Question about Kenmore 98702 Stacked Washer/Dryer
Water does not stop entering. - Kenmore 98702 Stacked Washer/Dryer
  • 71 Answers
It needs a watervalve...you can get it at any local appliance shop if you take in your model number
Posted on Sep 30, 2009
Water entering Dispensor and will not stop
check the water in celanoid may not be closing if not check pressure pipe from the drum to air switch
Mar 01, 2014 | LG WM2050C Front Load Washer
Washer stops between wash and rinse, and stays full of water. ld code
see this steps and fix it. God bless you
Lid Switch Assembly
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Enter your model number to see parts for your washing machine.
Help me find my model number
Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Jul 21, 2013 | Kenmore Washing Machines
The washer work but stop along the way,ie unable to complete the circle
Lid Switch Assembly
Water Inlet Valve
Main Control Board
Timer
Jul 13, 2013 | Washing Machines
Skipping wash cycle
follow this steps and fix it. God bless you
Lid Switch Assembly
Water Inlet Valve
Main Control Board
Timer
Jul 13, 2013 | Admiral 3.4 cu. ft. Top Load Washer in...
Affinity stops in the middle of a cycle a just shuts off no signal or anything?
use the following steps. God bless you
Lid Switch Assembly
Water Inlet Valve
Main Control Board
Timer
May 23, 2013 | Frigidaire ATF6000ES Front Load Washer
Washer heavy duty cycle issue
Lid Switch Assembly
Water Inlet Valve
Main Control Board
Timer
God bless youcb4af627-0171-42f5-ad0a-5f8e85e72ae0.gif6634bf88-8eca-4d0f-b59c-0e8829e5d59d.gif419f93c3-fea0-4d93-af85-2e59d98d88e0.gif
May 23, 2013 | Whirlpool AWG320 Front Load Washer / Dryer
What`s the function of starboard outlet spout ?
The water squirter out the side is there to show you that there is cooling water going through the engine. If the outlet spout stops shooting water out the side you need to stop the engine and investigate. I have had mine stop shooting water. I stopped the boat and blew air through the hole backwards to clear the tube. One time I had to pull the hose off the motor(where the squirting water enters a hose to the outlet spout) and push a piece of wire into the engine outlet hole to clear it. Fortunately , the motor was never in any danger of overheating only the wizzer hole was blocked , water was still cooling the motor. Again if the outlet spout stops shooting water turn off the motor and make sure water is entering and cooling the motor.
Sep 20, 2010 | Yamaha 12V Air Pump
Whirlpool AWG 354: Water flowing can not stop
Thet happens because either the water level switch/membrane switch is faulty, or because the water inlet valve is defective and stuck on open. See also : It's overfilling
Dec 19, 2008 | Washing Machines
Water won't stop entering the dishwasher
SOUNDS LIKE YOUR WATER INLET VALVE HAS FAILED,,REMOVE BOTTOM PANEL AND REPLACE,MIKE
Sep 13, 2008 | Frigidaire 24 in. FDBB840DC Stainless...
Kenmore 98702 Stacked Washer/Dryer Logo
Sal DeAngelo
fordexpert
Ed Mac
