Question about HP OfficeJet 7310 All-In-One InkJet Printer
After a paperjam my printer will not print fom the computer and i no longer have the software to reinstall. I have checked the connections and the printer work to make copies or fax but will not print from the computer
  • 855 Answers
Check in the control panel and go to printers. Then make sure your printer is still set as default printer. If it still is try restarting your computer. At times even though these are elementary things these are usually all it takes to repair minor printing problems.
Posted on Sep 30, 2009
My printer no pm235 problamas errar &inkpads rare
It ispossible that the printer has errors as there is a software error. Hence to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can
also be poor ink cartridge contacts
Apr 05, 2011 | Epson Printer
I recently downloaded the printer on my computer but when I try to print, it doesn't print the page centered. It prints to the left. We have this problem when printing from several computers. How can...
I suggest that you try to do a reinstallation as the PC and printer has not meshed up well. So remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Apr 04, 2011 | Ricoh Aficio SP C410DN Laser Printer
Printer willnot print off of computer hpphotosmart cs3100 all-in-one series
If the computer will not print to your printer, and this just happened, re-check the software or reinstall the software for this printer on your computer.
Sometimes the software will get corrupted and needs to be installed.
Other areas one will need to know is;
How old is the printer. New vs Old.
How old is the the software being used, is it for XP, Vista (32 bit vs 64 bit)
Reinstall the drivers from the manufactures website, they have the latest drivers for the printer.
In the properties area of the pritner, a print copy should print out, if it does not there is still a connection issue with the computer and printer.
Most times the software is not on the computer correctly and cannot connect with the printer.
Try this and see how it works. It is hard to tell what the problem is without knowing more about what exactly is happening.
Oct 24, 2009 | HP Office Equipment & Supplies
My printer says there is a paperjam but I don't see a paperjam.
its a mechanical problem ...
check the rollers of the printer ..and the paper pick mechanism ..maybe it can't caught the paper in the tray that why it display an error of jammed..
May 24, 2009 | HP DeskJet 3653 InkJet Printer
My HP 1020 will not print. I get a message that there is a paperjam and there is not a paperjam. The printer has hardly been used. Can anyone helP?
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 09, 2009 | HP LaserJet 1020 Printer
Can't get printer to print
I am hoping that you have you original install disk or that the windows has a driver installed alread as I believe that the Lexmark website no longer supports your printer. If you still have the install disk;
 Disconnect the printer from the computer.  Remove (Delete) the printer(software)from the computer . Reinstall the printer and software , if not a part of windows already.
Feb 16, 2009 | Lexmark C533DN InkJet Printer
Connection problem
Check and make sure that all of the cables are firmly connected including the printer's power cable and the cable that connects the printer and your computer. Cables can seem connected but occasionally, they can work their way loose just enough to interrupt the contact.
Check the cables to make sure they aren't damaged. It's pretty common for a cable to become damaged if a chair with wheels has rolled over it a time or two. That would be enough to interrupt the connection between the computer and the printer. If it looks like you have a damaged cable, you'll have to replace it.
If the cables are well connected and undamaged and the printer is turned on, try rebooting the computer, then see if it will recognize the printer.
If those steps don't work, you'll probably need to uninstall and reinstall the printer software and drivers. It would be ideal if you had the original CD with the printer software on it, but those disks usually get lost over time.
The HP web site has a page that describes how to uninstall your printer's software:
Uninstalling Your Printer Software in Windows
If you don't have the original software disk, you can download the necessary software from HP's site:
Drivers and Software
I didn't find a web page that provided the specific instructions for reinstalling the printer, but you can download the user's manual from the site:
Printer User Manual page
I hope the solution is a relatively simple one, but if it comes to uninstalling and reinstalling the printer, it is a "do-able" task.
Post back your results and let everyone know which solution worked for you. Good luck.
Sep 02, 2008 | HP PSC 1610 All-In-One InkJet Printer
Print jobs no longer arrive on printer
try this: make sure you do not have any pending printjobs (cancel all documents if there's one) then delete all printer icons. Reboot the computer then launch the printer server software to locate it. add that network printer & make it your default.
probability is that some of your applications are sending printjobs to the wrong queue (like the one for the USB connection).
Aug 18, 2008 | Lexmark N4000e Print Server
X1155 printer
If the power button blinks. It usually suggest that:- there may be faults with the printer itself. uninstall the driver-software. and setup the printer again. check for paperjams and also ink-levels.
ensure that all leads are connected correctly. and you have the most up to date drivers available for that model.
hope this helps.
Mike@Compurepair.
Feb 20, 2008 | Office Equipment & Supplies
Printer
Sometimes just a teensy bit of paper stuck inside will make it say paperjam. I would check very well.
Dec 11, 2006 | Canon I900D InkJet Photo Printer
HP OfficeJet 7310 All-In-One InkJet Printer Logo
62 people viewed this question
Seeker5211
Seeker5211
