Question about Frigidaire Dryers
My dryer overheats every ten minutes or so and shuts off. Now has burning smell and big burn mark on back. Is not lint!
Actually i've had this exact problem.
the burn mark is from clothes sitting on that metal piece as soon as the dryer shuts off and that is still hot. then once it burns the clothes, fabric is pulled through that metal opening and falls on the other side which builds up on the bottom of the dryer. you only need take off the bottom of the dryer and vacuum it out or remove it by hand. taking it apart is difficult and can be dangerous with all the wiring inside, so try not to take off any wires, otherwise when you plug it back in it could ground to the outside of the dryer and blow the motor.
Posted on Jul 19, 2010
Shuts off after approx 5-10 seconds; then slight burning smell
I would take the top off and continue to clean the lint out of the machine
Dec 22, 2014 | LG DLE3733 Electric Dryer
Lg tromm gas dryer burning smell shuts off
Hello Debi;
My name is Peter. I am a retired field service appliance technician.
You have a dangerous situation.
1.) First, your dryer is shutting down because your dryer is plugged up with lint and there is no air flow. You need to remove the top cover and control panel, the front cover and if your hot air distribution manifold id in the back or front end, remove that and clean. With a dry rag (DO NOT USE LIQUID CLEANERS), wipe the grease and grime off all components.
2.) The burning smell is the lint burning. Fortunately, due to the lack of air, the lint is being extinguished.
So far you are lucky. You have not had a major fire. DO NOT USE THE DRYER UNTIL THE ABOVE TASK HAS BEEN ACCOMPLISHED.
I wish I could provide you with more specific information on your dryer, but you did not provide a model number.
Nov 20, 2014 | LG Dryers
My dryer leaves a weird smell on my clothing anything i dry no matter what setting i use , how big or how small the loads are and it smells.
Try checking the back of the dryer, there should be a foil tube type exhaust. Sometimes if the tube falls off the wall (mine had a plug on wall) the lint backs up and burns or cooks. That's the cause of your smell.
U can also use a vacuum and try to vacuum the lint trap at the front of the dryer. U might have to unscrew the grill.
The bottom line is that there is lint somewhere in ur dryer and that's what is causing ur smell.
Nov 18, 2013 | Dryers
We have a DLEX 2801 front loading LG dryer. It has been having a slight burning smell, so we checked the lint below the normal lint collector and cleaned that out well. However, there is a plate with...
Usually when an electric dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat. Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws. The vent holes you described that look burnt is the heat intake for the dryer. Almost all dryers look like this and it is normal.
Feb 02, 2011 | LG DLEX2801 Electric Dryer
I have a Kenmore Elite model 110.63022100. My dryer runs for 30 seconds to 1 minute before completely powering off. There is a burn smell when it stops.
Usually when an electric dryer overheats and shuts down, it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat.
Jan 09, 2011 | Kenmore Dryers
I have a used GE DCLR333ETOAA model and last time was used it work for few mins. but smell like burn and then stop working. What you think it is?
If the machine quit and won't restart, I would be looking at the drum belt. Some machines will not start if the belt is broken. If the smell you are getting is more electrtical than a rubber smell you need to be checking the thermostats and make sure the venting from the back of the dryer to the outside is not full of lint because the safety thermostat will shut the dryer down so it doesn't overheat.
Jan 24, 2010 | GE Dryers
Overheating/burnt rubber smell
classical sign of a bad motor. the motor has a thermal switch on it telling the unit to shut off when it gets hot. after it cools down, the switch will tell the motor to turn back on again. good luck, i'm pretty sure that's your problem. contact me for further help if needed. thanks :)
Jul 06, 2009 | Kenmore 73952 Gas Dryer
Frigidaire dryer overheating and shutting off mid cycle
Usually dryers have the exact opposite problem where the heat does not come on. Because most dryers have thermocouples (rated at 150 & 185 degrees) to prevent the dryer from getting too hot. You may have the blower fan come off of the motor. Check and see if you have air moving out of the vent. Also unplug the dryer and take the back off and inspect the area where it is getting hot. It may be some wires touching the case. Sometimes you can see the problem or smell something getting too hot. Either way be carefull. A dryer that overheats is a fire hazard!
May 18, 2009 | Kenmore 24032\24036 Top Load Washer
Crosley CDE8000W Dryer has electric burning smell and shut down
it is most likely the belt. the squealing noise is because the motor is turning, but the belt is not. a replacement belt is not too expensive and it is fairly easy to replace. if you need directions how to replace it, let me know
Oct 27, 2008 | Dryers
Duet Dryer
burning smell would be coming on the coil of an electric dryer. the coils could have catch some lint that produces that distict burning smell..
i hope i was able to solve you problem..
pls rate me.
tnx
drcool
Jul 15, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
143 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
