Question about HP PSC 1610 All-In-One InkJet Printer
1610v All in one error with ! Remove and check color cartridge
Looked this error up and cleaned the cartridge. It's practically new, I cleaned the areas instructed to clean and the error message continues.
  • pearcepav Dec 22, 2007
    Error saying remove and check cartridge keeps appearing even though I printed with it yesterday.
  • kjjb Jan 12, 2009
    I have the error message on the HP PSC 1610 all in one: "remove and check colour cartridge." The patch from HP does not work, I get another error message on my laptop saying there is no eligible device to update. HP shows this error message on their help page here:http://h10025.www1.hp.com/ewfrf/wc/softw...
    but offers no real solution. Is this really the scam to make you buy their new cartridges rather than refill yours? I've heard this on other help sites, might buy a new 'official' cartridge tomorrow to see; either way, I'm never buying HP again. Their tech support has been next to useless.
  • 4 Answers
Hi, I had the same problem. I extracted both cartridges (colour and black), I cleaned both with alcohol and q-tips, I also cleaned in the same way the golden conections of the machine. Reinstalled and works (solved in only 5 minutes).
Important: This problem appeared when I was using the copy function in black and white, not in colour. Thats why I decided to clean BOTH cartridges (the colour one was very clean and black cartridge was the really dirty one).
Don´t ask me why, but it worked. Try cleaning both cartridges.
Hope it would be useful and I appologyze for my english (is not as good as I would like)
Bye
Posted on Jun 01, 2008
    Sergeant:
  • 263 Answers
The error about clean the cartridges is refer to do that not manually is with the system so you can go to printer then right click on printer then select properties then services and clean and aligne heads
Posted on Jan 05, 2008
My color cartridge has been filled and placed back into the printer and the light is still flashing with "remove and check the color cartridge" I have followed all steps to clean and re-install...
You need to bypass the out of ink message. If you have a parallel port, you can turn off the "bidirectional support" in the printer section of the control panel
Or you screwed yourself by waiting too long
The ink acts as a coolant for the cartridge. If you waited too long to fill it and burned it up, you will destroy the TSR (thermal sense resistor) and the cartridge is toast.
Jan 27, 2011 | HP PSC 1610v All-in-One Printer
Message to remove and check color cartridge. When I do it states that the cartridge is missing. Once replaced ... it provides the same message to remove and check.
This occurs when your cartridge develops incompatibility. The permanent solution is to replace the cartridge.  However you may want to clean (with tissue soaked in methylated spirit) the electronic panel of the cartridge to see if this resolves the issue. The electronic panel is the panel with copper dots that makes contact with the cartridge holder.
Apr 26, 2010 | HP PSC 1610v All-in-One Printer
My HP PSC 1610v keeps saying "Remove and check color cartridge".
Check to see if the installed cartridge is the correct one for the printer. If the cartridge is the proper part number, remove the ink cartridge and make sure all the packaging tape has been removed from the copper circuitry strip on the backside of the cartridge. Reinsert the cartridge and try printing again.
If the error continues, remove the cartridge again and clean the copper circuitry strip on the backside of the cartridge, and the contacts inside the printer, by following the instructions below:
1. Use a clean, dry, soft, lint-free cloth. Locate the copper-colored circuitry strip on the back of the cartridge.
2. Wipe the copper-colored strip with the dry cloth. Use an upward motion, from the nozzle end to the top of the cartridge. Do not wipe the nozzle end of the cartridge or touch the nozzle plate. Wipe the contacts only once.
3. To clean the printer contacts, carefully look for fibers or contamination on the electrical contacts inside the carriage assembly, but do not wipe the printer contacts with any object. The contacts in the printer can be damaged if too much pressure is applied during a wiping process. Try to remove any visible attached debris within the carriage assembly by gently pulling the debris off with your fingers. If the carriage contacts show noticeable damage, contact the Customer Care Center listed in the printer's User's Guide.
Reinsert the cartridge and try printing again. If the error continues, the cartridge may need to be replaced.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Apr 01, 2010 | HP PSC 1610 All-In-One InkJet Printer
My HP PSC 1610v keeps saying 'remove and realign color cartridge' even tho I've put in a new cartridge.
Is it a genuine HP?
If yes then there is a fault with the actual cartridge. Check you have removed the tape from the ink outlet if its still on it will cause theis error. If all appears right, try another GENUINE cartridge and claim the faulty one
Please rate my help++++Thanks for using FIXYA
Mar 24, 2010 | HP PSC 1610 All-In-One InkJet Printer
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    Hp psc 1610 alignment error
    replace the colour cartridge aLSO AS IT NEEDS some specific colour to start this allignment and to complete but the colour is not getting printed so this error.
    remove the cartridges from the printer.unplug the printer for some time.then again ON it and insert the cartridges and try .
    sometimes it helps.
    Jun 02, 2008 | HP PSC 1610v All-in-One Printer
    HP 1610v all in one printer
    Bye
    May 26, 2008 | HP PSC 1610v All-in-One Printer
    My HP PSC 1610V All-in-One
    hi,
    it is not possible to print without a color cartridge even if you are trying to print in black and white.
    so i suggest u to replace the color cartridge with a new one and check
    thanks and regards
    agnel
    Mar 12, 2008 | HP PSC 1610 All-In-One InkJet Printer
    Problem with ink cartridge
    There is something broke with the piece that keeps it in place. You need to take it out and look real close to how it works. Look at how the color works and compare the two.
    Sep 23, 2006 | HP PSC 1610v All-in-One Printer
    HP PSC 1610 All-In-One InkJet Printer Logo
    270 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
