I don't know how to take the battery of; I don't see where the back comes off
  • luuuunatic
    luuuunatic May 11, 2010
    Brand and model?
  • 11,896 Answers
You will have to remove all screws and pull entire unit apart.
Posted on Sep 30, 2009
Need a new battery but don't know what battery to buy please help
come on just take it to any store that sells batteries and some time they will open it up and sell you and install a new battery or just ask while out shopping and you see a battery display. I have had a large dept store do it for me and did not by a battery. There is a local small jewelry store that run a $3 coupon that right a $3.00 coup they will open and remove old and install new also if all fail read instuction if you saved them and last some time on the back of thr watch it will have the battery #.
Mar 05, 2013 | Watches
I have an acer wireless mouse model mg-0766 and i cant get it to connect to my hp pavilion laptop. the batteries are fine. the dongle light doesnt come on but when i plug it in it does download the dr
Hi friend , make sure you have install the proper driver of it, if you don't have the driver or you don't know what is the exact driver, then my suggestion is you can install windows 7 operating system then i am sure it will work, or you can check it out by connecting a different computer where windows 7 is installed. make sure the usb port is working fine also.
Sep 25, 2012 | HP Computers & Internet
Changed o2 sensor engine light went off but came back on
I don't know if you have reset the computer but if not take one battery terminal off for about 5 minutes and that will reset your computer. If you don't have anymore problems it should not come back on.
Aug 20, 2012 | 2000 Ford Windstar
I have a 94 caprice lt1 5.7 I brought a brand new battery for it and when I turn it over it don't say nun at all no lights or nothing come on but da battery has juice
I dont know which model you have. My sons 94 caprice classic fully loaded he got used at an auction. Didnt know it at the time but it was one a cop car. Look on the front of engine under the crank case there should be something called an optispark on it. It has four wires coming out of either side and they run back to your plugs. Thats what was happening to my sons
Aug 04, 2012 | 1994 Chevrolet Caprice Classic
How do you reset computer codes on 2001 auror
The only way I know of is with a scanner. I have heard that you can take the battery cables off and leave them off for several minutes then turn the key on and off several times after you put them back on (I don't know if this works or not). If you don't fix the problem that caused it the check engine light will come right back on. Please rate my answer so I get points awarded for it.
Jan 26, 2012 | 2001 Oldsmobile Aurora
I was on the phone with my BB Torch, then the battery ran out, i got back the next morning, tried to put it on charge, nothing happen, no red light, no indicator , nothing, tried the charge for few ghours...
Good Day, Try this first and let me know what happens later. Use something like a needle to scratch the terminals of the battery and put your ****** to the terminals to make it a little wet. Then put the battery back inside the phone without connecting the charger to the phone. Then after the red light comes on, connect the charger. If the red light doesn't come on, connect the charger and put the battery inside. Please don't hesitate to let me know what happens later. Thanks for using Fixya!
Sep 09, 2011 | RIM BlackBerry Torch Cell Phone
The red lead wire on the back of the alternator has pulled away from somewhere and I need to know where it attaches to. This is on a 1997 Chevy Cavalier 2.4 engine. When I took the bolt off of the red lead...
That heavy gauge red wire (called a B+ wire) runs from the positive side of the battery directly to the back of the alternator. On yours, if it goes to the starter, the starter main battery terminal would essentially do the same thing. (both connections are always hot and always come directly from the battery). If you meant that it became disconnected when you said "pulled away", you need to find the wire it disconnected from and re-connect it. If it just came out of a loop that was securing it, you don't necessarily need to find the loop but can secure it with a tie wrap, making sure it stays away from the manifold.
You could actually make a new wire and connect it between the battery (+) terminal and the alternator, using the same gauge wire, but I'd be concerned that the loose end coming from the starter could possibly touch something and cause a direct short. At the least, you should find the loose end and cap it off. The battery cannot charge with the wire disconnected.
Anything I've just written that you don't understand, just ask and I'll clarify it for you.
Jun 22, 2011 | 1997 Chevrolet Cavalier
BATTERY FLAT AND ON CHARGING RADIO IS NOW OFF AND
your sentence makes so sense - please reword it
Dec 26, 2009 | 2004 Ford Focus
My notebook S96F bios don´t recognize my keyboard
remove the battery and power cord then open the system find the battery on the motherboard remove it carefully let it set out for 10 min. then put the battery back on the motherboard put the system back together replace battery and power cord cmos should be reset
Nov 26, 2008 | ASUS M5N Combo Notebook
98 celica battery went dead replaced now it want crank
Try this: Unhook the battery. Reconnect the battery. When the horn starts to beep, cycle the ignition key in the ignition on-off 5 times. This resets the alarm; the cycling of the key. Please advise me if this works for you.
Oct 07, 2008 | 1998 Toyota Celica
50 people viewed this question
 Grubhead
Grubhead
