Question about Maytag MSD2456G Side by Side Refrigerator
Refrigerator not cold.
In the last few days (perhaps the past week or so) the refrigerator has not gotten cold, even though the thermostat setting has been adjusted close to "Coldest". The freezer still works, but the refrigerator will no longer get cold.
  • Loubo Dec 19, 2007
    Same problem?
    Fridge won't get cold.
  • 410 Answers
If the freezer section is still working ok then check for ice build up inside freezer on the back wall, its possible that the unit is not defrosting and ice is building up on the cooling coils, the most common culprit is the def thermostat. easiest way for you to get it going again fast is to manually def the coil.
remove the 2 screws about half way down the back freezer wall. then using a blow dryer def the ice from the coil.
since this refrig has an electronic def control i would recomend calling a reputable service company to check it further for you..
Posted on Dec 19, 2007
Freezer and refrigerator stop getting cold
Most likely it has a coolant leak or the compressor is bad. I would call GE as there may be a recall to repair this no matter if you are the original purchaser or not. Although with the amount of computerization in home appliances, it could be a main circuit board going bad.
Feb 12, 2014 | GE PSC23SGPSS Side by Side Refrigerator
Fresh food compartment is too cold.
It's ether a bad thermister out thermostat or a damper stuck open I would guess.
Sep 03, 2012 | Frigidaire GLRS237ZA Side by Side...
The freezer is working extra well but the fridge is not getting cold even though it's set at 7
Check that the vent opening inside the fridge is not blocked. Depending on the age, some of them now have a filter that needs to be changed periodically. RepairClinic.com or Sears sometimes are able to give you an answer over the phone as to what else to check.
Feb 04, 2018 | Amana ABB2223DES Stainless Steel Bottom...
The freezer section seems unable to get to -18 degrees in for the past couple of weeks, even on Super freeze. It has been fluctuating between -11 and -14 for the past week with Super freeze setting on...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 01, 2011 | Refrigerators
Our refrigerator started not being cold
your rtc or contactor on the compressor body needs replacement
Jan 01, 2010 | Maytag Performa PAV2200
Freezer keeps frosting up and fridge doesn't get cold enough
Your defrost system isn't working. Check your defrost heater, defrost thermostat. http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php If they are OK the problem is the electronic control. Part 32 on this diagram. http://www.appliancepartspros.com/sect/i/2/w/i2wajbeu9f.gif
Jul 01, 2009 | Jenn-Air JCB2280HES Side by Side...
Refrigerator side temp keeps dropping below freezing.
Set the freezer temp control to MAX cold and see if it improves.
If not replace the off/on thermostat.(cold control)
May 24, 2009 | Kenmore Refrigerators
Cooling and freezing gradually getting worse
check the coil underneth the unit for debris and alos if the fan is working or not
May 22, 2009 | GE GSL25JFPBS Side by Side Refrigerator
My 3 yr old whirlpool fridge has been constantly running for the last few days. The temps in the fridge and freezer portions are running high and the sides of the fridge are warm to the touch. What they...
" The refrigerator never cycles offThe thermostat cycles the refrigerator on and off. The refrigerator normally runs as long as the temperature inside the refrigerator is higher than the set temperature. If the temperature inside the refrigerator is cold enough and the thermostat still does not cycle off, the thermostat may be defective. If so, you need to replace it, because it cannot be repaired. If the thermostat is not defective, you may have a problem with the sealed (refrigerant) system, in which case you should contact a qualified appliance repair technician.
From repairclinic"
Aug 29, 2008 | Refrigerators
Refrigerator not cooling
-check your thermostat setting at refrigerator it should be at cold. Same digital control they have separate settings.
- Check also the vents of your unit for obstruction.
Jan 13, 2008 | Refrigerators
Maytag MSD2456G Side by Side Refrigerator Logo
169 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
