Question about Maytag Washing Machines
My maytag washer just stopped model #hav2557aww serial #10205741ec what do i look for
5 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: ginding or nocking noise when washer spins.it is level
Transmission bearings are going out.
Posted on Jun 08, 2009
  • 51 Answers
SOURCE: My Maytag HAV2557AWW Loud Noise
pull hoses off the pump and see if there is anything stuck in it
Posted on Jun 14, 2009
sclarke7
  • 222 Answers
SOURCE: Model number AS 200 serial # 251033 Maytage
either a bad pump or a worn or missing belt, lean machine back and check your belts
Posted on Sep 19, 2009
SOURCE: can't find value or date of manufacture of wringer washer(maytag)
I have a 1936 maytag gyratator wringer type electric washing machine in very good condtion - it works like a charm. What is it worth? I am out of room to continue storing it inside and it too good to leave outside - all the decals on it are like new with the exception of the bottom of the one with the years of maunfacture on it - it goes from 1922 to 1936
Posted on Mar 10, 2011
Model hav2557aww. Why does the motor only hum when started?
Because it is stuck and if you leave it on like that it will burn out. You need to find out why it is not spinning. Disconnect the belt and make sure motor spins - then starting from there go through all of the mechanical connections and look for trouble.
Aug 06, 2015 | Maytag Washing Machines
Check drum not jammed check drive belt not broken or stretched.
Aug 06, 2015 | Maytag Dryers
Can I remove the Pully assembly from the water pump of my maytag washer model hav2557aww
Usually you can. You would have to remove it in the event that the pump would have to be replaced.
May 08, 2012 | Maytag Washing Machines
What year is my may tag washer Model L4480 serial #564799PA
this is the report data from maytag for your washer:---
Brand: Maytag---
Country: any--
Model: L4480---
Serial: 564799PA--- This product appears to have been manufactured January of 1985.----
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Mar 17, 2010 | Maytag Washing Machines
Clothes look drab after washing them.
Is the machine new or old? How long has this been a problem? Has this been occuring slowly or has it started suddenly? Before you give blame to the machine, I suggest you wash your clothes at a laundromat or a friend/relative washing machine to see the results you get. Also, the detergent could be partially at fault especially if you use too little or too much (too much will cause a film to build-up on the clothes that cannot be washed away enough durung rinse). IF AFTER TRYING THESE SUGGESTIONS YOU STILL HAVE THE PROBLEM, open the lid while your Maytag is washing to see if the water level is sufficient and to see if the aggitator is moving; note- you may have to open quickly and check very fast to see if there is aggitation movement because some models stop the washing if you open lid (all models stop the rinse/spin action if you open lid.Goodluck, Macgivor
Nov 09, 2009 | Maytag HAV2557 Top Load Washer
I was wanting to know the year of the maytag neptune washer? model # MAH5500BWW
Try and get the serial number then contact a Maytag agent. The serial number in most cases is a date code.
Jun 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Jun 12, 2009 | Maytag HAV2557 Top Load Washer
Free advice on what recalls maytag is fixing free on front loading neptunes w/built in water heater
Fee advice???are youlookingperhaps for possible recalls on the maytage front loader?? a call to the manufacture with the model and seriasl number will enable you to acess all the current recalls
Mar 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
114 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
