im going to assume the satellites are not locked on.
look up at the top right corner of the map screen, and there should be atleast 4 green bars..if not, the satellites have not locked on to your position yet and wil show the last location you were at when i lost the satellites.
take the unit out side in clear view of the open sky and turn it on, then hold the power button for ten seconds. after it turns off, hold the power button till it starts. let it sit outside for up to 30 minutes to aquire the satellites.
if that fails, go HERE and download and install the latest update. just follow the install direction and it should fix it.
My Magellan 3200 when plugged to the charger, displays a blue screen with a message "USB has...
(More)
My Magellan 3200 when plugged to the charger, displays a blue screen with a message "USB has been connected to the unit, please follow instruction for PC application for updating maps or software."
I have a 4000XL it powered up briefly then nothing new batteries did not solve the problem. Any...
(More)
I have a 4000XL it powered up briefly then nothing new batteries did not solve the problem. Any suggestions please.
I get to the bootloader screen but nothing else will happen. I would like to load the os system. I...
(More)
I get to the bootloader screen but nothing else will happen. I would like to load the os system. I can scroll thru the choices, by hitting the reset button. Magellan is a waste of time and just what you to buy a new unit. they hope it lasts for a year and then you buy a new one they don't repair anything.
