Question about KitchenAid Dishwashers
Does the two drawer use liquid or powder soap? Kitchen Aid Dishwasher is not washing things clean, there is a coating of dirty food particles on the dishes. Help!
  • 63 Answers
About the soap: You can use both. I prefer tablets.
About the particles: Before putting the dishes in, remove the food with a brush ($2.00) in the sink and run the hot water from the faucet for a 1-2 min until it gets really hot.
Posted on Sep 30, 2009
Dishes do not clean, although the water is hot and the soap dispenses. Dishes and glasses have a cloudy residue at times, and dishes sometimes have small food particles baked onto the surfaces.
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Feb 13, 2011 | Bosch Dishwashers
My dishwasher is a kitchen aid and is leaving all the dishes and glass ware with grime and dirty what to do?
Hi
Daniel
Jan 14, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Soap tablets are not disolving in the drawer?
Unlike a dishwasher the drawer on a washing machine is for soap powder or liquid. Tablets won't dissolve in the drawer you need to put them in the drum if at all.
Dec 13, 2010 | Washing Machines
The dishes do not seem to come out rinsed, especially the glasses. There seem to be small particles of food left on them and overall everything seems coated with a layer of gunk. I've made sure that the...
Hi
Daniel
Dec 10, 2010 | Bosch Dishwashers
Dirty cups and baby bottles after dishwasher has been run
Hi and welcome to FixYa I am Kelly. One of the biggest causes of the symptom you describe is that there is a partial blockage of the drain. The blockage areas are most often in the "Air Gap" A device that looks like an inverted 5 oz Dixie cup on the back of the sink with no cone shape. Food particles collect in the very top of that and slow down the drain process. Because of that the dishwasher doesn't completely drain between cycles. So what you get is recycled previous cycle water in the rinse.
Other places where blockages occur are at the garbage disposal side inlet hole. And the last place is under the wash arm tower / mini riser in the pump impeller outlet area. To clean under the lower wash arm riser it requires diassembly and a good memory of how everything came apart / goes back together when your done cleaning.
Apr 18, 2010 | Kenmore 24 in. 17032 Built-in Dishwasher
Top arm is not moving
Filter and rotor jets prob clogged.
In wash, the water is heated, supposed to dissolve the soap and then sucked thru a filter and pumped up the back and out the top to spray water everywhere.
Soap doesn't always fully dissolve and clogs the filter and some slimy gets thru and clogs the rotor jets.
To fix:
1. Remove Upper and lower dish drawers
2. Take off the Upper. Middle and lotwe rotors and clean their jets out with toothpick and frequent flushing (Plug a clean hole with toothpick to make water come out elsewhere) Use the sink on full blast to see if water comes out all holes.
3. Reassemble rotors.
4. Remove and clean filter. The filter is in the bottom above the Motor/pump and held in with 8 shiny hex-head or Torx screws. Take out all screws, lift out filter and clean in sink with warm or hot water from backside. Use garden hose for hard to reach areas.
5. Reinstall filter. Don't overtighten or you will crack it
6. Replace drawers
Done!
Mar 26, 2009 | Dishwashers
Food particles are on dishes after washing
Try adding bicarb of soda/baking soda and vinegar in the detergent dispenser. Bicarb fizzes off hardened particles and vinegar strips off grease and aids rinsing.
Jan 26, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
Dirty dishes
On the bottom pull the wash arm straight up and out. It shouldn't be clipped because they held in by gravity. Under there is where you will find extra crud that gets lodged underneath the arm where you can't see it. Do you fill the rinse agent reservoir? Also try using liquid tabs or gel if you are using powder. Hope it helped!
Jan 12, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher not cleaning dishes. Casade cleaner not disolved.???
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
Diswasher not rinsing properly
You may have a clogged wash pump, resulting in low water pressure. This may not be enough to drive both spray arms at the same time. This can also be causing the problem with your detergents not being distributed properly. An easy way to tell if you have good water pressure is to open the door slightly while its in mid cycle. Look for a good strong spraying action from both spray arms. If you're not getting enough water, and you've already checked your supply hose coming in, then suspect you might have an obstruction somewhere. Most cleaning problems can be attributed to something as simple as food particles stuck in the vicinity of the wash pump inlet. You will have to remove the lower spray arm and coarse screen to get to it, however. Rule of thumb: If you still have to chew it, then it shouldn't go through the dishwasher. Scrape your plates of food particles, yes. But, don't put things like meat scraps, popcorn kernels, chicken bones, orange or lemon seeds, beans (the skins can clog the drain screen), etc. This does not mean you have to pre-wash BEFORE you wash. Most dishwasher detergents require the oils in foods to help activate the cleaning agents. One more thing: City water - stick with liquids or gels. Well water - stick with powders. Now, if all else fails ad you've checked the inlet to the pump and it's clear, you may have a bad drive motor and pump. Go with the cheaper solution, first. I hope this helps you. Let me know if I can help you any further.
Jun 06, 2007 | Kenmore 24 in. 15199 / 15194 / 15192...
Dishwashers Logo
170 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
