My toshiba laptop Satellite L25-S1194 wont connect to the internet, but the other computers in my house will so it's not the router..
  • luuuunatic
    luuuunatic May 11, 2010
    Wireless or wired? Do you have that particular type of network card installed? If you are using wireless, is your wireless card turned on? If it is, does your computer detect the router, but cannot connect? or does it not detect at all?
    President:
  • 1,564 Answers
You probably have to configure your wireless settings as to allow Windows to configure wireless settings and parameters" This can all be found in your control panel. Thanks, Dana
Posted on Sep 30, 2009
I have a toshiba lap top that when it connects to inter net wont hold and now I can't get sign in page
It seems like you intetnet explorer has crash down due to many reasons it cant be corrected eaisly so I suggeyt you to use another browser like chrome or mozilla
Feb 23, 2015 | Toshiba Satellite L25-s1192 / L25-s1193 /...
Toshiba satellite l25-s119 internet won't work.
Wired or Wireless? Try a Ethernet Cable to verify the ISP is sending a signal. Try another broswer.
May 04, 2013 | Computers & Internet
Wher i can download L25-s1194 vga driver for toshiba
http://download.cnet.com/vga-driver-ati-8/3000-18492_4-197341.html
http://download.cnet.com/1t2xw26-exe/3000-2122_4-120557.html
if these packages are not the right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
you might have to try a few times to get it right
hope it helps you
Apr 19, 2012 | Toshiba Satellite L25-s1192 / L25-s1193 /...
I want install l25-s1194 vga driver for toshiba
Click start control panel administration tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red X right click select reinstall drivers
http://download.cnet.com/acjxw01-exe/3000-2108_4-120624.html
hope it helps you
My toshiba laptop Satellite L25-S1194 wont connect to the internet. other laptops is able to connect.When viewing wireless network settings, I can see the laptop is receiving the signal, but unable to...
Is this the first time you are trying to connect to your Internet with that Toshiba laptop?
If that is your first time you need to call first your Internet Service Provider and check what can they do for you.
If there is no problem with you Internet Service Provider, try to press the FN+F8 keys these are the toggle keys to enable or disable your Wifi.
When you press those two keys observe the laptop if you will have a message that says Wireless Connection is On or Off. If it is off, try to press those two keys again to turn on the laptop.
I believe your laptop came with a Wireless On/Off switch, check that also if it is on there will be a light indicator for the Wireless Connection. It should be a steady light.
Now, if the wireless connection of your laptop is on and still you can't connect to your wireless connection, try to update the drivers for your Network Adapter.
Here's the link for the latest driver:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=1124513&rpn=PSL2XU&modelFilter=L25-S1194&selCategory=3&selFamily=1073768663
You need to search for your operating system and choose the Wi-fi on all categories.
You need to save it first on the laptop and after that you will have an option to run it on the laptop. After the installation of new driver try to restart the laptop and try to connect to your Internet.
If that will not work.
You need to contact Toshiba technical support at
Toshiba Technical Support
800-247-7777
Hope this helps. :-)
Mar 03, 2010 | Toshiba Satellite L25-S119 Notebook
WHAT IS THE IP ADD FOR SATELLITE L25-S119, MODEL PSL2XU-00J00D
go to internet connection, right click on lan and select properties and go to tcp/ip and restore to default (automatic)
Dec 30, 2009 | Toshiba Satellite L25-S119 Notebook
Toshiba satellite L25-s1194 wont boot windows
Is it giving you any error or out of the ordinary "beeping" as it is booting?
Usually the BIOS screen comes up if it cannot find an acceptable boot device.
Can you boot from an XP cd?
Can you boot into set up mode.. usually by pressing F1 or F2 on most computers. It should tell you just before the BIOS screen comes up. Enter into "set up" and make sure your boot order is correct.
You might want to reseat your RAM.
Check to see if the hard drive is coming on.
Nov 21, 2009 | Computers & Internet
Toshiba Satellite L25-S1194 attached to TV monitor can't get display on laptop at same time HELP!!
Connect your TV to the computer with an S-Video cable. Turn the TV on and choose the AV option (of your TV) to S-Video. It will tell you that there is no signal on the TV.Press the Fn key on the keyboard. While keeping that key pressed, press the F5 key. A small rectangle appears on the screen showing different connection possibilities (LCD, LCD +TV, LCD+CRT, TV only, CRT only). You can cycle through the options by pressing F5 repeatedly. You select the output option (TV + LCD).Release the keys . You will then have your two screens.
Note: I assumed you connect the TV through the S-Video. If your TV can be used as a monitor (it has a VGA adaptor), then with the F5 key select option LCD and CRT
Hope it helps
Aug 28, 2009 | Toshiba Computers & Internet
Free volume drevers for toshiba L25-S1194
http://www.realtek.com.tw/DOWNLOADS/downloadsCheck.aspx?Langid=1&PNid=14&PFid=24&Level=4&Conn=3&DownTypeID=3&GetDown=false
install and everything should work
Jun 19, 2009 | Audio Players & Recorders
I have a toshiba satellite laptop model L25 I have a ativa router. problem is as long as i am near the router my internet connection works but if i go elsewhere in my house the internect connection don't...
Ok. Let me explain something: Not all wireless connections are equal, there are different technologies underneath the routers. It is listed as C, G, and N. Being the C the older and more limited of the trio. C has a span of about 100 feet WITHOUT walls. G has medium range, and N has a 500 feet range,and can pass through walls. You can mix and match between the three with mixed results. Let us assume your router is G, and your laptop card is C; then your laptop is limited on "calling home" to the router. Try to match your laptop card with the router, or you can even go further and go for the N card, so it can "phone home" to the router at a larger distance.
May 07, 2009 | Toshiba Satellite L25-S119 Notebook
Computers & Internet Logo
217 people viewed this question
David Payne
David Payne
