Question about SoftMath Algebrator - Algebra Homework Solver (689076614429)
Help please george has one solution that is 40% water and a second solution that is 75% water. how much of each solution should he use to get 70ml of solution that is 50% water>
  • 700 Answers
Solution 1 = 50mL
Solution 2 = 20mL
Pls check if correct;
x = first solution
y = 2nd solution
.4x + .75y = .5(70) first equation
x+y = 70 2nd equation
x = 70 - y
subtitute x to 1st equation to get value of y, then subtitute value of y for x = 70 - y to get value of x.
There you go. Hope it is correct
Posted on Sep 30, 2009
  • 30 Answers
Volume 1 x .4 + Volume 2 x .75 = 70 mL x .5
Volume 2 = 70 - Volume 1
V1 x .4 + (70-V1) x .75 = 70 mL x .5
solve for V1
Ceiling mounted shower head (Danze) leaks water for a good 30-40 seconds long after being turned off
you really can not because of the overhead piping holds lots of water and so does this big head....that is just normal for these things...i am a licensed plumber for over 34 years and have done these...its just draining out all the overhead water....
Oct 06, 2012 | Danze Home
I have a Whirlpool Gold Conquest refrigerator model number GS6SHEXML00. It is working properly except when I open the fridge door, the light doesn't turn on. The freezer light turns on correctly. I...
George Andraws, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (George Andraws), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 17, 2017 | Whirlpool Gold White-on-White 21.9 cu. ft....
Where can I find a replacement upper plate release handle for the George Foreman grill model #GRP90WG? Plate is part number 22741.
george-foreman-parts.best-price.com Large range of George Foreman parts for all models: Get deep discounts! If this helped please rate me and let me know thanks and good luck
Jul 17, 2009 | George Foreman GGR50B Grill
George Foreman grill, model GRP4PBW Need both top and bottom right end handles
george-foreman-parts.best-price.com Large range of George Foreman parts for all models: Get deep discounts! If this helps please rate me and let me know..thanks
Jul 02, 2009 | George Foreman GGR50B Grill
Washing machines door open light is on, but door is shut
Found it for myself - F7=motor fault. New motor brushes fixed it. This error code will come up if the motor fails to turn on demand at any point in a program, be it filling, in a wash cycle, or spinning.
Hope That Helped;
Thanks For Using
FixYa.com
George
Please Rate Me
May 23, 2009 | Whirlpool AWM8163 Front Load Washer
Frigidaire front loading washer stopped at rinse cycle. 3 beeps
When in doubt check the easiest thing to check. The pump can cause a number of errors to come up. Since the unit stopped in rinse I would start but checking to make sure there is nothing obstructing the pump before going to the expensive parts.
Feb 22, 2009 | Frigidaire ATF6000ES Front Load Washer
Laptop problem
Hi George you may have the brightness turned down or The screen turned off Press FN Key and F4 if this dosent help
Try FN Key and F5 and do it slowly give it a second or 2 to happen Try looking pge 3.8 at special keys in your manual and try these
Hope this helps if it dosent try and restore your OS by pressing F9 when starting then see if the screen comes up if this doesent work you may have a screen Lighting inverter problem
let me know
Gary
Feb 16, 2009 | ASUS Eee 4G Notebook
Dehumidifer seems to run constantly
With that low of a setting it will most likely be kicking in alot more often. Most people run their dehumidifiers between 60-65%. It is a matter of preference. Also some basements hold out moisture more than others. There could be alot of variables affecting this. One thing you need to make sure is that you have the correct placement. Make sure you dont keep it near the sump pump or any other standing water because those areas have more humidity due to the water being there. Also make sure it is not in an area like a laundry room because when your washing machine despenses water it is despensing moisture into the air. I try to keep it at a central location if at all possible and away from areas that have water. If you found this solution helpful please rate it when you get a chance. Thanks - Tech101
Sep 06, 2006 | LG Goldstar LD65EL Dehumidifier
Computers & Internet Logo
207 people viewed this question
Top SoftMath Computers & Internet Experts
k24674
ali_zulfikar
ali_zulfikar
Starnley Johnwells
Starnley Johnwells
Are you a SoftMath Computer and Internet Expert? Answer questions, earn points and help others
