and causing overheating as well. Easy fix. Call Danby with model # and they can figure out correct fan. Part will cost around $10 and is easy to replace. Plug and play with screws. Good luck
Apr 21, 2009 | Danby Silhouette DWC512BL Wine Cooler
I have owned a Sony Grand Wega for about 3 years now and for the past few months the TV has been making a very loud noise. I thought the noise was the fan but came to find out it was not the fan and was...
There is a fan beside the lamp chamber in this TV. There should be 4 fans total, and the one beside the lamp chamber might be making some noise. They are all bearingless fans, so the noise should be relatively low-pitched "whirr" if it is the fan. If the noise is more of a buzzing sound, it could be coming from the lamp driver (ballast) or from the lamp itself. Lamps tend to do strange things toward the end of their life.
If you have never changed the lamp, it is about time. They have a 2.5 -3 year life span with average use.
One thing you can try is to turn the TV on from a cold start, and watch inside the vent areas beside the lamp chamber. If you hear the noise before you see the lamp light up, then it is probably a fan. If it starts as soon as you see the lamp light up, it is the lamp or ballast.
Hope this helps you...
Jan 06, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Toshiba DLP fan noise (52hmx95)
i constantly hear complaints about fan noise in dlptvs if you sit in front of your computer you will hear the same noise even in the next room there is no solution to the fan noise problem this product has a huge cage fan and a second and third three inch fans in it.... more than the samsung product it can be noticeable if the tv is on hard surfaces ie wood floors ,inthe corner, glass top etc the vents on the back of the tv allow for proper cooling of the lamp at shutoff so it doesnt shatter the tube its kinda like annealing glass its designed to extend the life of the lamp .... which im sure youve priced call toshiba and tell them your lamp is bad right now and get a new one for an emergency ( warranty if you can do it ) they are also improved this product is known to have short bulb life sometimes the zinging noise you hear is indicative of a bad color wheel in the light engine which would require replacement ( not cheap) toshiba will not piece out the color wheel assembly individually
Nov 30, 2006 | Toshiba 62HM95 62" HDTV
Sony KDF-E42A10 42 in. LCD Television Logo
352 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
