Question about Makita 6408K 3/8" Variable Speed, Reversible Drill with Case
Need to replace worn chuck on my makita 6480 drill, thanks
    President:
  • 1,564 Answers
If you back off the jaws(fully open) you should see a bolthead. Loosen this and the chuck should pop off with a few easy taps from a small hammer. If you dont see the bolthead, then all you have to do is turn the chuck to a fully open position and keep turning with force in the same direction and the chuck should unscrew. This type can be very difficult to remove. Exercise patience and it will come off. Thanks, Dana
Posted on Sep 30, 2009
Keyless chuck drill just spins
Some times the selector on top get gummed up with dust, it just needs cleaning. You were right to put it into 1st gear to remove the chuck with a big allen key, you get more resistance in the gears.
May 30, 2012 | Makita Drills
How can i replace the keyless chuck on my makita
I answered that question already on another post, but if you need to know how to remove the chuck I have detailed instructions in the TIP SECTION on how to do this. Let me know if you need more help
Dec 31, 2011 | Dewalt Makita Bhp452 18v Lxt Lithiumion...
Makita HP 1640 hammer drill chuck loosens grip on drill while drilling
Sounds like the chuck is worn, happens frequently when used often. Here's the link to Makita, their contact info should get you some answers as to what part number is needed as well as the closest location to you for service if required. Hope this helps.
http://www.makita.com/en-us/Modules/Tools/ToolDetails.aspx?ID=316372
Jan 14, 2011 | Makita HP1640 58Inch Hammer Drill
Damaged chuck
Grasp chuck, reverse it until fully open. Look inside where bit goes and should be an allen head or torque head screw holding chuck to motor arbor/shaft.
May 14, 2009 | Makita 5/8" 2 Spd Hammer Drill
Makita Percussion Drill HP2051F keyless chuck release problem
jacobs come out with this all metal keyless chuck(i think thats what you have) and if thats the case, there is no solution for this youll have to replace the hole chuck, being its new, it may be under warrenty
May 04, 2009 | Makita Drills
Stuck chuck
open the chuck all the way, insde there may be a screw in the bottom it's lefthand thread turn it clockwise to remove, the chuck is also threaded, right hand thread. close the jaws on the short end of an allen wrench and strike the long end with a hammer to break it free
Apr 01, 2009 | Makita Usa Inc No.8390DWPE 18V Crdls...
Makita 6408 drill motor. can't see how to replace the chuck.
If you have the 6408 as listed the spindle is threaded and you are correct there is no retaining screw. What you would need to do is find a bent handle allen wrench about the size of the chuck capacity 3/8" and insert the shorter end in the chuck and tighten. put the chuck on a block of wood or workbench and position the long end at about a 30 degree angle in the counter clockwise position and strike it with a hammer, this might take a couple hits. If this is not a 6408 let me know and I will look at the tool for you and see what you got.
Jan 23, 2009 | Makita 6408K 3/8" Variable Speed,...
Chuck removal
First open the chuck jaws and remove the LH chuck retaining screw. After that find a bent handle allen wrench about the size of the chuck. Put the shorter end in the chuck and clamp down on it. Put chuck on a block of wood or workbench with the long end at about a 30 degree angle so you can hit it counterclockwise with a hammer. It might take a couple hits but it will come off.
Jan 01, 2009 | Makita 6304LR 1/2" Chuck Electric Drills
Worn bearings at the chuck
no such parts in the chuck that you can replace.it comes in assy.
Apr 05, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita 6408K 3/8" Variable Speed, Reversible Drill with Case Logo
160 people viewed this question
Top Makita Drills Experts
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
