Question about Magic Chef CMV1000B Microwave Oven
Turntable, lights and fan inop
Replaced the bulbs under the unit and when I turned the lights on there was a flash and now the turntable, lights and cooling fan do not work. I checked the fuse and it is good, possibly a relay?
  • 1 more comment
  • Tkcc Dec 20, 2007
    No sir, the microwave still heats, but without the fan will cut itself of when it gets hot. You are right that I do have to check the sockets because they were hard to get out and there could have been some debris in there, but now when I push the light button, the display shows it on, but it isn't. I know that the turntable, lights and fan are on the same circuit, but I am assuming there is no power there or it would short out when I go to turn the lights on again. Thank you for your time.
  • Tkcc Feb 14, 2008
    Mark2424, your solution was dead on. Only difference was my board had 3 traces burnt. Got some solid copper telephone wire and saved $217, which is what a new control board costs. Many thanks!
  • Anonymous Feb 17, 2008
    Hey mark2424 and Tkcc.
    Thanks to both of you. I had the same problem. My Magic Chef, MCO153UBF Microwave had similar problems. The Magnatron, Cooling fan, Turn table and under hood lights were not working at all after hearing a pop sound under the control panel. Thought it was the fuse but the fuse was fine after testing and replacing. I checked the circuit breaker wired to my house and saw it had a break to my kitchen outlets so i flipped the switch to get back the kitchen outlets. Then I checked the microwaves Control Panel ( Printed Circuit Board) underneath and saw to traces were burnt. I soldered the two trace lines and the fixed the problem. Thanks a HUGE bunch.
Mine 3 traces blew on the main board. Model MCO160UW
Repaired with solder and wire
Posted on Jun 21, 2008
I have the same problem
no turntable no inside light no cooling fan or range lights
i removed range bulbs and they look blowen i have not yet replaced
the unit still heats
i can only find one fuse
i was told there was a pop before it stoped working
thanks for any advice
Posted on Feb 11, 2008
  • mark2424 Feb 12, 2008
    ok i posted my problem in wrong box but i solved it.
    i must of had a power surge
    i removed the main board and found two traces were burnt
    i used telephone wire and soldered jumpers across the two traces
    lights colling fan and turn table now work
    good luck
    mark
  • 833 Answers
I'm guessing that nothing is working...is that right? If so, first guess is the breaker or an internal fuse. Nearly all units have them. You don't say what fuse you checked. Unplug the unit, remove the bulb and see what is in the socket. Next, open the breaker and then turn it back on. This will reset it. Something caused this.
Posted on Dec 19, 2007
  • Robert Hirst Dec 20, 2007
    I'm still thinking internal fuse or thermo sensor. Fuses sometimes look like rectangles about 3/8 inch on a side and an inch or so long. On the circuit board, they say something like '10A'. The thermosensor is located on the oven wall, is black, the diameter of a dime and 3/8 inch thick with two wires on it. Check all for continuity. All of this is located behind the key panel. If you have a circuit diagram (many are inside the unit) have a look for clues as to what works and what doesn't. Use a tester from the hardware store to check everything...power off!
2 Suggested Answers
IB4G2008
  • 3587 Answers
SOURCE: Turntable, lights and fan inop
sounds like a cross wire, and a short. I'd inspect the socket for the bulbs to ensure that there's no short circuit.
Turntable turns intermittently so unit will not operate
The turntable fan and light all share the same feed, first check wiring for loose connections the problem though is most likely with the controller
Dec 28, 2009 | Viking DMOC205SS Microwave Oven
Feb 11, 2008 | Magic Chef CMV1000B Microwave Oven
Panasonic Microwave NN-S935BF turntable and light do not work. Microwave still works. Bulb and turntable motor okay. No power to light or turntable. Any ideas?
Your description seems to be confusing turntable and light do not work
Bulb and motor OK
Which is it?
They could be separate incidents. The drive motor could be fused and the globe just blew its life away..
Aug 15, 2009 | Microwave Ovens
Ewave OTR Microwave Oven, Model KOT-153UW. Light
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or no bright, too. Sometimes this will similarly affect the exhaust fan operation or inside light, too.Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jul 13, 2009 | Daewoo Microwave Ovens
Turntable will not turn and under unit lighting will not work
Possibilities are:
There is a harness that is no longer connected(possibly loosened when the fuse was replaced)
There are bad relays on the control board
The touch panal is not giving the command to the Control board
Jun 08, 2009 | Magic Chef CMV1000B Microwave Oven
Bulb & turntable
Yes the microwave is safe to use, without the turntable working.
May 03, 2009 | Microwave Ovens
Light, turntable and fan don't work
Possibly the light bulb has blown, which has blown on a track on the board which has taken out the turntable motor and the fan. Also, there could be a problem with the door switch.
Mar 27, 2009 | Panasonic Microwave Ovens
Unit makes a loud buzzing sound whenever the unit has power.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
Nov 23, 2008 | GE JVM1860 Microwave Oven
GE JVM1450WA01; Lights do not work, -- both blown and replaced.
We see this a lot. The problem is almost certainly on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This often can affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on.
Details: If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 13, 2007 | Microwave Ovens
Magic Chef Over-Range Microwave Oven Model:MCO153UBF
The turn table and fan are connected in series with the bulb,as you have mentioned that you have replaced bulb,so please check again for any loose contact on bulb holder or bulb continuity again.
Aug 03, 2007 | Magic Chef CMV1000B Microwave Oven
Magic Chef CMV1000B Microwave Oven Logo
320 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
