Question about Samsung Smooth SCH-u350 Cell Phone
How do i set my alarm clock as a shortcut? and from there, how do i actually use the shortcut?
  • 45 Answers
Menu>settings & tools>6.Phone settings>2.Set Shortcuts>Set My Shortcuts>Select shortcut to change 1 thru 4>Select Alarm Clock DONE!
To Access press the right side of the directional key and there are your 4 shortcuts!
Posted on Oct 02, 2009
Testimonial: "works perfectly, thanks!"
How do I set the time on a KADIO KD-3806 digital clock
Earlier FIXYA question:
sachin_arane
ALL PARAMETERS CAN BE ADJUSTED BY USING KEYS
GIVEN BACKSIDE...KEYS ARE
MODE (LONG PRESS-4 SEC) TO ENTER INTO SETTINGS;
UP/DOWN TO CHANGE THE PARAMETERS; \
*C/*F KEY TO TOGGLE BETWEEN TO TEMPERATURE FORMAT;
SNOOZE BUTTON TO SET SNOOZE IN ALARM-MULTIPLE SNOOZE CAN BE SET;
RESET KEY CAN BE USED TO RESET CLOCK TO DEFAULT;
DAY COUNTDOWN , AND TIME COUNTDOWN CAN BE ADJUSTED;
DETAILED INFORMATION TO SET THE CLOCK
INSERT CELLS;-SCREEN SHOWS DEFAULT VALUES-INITIAL MUSIC WILL RING;
LONG PRESS MODE BUTTON-KEEP IT PRESSED UNTIL 12 STARTS BLINKING;
USE UP /DOWN BUTTON TO ADJUST HOURS...
THEN SIMPLY PRESS MODE AGAIN, NOW MINUTES 00 IS DEFAULT WILL START BLINKING;
USE UP/DOWN BUTTON TO ADJUST MINUTES;
AGAIN PRESS MODE, SCREEN WILL SHOW YEAR 2002 DEFAULT BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW MONTH BLINKING, USE UP/DOWN KEY TO ADJUST CURRENT MONTH;
AGAIN PRESS MODE, SCREEN WILL SHOW DATE BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW 12:00 BLINKING WITH ALARM SIGN (FOR ALARM SET);USE UP/DOWN KEYS TO SET ALARM, FIRST HOURS AND THEN MINUTES FOR ALARM; THEN ON PRESSING YOU CAN SELECT SNOOZE MINUTES;
AFTER SNOOZE ON PRESSING MODE AGAIN YOU CAN SELECT DAY COUNTDOWN TO SELECT 999 DAYS COUNTDOWN FROM CURRENT DATE;
when watch displays time and everything .....
each and every buttons has some function;(shortcuts)
press down to toggle between 12hr/24hr format;
press up to enter contdown timer;
press snooze to set snooze in alarm;
press c/f to toggle between two temperature formats;
press mode to toggle between alarm time and current time
Mar 18, 2018 | Car Audio & Video
Set time on RCA dual clock radio with fashion wrap? RCR 8622
I love the form of your question, as I wanted to wing the sucker myself, but got online before I actually pulled an Office Space on it. I found nothing, but I DID actually figure it out. Not super intuitive though. To set the time: Hold down the memory key in the middle until the number flashes. Use the arrow up/down on the right to set hour. Press Memory key again, repeat with arrow keys to set minutes. Hit memory key again. Alarm: Press/hold the Alarm button until the Alarm 1 or 2 flashes and press the side you want, 1 or 2, to set. Arrow time up/down, then do minutes, press alarm 1 again, select alarm or tuner, press alarm 1 again. Now I need to see if it will work in the morning. I know the flipping time is set though! Good luck. If you wing it, please post photos! :D
Dec 11, 2014 | RCA Audio Players & Recorders
My alarm is set...but it doesnt go off.
There are 2 common mistakes with radio alarm clocks. 1) You have AM/PM backwards either on the actual time or alarm time 2) The volume is mistakenly set all the way down
Jul 18, 2011 | PHILIPS AJ3915 CD ALARM CLOCK RADIO AMFM...
I cant find an online manual for an audiovox CD alarm clock radio model 1167, and cant figure out how to set the alarm. a link to the actual manual would be great
With the power off, push the alarm 1 button, then push the clock set button. Use the skip & preset buttons to set the hour. Push the clock set button again to change to the minute. Again use the skip & preset buttons to set the minute. Push the clock set button again to set. You will see an alarm clock in the upper left of the screen to show the alarm in now set. To cancel push the alarm button and then the stop/alarm off button.
Mar 09, 2011 | Hardware & Accessories
How to set the clock?!
Assuming your is like my 2001 RX300 you will have a reset adjustment in the center info panel. You should actually have a clock and alarm setting using the two right hand buttons on the lower sill of the info screen. look for the clock icon in the info screen...
Dec 10, 2009 | 1999 Lexus RX 300
I want to change it so there are no key pad tones. also, i'd like my alarm clock to be on the right hand corner of my screen, not the web2go button...
Go to settings on your phone menu and go to sound and change key pad tones to silent or none or volume zero then for the buttons go to shortcuts and on the right soft key change from web to alarm clock! if not then this setting may not be available on your phone.
Nov 11, 2009 | Samsung Gravity SGH-T459 Cell Phone
I have a samsung impression & i can't get the alarm clock picture to get off the screen. What should I do?
tap on the arrow on the left of your screen thats pointing to the right thats your shortcut key, then it'll open your shortcut keys, then drag the alarm clock toward to your shortcut keys or drag it to the left and it will automatically lined up with your shortcut keys. to hide your shortcut keys just tap arrow again (arrow thats point to the left).
Sep 16, 2009 | Samsung SGH-A877 Impression Cell Phone
ALARM CLOCK SETTING
I've manage to set it... press time/awake and the 1 flashes... use arrows to set the time... then press time/awake again for alarm 2.
But how do you know when it is actually set?? it did not go off this morning and i was late for work!
Mar 14, 2009 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
Sony dual alarm am/fm alarm clock radio
HOW does one set the time and alarm on a "sony dream machine clock radio"?
Aug 28, 2008 | Sony Dual-Alarm AM/FM Clock Radio with...
Samsung Smooth SCH-u350 Cell Phone Logo
182 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
