Kenmore 90 Series Washer has slow spin cycle
My kenmore 90 series 26912 washer model 110.26912691 has a slow spin cycle. It will spin properly when empty but any load causes it to stop. No bearing noise is heard. Please help.
  • 10 more comments
  • dogpurple Dec 19, 2007
    Please also reply direct to email felber@gmail.com
    More information on the above problem. Viewed underside when spin cycle NOT spinning, found coupler from motor to be in good shape and spinning. Is there a clutch assembly that could be bad?
  • dogpurple Dec 21, 2007
    Thanks for the help. I took everything apart. Clutch pads looked good. Spring held pads in the break position. When I took the transmission out I noticest that one mounting bolt had worked it's way loose. I figured that maybe the loose bolt had allowed the transmission to drop just enough to cause the problem. Put everything back together and tried a load. It worked!! Only time will tell but seems great now. Thanks for the great help!!!
  • dogpurple Dec 22, 2007
    Thank you. It was a simple fix, but I had the machine in many pieces all across the kitchen floor. Wish I had tightened it before disassembly. Thanks again for your help.
  • Ken90 Jan 22, 2008
    The spin cycle is intermittent on a 10 year old Kenmore 90 Series Washer with model number 110.26934691. I've already replaced the clutch, the timer and by pass the lid switch. The spin clycle is still intermittent. When the spin cycle does not work: It drains fine with the baket on low spin. Then the basket gets to a higher spin. The basket stops, the timer and motor continue through the spray cycle and the spin cycle, to off, leaving the laundry wet.
  • acarey May 15, 2008
    I have the Kenmore 90 Series 26912 and it fills correctly but makes a clicking noise and will not agitate or drain. Any suggestions would be appreciated. Thanks
  • danyschimpf Jul 21, 2008
    I just bought a used kenmore 90 series washer. I am having a slow spin cycle problem. The clothes are soaking wet at the end of the spin cycle.
    I don't really know how to use all te knobs. Is there a user manual online?
  • geoffndeb May 25, 2009
    My 90 series washer model 110.26912691 fills and then stops. There is a ticking sound which makes me think the timer is working ... not. But the knob turns until it gets to the spin cycle ... and it does spin. It also drains. It just won't agitate. It doesn't even try. I've already gone through the trouble of inspecting the coupler and even though it looks like it could use a new one it's clearly not the problem. My bets on the timer but I'm going to look around a bit more. Unfortunately this problem doesn't seem to be as common as the whole coupler thing.
  • Anonymous Mar 15, 2014
    bearing noise while slow spin
  • Anonymous Mar 22, 2014
    Will not stop filling
  • Anonymous Mar 27, 2014
    The spin cycle is too slow when a heavy load
  • Anonymous Apr 01, 2014
    Kenmore 800 series
Washing machine won't spin, seems locked up, when i turn the spin cycle on you can hear the machine trying to spin but it won't budge....... any suggestions???
Posted on Dec 28, 2007
    Sergeant:
    Champion:
  • 262 Answers
Yes the clutch is right above the trans mission you have to pull trany and there are pads you can replace them and take scotch brite to the lining try this first if pads look good spray some brake cleaner on the pads they may have grease on them
Posted on Dec 20, 2007
  • Bill Dozier Dec 22, 2007
    glad you got it fixed just be glad it was simple
Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
CHANGE THE LID SWITCH
Apr 18, 2009 | Washing Machines
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
You have a broken lid switch. Its # ll in the diagram. Part # is 3949238. Let me know if you need info on how to replace it, Dave www.washermd.com
Dec 17, 2008 | Kenmore 23822 Top Load Washer
Kenmore 90 series slow spin
You need a repairperson. It is probably a belt or a switch problem.
Jul 29, 2008 | Kenmore 22422 Top Load Washer
IT IS NOT A 23822. IT IS 26912, 90 SERIES
put a new couple in it its between the motor and the transmission
Mar 18, 2008 | Kenmore 23822 Top Load Washer
Intermittent spin cycle on Kenmore 90 Series washer
You may try the speed selection switch.....Ive had problems with these.
Jan 23, 2008 | Washing Machines
Yes the brakes are grabbing too hard....I will sometimes lubricate them....Or replace the basket drive assy. You do know how to take the cabinet off i take it??
Oct 02, 2007 | Washing Machines
Washing Machines Logo
3,290 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
