Question about Samsung WF337AA Front Load Washer
Samsung WF337AR front load washer
When using bleach, it takes about 2 more cycles for all the bleach to get out of the system. We have already ruined many clothes due to this. Any suggestions?
Use weaker bleach
Posted on Jan 04, 2008
I accidentally put bleach in the fabric softener compartment of my Samsung front load washer. Now it's vibrating funny. Coincidence or did I tear something up?
Coincidence.
Just runt the washer through a rinse cycle to clear it. The only thing the bleach will do is clean the drum out.
Vibration is caused by badly overloading or underloading
Sep 08, 2017 | Samsung Washing Machines
We have Samsung WF448AAW steam, silver care washer. This problem only occurs on towel cycle. When we wash colored cotton terry bath towels and wash cloths there area areas about the size of your hand or...
Hi
This type of issues usually occur when the washer is unable to drain water completely, you can run your washer at its hottest temperature setting with 2 cups of vinegar inside the unit. After this take off the bottom front panel and clean it completely, also clean the drain hose and drain pump filter, the bleach marks should disappear after doing all this. Hope this helps...please post back for further assistance.
Daniel
Jun 17, 2011 | Samsung WF448AAW 4.5 cu. ft. Front Load...
My Samsung front load washer, which is about 1 1/2 old, smells like mildew. I've read that people put bleach in the drum and run it on a maintanence cycle and I'm wondering how I do that. ...
I had this problem too---same washer. The rubber door seal often harbours moisture and it's hard to clean just by running a cycle. You'll have to scrub away the mildew by hand.
Get a pair of gloves, a soft sponge, and a bucket of hot water with soap and bleach. Open the door. Press the sponge into the folds of rubber where the moisture is trapped. Work your way around the circumference of the seal. Repeat until the black goo is gone. Finally run a rinse cycle with some bleach.
Avoid this in the future by leaving the door ajar when not in use. Tuck an old towel into the seal to wick away the water.
Let us know if the smell is still there.
May 20, 2011 | Samsung WF337AA Front Load Washer
After each load the "fill bleach cup" is filled with water. I have to take the whole tray out and flip it up-side-down to empty the water. I cannot find where the thing can be clogged. I can't use bleach...
Bleach & fabric conditioners "syphon away" into machine... try adding 1/2 lt water to the bleach compartment, if it then syphons away your syphon is not blocked. If it does not drain you will need to find the syphon cap - genarally just a tube, most manufacturers will make the tube a different colour to the rest of the draw.
If it did drain when water added you may have issues with bleach not being a part of that particular cycle, delicates for example...
Apr 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Samsung Front Load washer has odour
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
Sep 01, 2009 | Samsung WF203ANW Front Load Washer
Clothes picking up residual dyes & bleach spots
I dont think the washing machine is designed to put bleach in??
Remember a washing machine is never really empty of water.
It holds about 1 litre of water in the tub after each cycle.
Thats the way they are designed.
The same as front loader.
I would put clothing in the tub to bleach,then rinse them in the tub with cold water ,then wash them?? cheers
Jul 25, 2008 | Fisher Paykel EcoSmart GWL15
Liquid Bleach dispenser doesn't work correctly
This may not be relevant, but by design, bleach does NOT dispense in the Buly/Bedding, Kids Wear, and Silk/Ultra Delicate cycles. If you try to use it, it remains in the dispenser.
As for the yucky smell, leave the door open when not in use.
Nov 16, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Facia panel keeps breaking/bleach ruins clother/water level too low and doesn't clean well
Do not use bleach, if you do you will get a bleaching effect,the new machines use less water, do not volume overload machine. mix the load to prevent uneven out of balance spin and check feet are level. Ragrds Advisor
May 05, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Samsung WF337AA Front Load Washer Logo
169 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
