Question about Delphi XM SKYFi2 1016211B1 Satellite Radio Receiver
Delphi Shyfi XM radio only picks up certain channels in the car cradle but picks up all of them on the Boombox. Why?
  • Delphi Expert
  • 509 Answers
XM actually uses 2 sets of transmitters on each satellite, so it is possible you need to adjust your antenna to get the rest of the channels in the car cradle.
Posted on May 27, 2010
When my receiver is plugged into my boom box, I get a display reading "check cradle for power"
It's not receiving enough power from the boombox so the voltage drops too low for the receiver to function properly. Check the cradle connector for bent or pressed pins and the power source of the box for proper functioning: measure the voltage it delivers and the status of its components, especially the filtering capacitors.
Jul 04, 2011 | Delphi Roady XT XM Radio Receiver
FM Transmitter does not connect to car radio, have FX signal and Line out works.
Car cradle works "wirelessly" with Car Radio (inherent design of unit). Place Unit in Cradle; connect Cradle to Auto Power Source, and SkyFi3 should power on. Press Menu to Get FM Radio station channels; select a lower station Channel Frequency i.e. 88.3 or any vacant channel number and the signal should transfer to your Radio speakers automatically. You can change Station frequencies as often as you need to do so--for example if traveling through different broadcast areas, some channels frequencies are clearer than others. Good luck.
Jul 19, 2010 | Delphi SKYFi3 XM Radio Receiver
Delphi skyfi2 Xm Radio Receiver car connection
Yes, you can buy an FM Direct adapter that will allow you to transmit directly to your car FM tuner, but if you have an older SkyFi2, the Fm transmitter is so strong, you can sit the radio on the floor and tune your car radio to your preset XM channel, like 107.1 FM and it will work great. Go into "Menu" and pick a channel that's not used locally.
Jul 12, 2010 | Delphi SKYFi2 SA10101 XM Radio Receiver
Broken SkiFi vs New SkiFi 2? Direct Replacement? Please advise-Thanks
The original SkyFi's display was quite difficult to see in the sunlight. The glare was too much. The new unit's display is a different material, and sunken in to alleviate the problem of glare.
The SkyFi2 also has TuneSelect. It was the first receiver to allow the user to enter the artist information for memory. Other units with TuneSelect only allowed song titles.
It also added a 3rd bank of presets, allowing for 30 presets instead of the original's 20 presets. SkyFi2 added the option of a stock ticker, or sports score ticker in the display. The original SkyFi's option of 3 different displays included the channel number only, to be displayed. Also, there is a built in FM modulator so you can set the tune on the reciever... and yes you will be able to use all of your accessories.
Oct 24, 2008 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
Downloading instructions Delphi SKYFi3 unit
You can't download Xm programming, like you can from itunes, where you get a song in 3 or 4 seconds.
Do you mean record music? You must record realtime, either while listening or while the unit is idle in its cradle.
It's easy. while listening to the radio in the cradle (press mode repeatedly to get to Live XM mode), then press the center (play/pause) button.  the menu will pop-up, select Record.  It will give you the option for Song, Channel, and Session.  Just chose one of the first two and press the button.  You should see a microphone appear at the top of the screen.  It's recording.  Follow the same steps to stop the recording.  Setting up a recording session is self-explanatory once you get into that screen.
Oct 21, 2008 | Delphi SKYFi3 XM Radio Receiver
Delphi MyFI
I have the same problem, and only the same few channels are shown on the channel access screen and they all have + signs.
Aug 21, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
Great signal, so sound
My XM Boombox is also white and it is a Belkin. The folks at Delphi told me the receiver in the boombox is screwed up which over time also screws up the Delphi receiver. Belkin is sending me a new boombox and Delphi is sending me a new Roady XT.
Mar 01, 2008 | Delphi Roady XT XM Radio Receiver
Delphi MiFi
xm radio shuts down , then starts back up again with no intervention.
Oct 03, 2007 | Delphi MyFi SA10113 XM Radio Receiver with...
Delphi XM SKYFi2 1016211B1 Satellite Radio Receiver Logo
193 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
