Question about Wagner Power Products 0154842 Medium Spray Gun Filter, 50 Mesh
I have 2 Wagner power painters, neither work at the moment? They do not pick up paint...No Spray? I've cleaned up nice all seems to be clean and clear? Motor works, but no spray??? Wagner 6.6 GHH Wide Shot and a 1800 PSI Power Painter (2 speed) Any help would be appreciated. Gary
  • Anonymous Mar 16, 2014
    1800 2 speed
    Need assembly instructions for Wagner 1800 2 speed
  • 8,197 Answers
I have had that happen to me you need to rebuild the diaphragm to **** up the paint.
Good luck
Posted on Sep 30, 2009
The piston is the problem they ware out or brake,amazon has them for 14.00
Posted on Feb 10, 2012
Does a Wagner Paint Crew sprayer take lubricant?
The Wagner Paint Crew airless sprayer does not require oil for its operation like full professional sprayers. The piston is off-set from the pump chamber with the inlet and outlet valves opposite each other, however you need to protect the parts from corrosion between use and Wagner recommend running some light oil through it after cleaning. If you will be using it in a day or so for water based paint, you could run a 10% solution of their EasyGlide through it.
Sep 30, 2014 | Wagner Spray Tech Wagner Paint Crew 2750...
Spray gun problems
did the canister tube fall out? dump the paint out into a saveable container and put straight (enamel reducer) in it and try to clean/clear the unit..adjust the knob on the back of the spray gun it controls the paint flow..
Aug 03, 2014 | Wagner Air Tools & Compressors
How can I fix a electrical spray gun that does not spray but makes noise like its going to spray.
R D, I think the spray nozzle is blocked with previous paint job. I would try soaking it in paint solvent for a few hours to see if it helps. Use the cleaning brush to clean as much as you can all the channels where you see paint. good luck.
May 20, 2014 | Wagner Spray Tech Model 242 Electric...
Why does my gun keep spitting
Spitting is usually caused by not filtering the paint through a strainer (made for the purpose by the paint manufacturer). The paint debris blocks the paint for just a moment, then spits it out. Easy fix!
Jun 09, 2010 | Wagner GX10 Airless Spray Gun
Wagner power painter 325 not spraying right-comes out in clumps and spatters even when trying with water
You should be able to adjust the spray pattern to clear this up. You may also give it a good cleaning with mineral spirits as well as making sure that the paint is thinned enough
Mar 12, 2010 | Wagner Power Products 0154842 Medium Spray...
Wagner power painter spray tip clogged.
strip a peice of wire from a normal wire the use it to clean tip with some thinners
Dec 30, 2009 | Air Tools & Compressors
Not enough compression to spray thompson water
Maybe just plugged. If it has the nozzle that can be rotated 180 degrees, roll it and try to spray. Sometimes a bit of debris gets in there and stops it up. If no on the rotatable nozzle, take the tip off and try to push liquid back to the container, or a waste bucket, to clear the line. You also may need to clean the tip. One last item.....since you sprayed water.....if you chased the water with the TWS, you may have made an emulsion. If so, remove the spray gun, and turn on the pump, pumping into a waste container, until the emulsion is displaced. Clean the gun. I'd say that if it'll spray water, TWS would be even easier.
Regards, --W/D--
Aug 03, 2009 | Wagner Air Tools & Compressors
Wagner Paint crew - No pressure
In order of likelyhood:
1. There is an inlet valve where the paint first enters from the hopper. With the machine off, you can poke your finger all the way down the hole. It's spring loaded and will depress abouta quarter inch. If the inlet valve is stuck no paint will pump in PRIME or SPRAY position.
2. In SPRAY position. Motor runs for a few seconds then turns off. This means the pump is working. When you pull the trigger, if you get poor pressure, the problem is in the gun. Unscrew the handle and remove the filter. Clean out everything you can, and replace filter if necessary. Also try turning the spray nozzle 180 degrees and spray to clear if necessary.
there are more things that can go wrong, but these are the most likely.
Jul 08, 2009 | Air Tools & Compressors
Wagner Power Products 0154842 Medium Spray Gun Filter, 50 Mesh  Logo
2,522 people viewed this question
Top Wagner Air Tools & Compressors Experts
JOHN LAPIER
ray gallant
 Andy
Andy
Level 1 Expert
Are you a Wagner Air Tool and Compressor Expert? Answer questions, earn points and help others
