Question about TT Systems 4900 900MHz Phone (IBM-4900)
I have 3 IBM 4900 in the system
We used 1 4900 for a long time, we are now trying to use 3 and calls get put on hold in the middle of a conversation.
  • J Bob Dec 20, 2007
    are you suggesting that the electricity in the phone line, line 1,2,3,4 are creating the problem or is it the electricity to run the phone from the ac adapter is the problem or could it be old batteries that do not hold enough charge?
  • 152 Answers
Well... since phones work on electricity too, (of course, powered from other lines) there is a huge possibility, from what i understand, that those 3 phones are connected from the same place where the phone line comes..
this means the 3 phones at the same time are consuming way too much electricity to maintain a conversation..
the way to fix it is getting the phone line from another source (of course, coming from your own house, but what i mean is a different box).
anyways.. try with 2 phones and see what happens... other than that, the best fix is getting more sources to connect the phone
Posted on Dec 19, 2007
  • Asdrubal Perez Dec 20, 2007
    i am pretty sure it must be the phone line, are you using somthing similar to this to feed your phones?
    here is a better picture in case the link doesnt work
Im trying to figure out how to inflate the trek 4900 tire, its not your normal valve stem and i havent found anyone that know please help me?
Where did you look? Search for "inflate bicycle tire" or "inflate presta valve".
Search engines work for most common questions - immediately.
Aug 04, 2011 | Trek 4900
Here are the instructions for making a conference call on a Norstar system....
Conference [Feature] [3]
  • Establish a conference call between yourself and two other parties.
1. Make or answer the first call.
2. Put the first call on hold.
3. Make or answer the second call.
4. After the second call is connected, press [Feature] [3].
5. Press the line or intercom button of the first held call.
6. Press [Rls] to end the conference call
  • To remove yourself from a conference permanently (unsupervised conference):
    • Press [Feature] [7] [0]. The other two callers remain connected. (Some external lines may not support this feature.)
  • To put a conference on hold:
    • Press [Hold]. The other two callers can still talk to each other.
  • To split a conference:
    • Press the line or intercom button of one caller to consult privately while the other caller is on hold. To re-establish the conference, press [Feature] [3].
  • To disconnect one party:
    • Press the line or intercom button of the caller you want to disconnect, then press [Rls].
    • Press the line or intercom button of the remaining caller to resume your conversation.
  • To independently hold two calls:
    • Press the line or intercom button of the first caller, then press [Hold]. The second caller is automatically put on hold. To re-establish the conference, retrieve one call from hold, press [Feature] [3], then retrieve the second call from hold.
on Mar 21, 2009 | NorStar CallPilot 100
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.ArgumentOutOfRangeException: Cannot anchor...
Not sure whether this is a Q.
To enable just in time (JIT) debugging, the config file for this application or machine (machine.config) must have the jitDebugging value set in the section. The application must also be compiled with debugging enabled. For example: <configuration> < jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the machine rather than being handled by this dialog.
In VS the way to enable/disable that is: 1-On the "TOOLS" menu, click Options. 2-In the Options dialog box, select the Debugging folder. 3-In the Debugging folder, select the Just-In-Time page. 4-In the Enable Just-In-Time debugging of these types of code box, select or clear the relevant program types: Managed, Native, or Script. To disable Just-In-Time debugging, once it has been enabled, you must be running with Administrator privileges. Enabling Just-In-Time debugging sets a registry key, and Administrator privileges are required to change that key. 5-Click OK.
It has to be done by the developer and its his responsible to guide the application error reporting to the system event handlers. If this is an issue which occurs in a certain app, have to check for the .net version (specially in vista). Many 1.0 and 1.1 based apps give the problem. To install dotnet fw 1.1 on Vista will give an error. Most of the time caused by DEP (Data Execution Prevention). But the thing is some software forces the installation of .net framework (older versions). How ever Vista is packed with .net 3.0 and 2.0. Even if you allowed to install will not be able to uninstall 2.0 (possible to remove 3.0 though).
