Question about DCM Audio Players & Recorders
Subwoofer blewn fuse
I have a dcm 10" home subwoofer that recently blew the fuse on the back panel. I replaced it with the same exact fuse that I round at radioshack and still no power to the amp??? I read something about an internal fuse that can blow?
djnick989
  • 1067 Answers
SOURCE: DCM SUBWOOFER PROBLEM.
telll sterio use sub out and remix on in settings menu on steiro ok also does it have speaker wires in and out use them off fornts ch from sterio then back up throw sub to fronts set cross over on 100 or so
Posted on Jan 29, 2008
  • 3 Answers
SOURCE: AR1 Subwoofer Keeps Blowing the 5 Amp Fuse
Well, so far so good. I reinstalled the newly repaired amp and fired it up and so far, so good. Ran it through about an hour of fairly intense break-in tracks and then ran it through about 2 dozen power up and down cycles to try to get it to fail (better now than a month from now and have to fight them on backing it up).
Posted on Nov 13, 2008
  • 26 Answers
SOURCE: fuse on subwoofer keeps blowing
Subwoofers draw a tremendous amount of power. With the amount of heat generated by amperage flow and the movement of the voice coil, you may have burned out the coil. Do a resistance check across the coil. Easy check? Temporarily attach another speaker to replace that one. Use LOW VOLUME and slowly work the vol up,and, if the fuse does not blow, it's the other speaker.
Posted on Mar 10, 2009
mikeslab
  • 87 Answers
SOURCE: klh powered subwoofer keeps blowing fuses?
then the circuits took a hit and the fuse didn't do it's job in the 1st place. best is too get new circuit thats inside the sub woofer.
sorry to be the bearer of bad news
Posted on Apr 26, 2009
  • 140 Answers
SOURCE: powered subwoofer keeps blowing its fuse
The amp is blown. You need to get it in for service. No telling exactlly what is wrong untill it is opened. 215-736-8055
Posted on Jan 15, 2010
Where do you change the fuses on there Valvoline DPS 12 subwoofer
The fuse or fuses should be behind the back panel where the wires and cord are.Unscrew the plate and remove. Use the same fuse that came with the unit. It blew for a reason
May 18, 2015 | Audio Players & Recorders
Basslink Fuse Blown
if it has a short some where in the lines it will do that
Feb 25, 2010 | Infinity BASSLINK Car Subwoofer
Polk Audio PSW10 electrical board smoking
I should just replace the parts that were burning, it will cost a lot less.
Jan 15, 2010 | Polk Audio PSW10 Subwoofer
PDR-10 subwoofer has no output. 120vac to unit is
I have exactly the same situation with my PDR-10. Paradigm techs were of no help, don't me to take it to a service centre which i did. Of course when it was there they plugged it in and it stayed on for a day and a half so no problem right? Get it home, nothing, plugged and replugged, got it on once but not for long. Opened up back, everything including fuse looks solid and fine....to naked eye anyhow.
Dec 20, 2009 | Paradigm PDR 10 Speaker
Fuse blows
Both 3 or 4 amp slow blow fuses are suitable replacements for the 3.125 amp subwoofer fuse.
It could be that the subwoofer is blowing the fuse because the one you installed was not slow blow.
But, more likely is the subwoofer has a short in the power supply which is causing the fuse to blow.
May 31, 2009 | JBL PB10 Subwoofer
Fuse blows when powered on . KLH E-10DAW
Hi, you can get the fuse at Polk Audio. 800-377-7655. You can talk to technical, too.
Jan 20, 2009 | KLH Audio Players & Recorders
Jan 29, 2008 | DCM KX-6 Speaker
Subwoofer eating fuses.
Check the circiut board for any blown capacitors. Sometimes it's that simple as replacing a capacitor. But then again, what is causing the capacitor to blow??/ Hope this helps.
Nov 02, 2007 | Audio Players & Recorders
Kenwood Home Theater
Please update your post with any Model Numbers that you can retrieve, especially the subwoofer. Off hand, and with the limited amount of information that you have provided, I would GUESS that your subwoofer is simply overheating, and is being shutdown internally, hence protecting the fuse because no short is detected. If you haven't moved and or vaccuumed/cleaned around or near your system regularly, dust, pollution, pollen...you name it, builds up and can easily prevent electronics from breeathing/venting properly.
Jul 31, 2007 | Kenwood HTB755DV System
355 people viewed this question
Top DCM Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a DCM Audio Player and Recorder Expert? Answer questions, earn points and help others
