Question about Vehicle Parts & Accessories
How to unlock the doors when my passenger wants to go out while the engine is running
  • 101 Answers
Not much info to go on here ... but I have a GMC Envoy and it has computer setting I access from the steering wheel to lock doors when in drive or at speed and to unlock when in park or when shut off engine ... look at your operators manual if you have one ...hope this helps
Posted on Sep 30, 2009
Electric Door Locks not working to lock or unlock passenger door
Pull the door panel apart and check and see if the pun that locks and unlocks the door is connected, if so check the power supply the the actuator.
Apr 28, 2016 | Cars & Trucks
Passenger door locks don't unlock.
You need to understand how they work , do you know about automotive electronic controls ? Your switches are just inputs to the BCM - body control module !
Door Locks Power and Ground
For door lock operation, the IP Fuse Block supplies battery positive voltage, through the 15 amp DR LK/TRUNK fuse, to the BCM. The BCM uses this circuit exclusively to apply power to the door lock actuators. The BCM is also supplied a ground circuit, which it uses exclusively to ground the door lock actuators. When a door lock is pulsed, the BCM internally connects these two circuits to the appropriate lock and unlock control circuits to actuate the locking or unlocking functions.
When diagnosing door lock malfunctions, these circuits must not be confused with the other battery voltage and ground circuits of the BCM. The appropriate wiring schematic must be used to locate the correct circuits. Failure to identify the correct battery voltage and ground circuits of the BCM during diagnosis of door lock concerns may result in misdiagnosis and unneccessary parts replacement.
Passenger Door Unlock Operation
When the BCM detects a transition of either of the door lock switches to the Unlock position, it switches the door lock actuator unlock control circuits to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the passenger door lock actuators transition to the Unlock position.
The door lock actuator unlock control circuits are dedicated control circuits used only for the passenger door lock actuators. This is done so that the driver door may be unlocked individually before unlocking the passenger doors using a keyless entry transmitter or an automatic door unlock function, if programmed. When the keyless entry transmitter is used to unlock the passenger doors, the BCM requires a repeated unlock command before it performs the unlock function. However, when the unlock input is from a door lock switch, a single unlock command is all that is required to unlock all doors.
How to test computer controlled door locks
Sep 12, 2015 | 2006 Pontiac Grand Prix
Front passenger door does not stay locked while driving locks when I start, but does not stay locked. 2007 CRV
If the door locks properly, it is not the actuator. It's only function is to lock or unlock the door. Something is sending a signal for it to unlock. Just like if you try to lock it with the keys in the ignition, it automatically unlocks. Maybe read through the locking options in the owner's manual.
Dec 01, 2014 | 2007 Honda CR-V
Doors not opening even if they are unlocked
My 2009 Sebring does the same thing occasionally but only the drivers door gets stuck (dead locked - even though the locks appear to pop up).
The solution I have found once this happens is:
1) The car needs to be driven (crawl in thru the passenger door) -even just a short distance
2) Engine shut off & doors locked with remote (after you've exited from the passenger door of course)
3) Leave turned off for 10 minutes
4) Doors will now open when unlocked with the remote
Mar 14, 2014 | 2007 Chrysler Sebring Sedan
Door locks unlocks
Sounds like the main wiring loom into the door has been damaged.
Check near the hinges, where the door swings, to see if any damaged wires. Does the door lock and unlock from the drivers side switch?
Jan 04, 2014 | Toyota Cars & Trucks
All my remotes won't unlock passenger doors, why?
this is a problem that can appear after your car battery died, cause the car didn't reset propely, so taking the battery out and putting it back in or letting your car die again would do the trick. I tried a lot of reprogramming procedured for my remote key, none of them worked, what did the trick though was simply unlocking the doors via the all door unlock button on the passenger side door, so simple.
Apr 27, 2012 | Cars & Trucks
The lock button on the passenger door doesn't work when the ignition is at "on" position.. only works when it's on "off".. is this electrical problem? :(
some cars are fitted with autolock,car starts/car locks. some are fitted with driver masterlock button(above door switch panel)so the driver can lock all the doors/unlock for passengers to alight.but to stop you
locking the keys inside/you have them in your hand),car will not let you lock when in on position,keys in ignition/engine running etc.
so you do not have a problem.
Apr 28, 2010 | 1997 Audi A4
Unlock button on passenger door doesn't work. To lock, it does work but no to unlock.
It will only lock all doors, but should only unlock passenger door.
May 30, 2009 | 2008 Jeep Grand Cherokee
Several months ago I began experiencing a occasional problem with the anti-theft system of my 1992 Nissan Maxima SE 5 speed manual trans. Using my key I unlocked the drivers door and opened the door. The...
jimmy: it sounds like the drivers door unlock tamper switch or the other switch may have failed. One side can affect the other under certain circumstances. Your trunk lock also has a switch which arms and disarms the antitheft system. Try locking all the doors, make sure the hood and trunk lid are closed and then open the trunk. Leave it open open the drivers door and try to start the car.
If it's a no start. Disconnect the ground battery cable then put the ignition key in the run position in you ignition switch. Reconnect the battery and try to start the car. It should start. This usually will override the anti theft system. One issue with this will be, whether the antitheft system will remain disarmed.
Although I have never tried this before, I know that the system will not arm unless all the doors, trunk and the hood are closed.
I could suggest this to try if the car starts as I had told you pertaining to disconnecting the battery cable, I would take the switch and unbolt it from the passenger's side of the engine compartment just forward of the shock tower. Just let it sit somewhere so it doesn't get caught up in anything moving. If there is a light under the hood of your car, remove the bulb.
Let me know how you make out.
Mar 30, 2009 | 1992 Nissan Maxima
Vehicle Parts & Accessories Logo
37 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
