Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
Sony KF50WE610 screen turns green often? what could be the problem/ Thank you, Lloyd
  • lwarner4q Sep 30, 2009
    Hi
    How would i fine the faulty convergence IC or STK. I found the service manual on this site -
    Normal
    0
    false
    false
    false
    MicrosoftInternetExplorer4
    /* Style Definitions */
    table.MsoNormalTable
    {mso-style-name:"Table Normal";
    mso-tstyle-rowband-size:0;
    mso-tstyle-colband-size:0;
    mso-style-noshow:yes;
    mso-style-parent:"";
    mso-padding-alt:0in 5.4pt 0in 5.4pt;
    mso-para-margin:0in;
    mso-para-margin-bottom:.0001pt;
    mso-pagination:widow-orphan;
    font-size:10.0pt;
    font-family:"Times New Roman";
    mso-ansi-language:#0400;
    mso-fareast-language:#0400;
    mso-bidi-language:#0400;}
    http://www.eserviceinfo.com/
    the model number is KF50WE610. One of the phone support techs at sony said it might be the Optical Block. what do you think
    Thank you.
    Lloyd
  • lwarner4q Oct 01, 2009
    I am looking for someone who has ether fixed this issues or has seen it.
    President:
  • 2,923 Answers
This is a heat related issue. The problem could be that the bulb is getting too hot. It usually happens once you've got a defective bulb that you need to change or you change the bulb with different part number.
If the TV is still under the warranty, take the advantage and get your TV repaired for free. If you run out of warranty, you should not spend too much money just for the bulb replacement.
Have a great day!
Posted on Oct 01, 2009
  • 11,896 Answers
Could be faulty convergance IC's or STK's depending on your model. You can test them with a tester. If you have color tubes, then the green one is surely faulty.
Posted on Sep 30, 2009
  • Nate Stansfield
    Nate Stansfield Sep 30, 2009
    that is also very possible. You may be able to test with continuity tester to make sure. But it is very possible. Testing would be the best bet.
What is wrong with my sony kf50we610?
Chances are the lamp needs to be replaced.
May 20, 2013 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Grand WEGA KF50WE610 tv will not turn off
Problems that do not happen all the time are hard to find--2 things: if set blinks the red light try to count the blinks--usually that is an error code.
Also this set if it does for the most part work should have an error buffer.
With the set turned off and using the Sony remote:
Display
5
Volume down
power
If it has this when it comes on there will be a box in the middle of the screen with several items listed---all must have a zero to the right of them---if one has a number(any number) it means it has detected that error that number of times.
Let me know what you find
Apr 11, 2012 | Sony Grand WEGA KF50WE610 50" Rear...
My Sony KF50WE610 50" Grand
You just need to replace the lamp, put the model number in a search engine and chose the best priced one for you
Jun 12, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
Sony kf50we610 turns off after 2 minutes and will come back on in 2 minutes .the green lite blinks 3 times when tv is turning on but when on it is solid
The blinking light is a code for a problem. Check your user guide for the code for 3 blinks. It may tell you that your lamp needs to be replaced.
Dec 29, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Sony KV-32FS16, heard a pop then the screen turned green. What do you think?
Hello famous2,
I believe that pop was a capacitor venting. If you open the set you will see either a completely blown capacitor or it will be bloated and or puffy in appearance. Check the signal board or the power supply board for this vented capacitor. it will have to be de-soldered and replaced.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jul 11, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Power green light will flash then flash red when first turned on
Please intimate exact model of your Sony TV to find out reason of no power up.
Jul 09, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Sony TV Screen
Is you model listed below?
Sony wega blue dot or star pattern on screen
http://esupport.sony.com/perl/news-item.pl?news_id=206&mdl=KDF42WE655
Models: KDF-42WE655, KDF-50WE655, KDF-55WF655, KDF-60WF655, KDF-55XS955, KDF-60XS955, KF-42WE620, and KF-50WE620
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Green Screen?
Intermittently displays bright red/green/blue raster then shuts down with led flashing 2, 4 or 5 times
Amazingly this was due to the CRT being faulty !
Red or Green or Blue screen
Check and replace on crt module : D702, D703, D704 (all 1N4148) replace with type 1N4948T
Nov 24, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
44 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
