Question about GE Profile Prodigy WPSE4200A
My GE Prodigy washing machine stops after 15 seconds of agitating
My GE Prodigy washing machine (model #WSSE4220) fills, begins to agitate and then stops after about 15 seconds. The machine smells like it's burning when the agitating stops. I've tried resetting the motor with the recommended opening and closing of the lid. I had no problems until some electrical work was done in my kitchen and the washer was still plugged in. The washer drains fine. Any suggestions before I buy a new one?
vest6
  • 196 Answers
SOURCE: Spin and Agitate problem on GE Profile Prodigy WPSE4200A
This machine uses an electric water pump. I would check to motor. Remove the front panel and operate the machine to see if the motor is working. Check this by listening to the motor and watching the belt. If you hear the motor but the belt does'nt move then there may be a problem with the pulley or motor clutch assy.
As far as not draining or pumping water ? Check the wiring from the pump to the control panel. If these wires are alright then i suspect the pump.
Posted on Jan 12, 2008
MNTECH
  • 1543 Answers
SOURCE: GE Profile Prodigy Machine not agitating
If the motor runs when it is suppose to be agitating, but the agitator does not move, pull the agitator straight up and out of the machine. Sometimes this is difficult, but you can slip a belt or similar object under the agitator, attach it to a broom handle and yank up on it. Now take the bolt out of the agitator drive collar and remove it. If you can not turn the splined transmission shaft with your fingers you are in luck and should be able to just replace the can shaped agitator drive spline. (part number WH49X10042 ) If you can turn that splined shaft with your fingers you are looking at a new transmission.
Posted on Nov 11, 2008
kram26
  • 544 Answers
SOURCE: washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
Posted on Mar 29, 2009
  • 23 Answers
SOURCE: my washer wnot agitate unless i slam lid
is the lid up during the filling process? the new washers will not agitate unless the lid is down. no need to slam the lid.. There is no pin to push the activator switch.. they are controlled with a magnet...
Posted on Jul 31, 2009
erpaalai
  • 999 Answers
SOURCE: Maytag top loading washer will not agitate
My rule of thumb: Take what you paid for the washer new and divide by number of years without repairs. That is your cost per year for the washer. If the repair will get you another year and is less than the number above do the repair. If you have done more than 2 major repairs in a year it is time to think new. eric
Posted on Aug 10, 2009
GE Prodigy Washer: Doesnt agitate or spin. Fills ...
Hello, If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
Thanks
May 19, 2010 | Washing Machines
GE profile top loader, agitator and spin start and stop
Is this a newer model washer? I have one of the newer models and it does the same thing. It is supposed to do that.
May 23, 2017 | GE Profile Prodigy WPSE4200A
Machine fills with water, sits for a couple of minutes, agitates for 15-30 seconds, stops for 3-5 min. agitates for 15-30 secs etc... When rinsing, empties water starts to spin, kicks into high gear for a...
Your motor/clutch combo is on the way out. The motor is overheating and turning off. Cools down and restarts.
You need a new motor/clutch combo or a new washer. I do not recommend another GE.
Jul 07, 2009 | GE Washing Machines
Washer only spins
Have you tried to unplug the machine, sometimes the control boards can get stuck and if you unplug it for say 30 seconds then plug it back in, it may reset itself. otherwise you may have to call someone these are very complicated machines.
Jun 19, 2009 | GE Profile Prodigy WPSE4200A
Washer will not agitate or spin
HI,
thanks,
Mar 29, 2009 | GE Profile WPRE6100G Top Load Washer
Washing machine quits after filling
I believe you need a new belt. The weight of the water is to much for a loose belt that is connected to the agitator.
2. Make sure nothing is blocking the safety shut off located on the machine.
Jan 19, 2009 | Washing Machines
My ge prodigy wpse5290 won't stop filling and won't drain, spin or agitate. I replaced both the fill switch and control panel (twice). What else is there?
replace the hose that leads to the fill switch. there is most likely a pin hole sized hole in it not allowing the air pressure to build up and make contact witht the fill switch
Jan 01, 2009 | GE WWSE5200B Top Load Washer
Nov 11, 2008 | GE Profile Prodigy WPSE4200A
Kenmore Elite Calypso Washer agitator malfunction
you either have too much stuff in it or something that gets under
the agitator or it has a weak transmission
Mar 16, 2008 | Washing Machines
Agitator not washing clothes
check and make sure the agitator hasnt come loose or broken pull up on it and see if it comes out if not the bolt is in it, then grab ity and twist it do you feel any drag on it if not look under the machine and see if the pully has slipped down or if something looks loose. you should norice any problem
Sep 24, 2007 | GE Profile Prodigy WPSE4200A
Washing Machines Logo
205 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
