Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
I am trying to install a v belt ground drive on my craftman lawn tractor it is a DLT 2000 48" cut with a 20 hp Kohler Pro engine.I cannot get it over the electric clutch pulley what anm I doin wrong
  • David Lopez Aug 15, 2013
    theres a pully that you can actually move forward or backward to give you enough room to put the belt on
  • 472 Answers
YOU WILL NEED TO DROP THE STACK PULEY DOWN AND MAKE SURE THE PARK BREAK IS SET THAT MAKES THE BELT LOOSE
Posted on Sep 30, 2009
Need to know how to change transmission fluid on cub cadet lt 1045 riding mower
Cub Cadet has five models in their new Series 1000 lawn tractors, all powered by Kohler engines. Cub Cadet models -- as several other lawn equipment brands -- are manufactured by MTD Products.
The Cub Cadet LT 1045 has a 20-hp Kohler single-cylinder engine, with an aluminum block and cast-iron sleeve for longer life. It has a full-pressure lubrication system with spin-on oil filter for easier maintenance. This engine is not as powerful or as long lasting as the Kohler V-Twin OHV, which is available in other models in the line, but the LT 1045's engine is still solid enough to provide years of mowing.
The hydrostatic (automatic) transmission is a good match with the engine and provides sufficient grip to cut grass on moderate inclines. Power is transferred from the engine to the transmission by a heavy-duty Kevlar belt rather than a more expensive shaft drive. A Kevlar belt also drives the three cutting blades.
The mowing deck cuts a swath of grass 46 inches wide at one pass, and is removable for service and cleaning. Four anti-scalping wheels help keep the deck from scalping grass on uneven ground. The cutting height is manually adjusted from 1-1/2 to 4 inches. The turning radius is 18 inches, which standard for lawn tractors. This model is intended for use on 1- to 2-acre lawns without many turns or small obstacles.
Jul 28, 2012 | Cub Cadet Garden
I have a craftsman Dlt 3000 riding mower with a 20hp kohler v twin . engine starts and runs for 5 seconds and shuts off
no model # on my DLT3000. Replaced rear fender a few years ago where the model # used to be. I can't get the right parts w/o model #. It was by my dad sometime between '04 and '07. It's red w/42" cut, 20hp koler pro motor.
Sep 18, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
My craftmans 46 in cut (22 hp) tractor goes backward after I changed drive belt
If you notice how the belt leaves the motor pully and goes to the transmission, it makes a 1/2 twist? Well reverse that twist and the tractor will go in the correct direction.
Jul 03, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Belt diagram craftsman 917 2733100
Assuming your model number is 917.273100, go to ... http://www.searspartsdirect.com/partsdirect/index.action Enter the model number, hit search then scroll down to Ground Drive
Jul 27, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Belt diagram for craftman tractor lt1000 drive belt that is!HELP
Go to... http://www.searspartsdirect.com/partsdirect/index.action Then enter the model number that is under seat. Should start with 917. Then scroll down to Ground Drive and there's your diagram.
Jun 29, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Belt Diagram needed on Craftsman Kohler Command 20 Hp RidingMower
Go to... http://www.searspartsdirect.com/partsdirect/index.action Enter your model #, click enter, then scroll down to the sudcomponent list and click on 'Mower Deck' if it's your blade belt you need to see or 'Ground Drive' for your transmission belt. Hope that helps. Dwain
May 15, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
542 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
