Question about Kenmore 98702 Stacked Washer/Dryer
Water slowley pours out of the upper part of the washer into the tub area even when the machine is off. What can this be?
  • 71 Answers
It has a bad watervalve....you can pick that up at any local appliance shop if you just take them in your model number.
Posted on Sep 30, 2009
Water was pouring out the front of my machine. It was turned off and empty!
If you have hard water in your area, the valve could be stuck in the open position. Try running an empty cycle and see if it stops filling. Either way, you may want to follow manufacturers' instructions for de-liming. If this fails, the valve/solonoid may need to be replaced.
Best of luck.
Oct 09, 2014 | Maytag EPICz 3.7 cu. ft. Washer
Water leaks into washer tank slowley
If you mean that the tub fills slowly, check that your supply faucet is fully open, Check if there is a screen in the supply line, these can become blocked due to scale deposits from the mains. If there is no screen check that the inlet solenoid valve has not got blocked.
Apr 13, 2011 | LG WM2487H Front Load Washer
70 Series Kenmore washer pouring water underneath washer.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Check the areas for the motor and pump and the Agitator Basket and Tub .
If you've checked the hoses to and from the pump the problem points to either the pump itself or to the Centerpost gasket.
Neither of these is too difficult to replace, the Gasket requires removing most parts of the washer although the pump is an easy replacement.
Sep 24, 2009 | Kenmore 24032\24036 Top Load Washer
WHEN I TURN WASHER ON WATER STARTS POURING OUT OF THE BOTTOM OF THE MACHINE AND ONTO THE FLOOR. WATER IS COMING FROM THE BOTTOM LEFT SIDE.
The drum seal is bad. The seal allows the center to come up through the tub and the tub to rotate around it, It usually has a rubber membrane that flexes so the tub can rock around. The rubber tears and the water runs right out. If you can, disassemble the washer and change the seal, otherwise the washer is toast. Sorry! You can verify this by pouring water in from a bucket. If this water doesn't run through then it is the hose from the fill valve to the water outlet under the lid.
Jun 08, 2009 | Washing Machines
Front load washer pouring water from detergent drawer
w would immagine that if you have water pouring out from your dispensor that something has found its way down into the the dispensor hose leading to the tub and is bl;ocking free passage of wwater. you can remove the top off the machine and check the dispensor to tub hose for possible debris/ sock/washcloth. ive even seen the pull tab from the top of the detergnet bottles in there
Feb 23, 2009 | Kenmore 46462 Front Load Washer
Whirlpool Duet GHW9100L pours water out of the soap dispenser dra
probable cause is there is an article of clothing that is stuck between the outer and inner tubs, in the area where the dispenser water and detergent enter the machine. you can run your hand around the rubber boot and you might be able to remove the article, it will be in the upper left part of the machine. if nothing can be found than you have a plugged up dispenser hose.
Jan 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water overflow on washer
  1. some how you have caused the pressure switch hose too come off.it is a clear vinyl tube in the upper timer console area.it is very common for it to come off.it is the water level selector switch/knob,behind is where the tube goes
Jan 24, 2009 | Kenmore 24032\24036 Top Load Washer
Maytag Washer overflowwing
I had the same problem. My whole basement flooded. Inside the back (you can see it thru a small hole 1/2 way up on right) a small white hose connects to the water shut off collection area. This hose carries the water from the tub to the collection area and tells the machine to cut off for the size of load selected. Mine had come undone and so the machine could not sense it was full and the water poured all out the bottom. I simply removed the small gray panel at the bottom on the back and reached up inside to reconnect.
Jan 26, 2008 | Maytag Performa PAV2200
Kenmore 98702 Stacked Washer/Dryer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