How to solve the installation issue: This issue is resolved in Microsoft .NET Framework 1.1 SP1, however you will need to use the following procedure to install both the .NET Framework and the Service Pack at the same time: Download Microsoft .NET Framework 1.1 Redistributable Package and Microsoft .NET Framework 1.1 Service Pack 1 using links below: Dotnet Framework 1.1 Redest Dotnet Framework 1.1 SP1
Save both installations in the same directory Ensure that the Microsoft .NET Framework 1.1 Redistributable Package is named dotnetfx.exe. If not, change its name to dotnetfx.exe. Ensure that Microsoft .NET Framework 1.1 Service Pack 1 is named dotnetfxsp1.exe. If not, change its name to dotnetfxsp1.exe. Open command prompt as Administrator, and change to the directory where the two installations are saved. Run the following commands using the order shown below dotnetfx.exe /c:"msiexec.exe /a netfx.msi TARGETDIR=C:dotnet" dotnetfxsp1.exe /Xp:C:dotnet etfxsp.msp msiexec.exe /a c:dotnet etfx.msi /p c:dotnet etfxsp.msp Install both Microsoft .Net Framework 1.1 and Service Pack 1 by running C:dotnet etfx.msi
The systems must be backed up before trying this specially the system state. How ever the keys can be repaid in a damage This thread will also be helpful
May 29, 2010 | Dell Studio XPS 16 Notebook
Handset buttons are worn out. Are there replacement handsets?
Of course there replacement.Check the manual of your phone get the adress of the company and call the customer care they will tell you where to get the accessories
Nov 11, 2009 | IBM 4900 4-Line Cordless Phone
How to transfer calls between extensions
You have the ability to transfer an outside call to any extension within your phone system.
1. Press the [TRNSFR] button during your conversation
2. Dial the desired extension or press one of the Direct Station Select (DSS) buttons
3. One ring will be audible a transfer is successful. Otherwise, two rings will be heard
4. Any extension can pick call transfer
5. The Call Transfer mode will automatically cancel after 10 seconds if no transfer number is dialed
Sep 24, 2009 | IBM Corded Phone IBM412CID
Phone is 'searching' and not working. This a phone I bought last week, the batteries were charged for 24 hours
The phone is maybe too far from the base. You can also try to use the find button on the base to «call» the phone the first time so it can find it. There is also a another way for the base to find the phone and it should be indicated in your manual. I know we had this problem with ours and we had the procedure in our manual but I suppose it is not the same for all the phones. Also... make sure the phone line is connected to the base... ;)
Good Luck.
Aug 19, 2009 | IBM 4900 4-Line Cordless Phone
How do I put second call on hold while finishing first conversat
Jul 10, 2009 | Uniden DXI8560-2 Twin - - Phone
How do I send a text message with a sanyo scp 4900 phone
You may need to call your provider and make sure that this feature is in your price plan..and they can tell you how to send a message on your particualr model. Press *2 for customer care or dial 1-800-639-6111. Hope this helps ya!
May 22, 2009 | Sanyo SCP-4900 Cellular Phone
4900 phone problems
Probably need new battery, you can get one here - IBM 4900 Cordless battery
Oct 02, 2007 | IBM 4900 4-Line Cordless Phone
Uniden DECT 6.0 cordless phones
Here are some steps that should help. I don't think that you can Conference call You can hold a 3-way conversation (conference call) between your handset, an external caller and another internal handset user. During an external call: 1 Press . The external caller is put ?on-hold?. 2 Press or to select name, number or the handset you want to have a conference call with and press or key. The called handset will ring. 3 When the called handset answers, press to start your conference call. 4 Any handset can press at any time to leave the conference call. It looks like you can use the multiple system sets together, but the system is not designed to do what you are asking for. Please repost with any other comments or questions. Please rate this solution through fix-it. Thank you.
Jun 30, 2007 | Uniden DECT1080-2 Phone
TT Systems 4900 900MHz Phone (IBM-4900) Logo
Top TT Systems Lands Phones Experts
Are you a TT Systems Lands Phone Expert? Answer questions, earn points and help others
