Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
ELECTRONICS PART hi where i can buy pcb assy and the sub circuit for my RCA d52w20? THANKS
    Genius:
  • 1,030 Answers
WWW.UED.NET
Posted on Dec 19, 2007
How to reset e001
An error E001 should have a detail code with it.
Detail Code 0001:
Cause
The fixing temperature has increased abnormally
  • The main thermistor (TH1) has a short circuit.
  • The fixing heater drive circuit has a fault.
  • The DC controller PCB has a fault
  • The image processor PCB has a fault.
Description
The output of the main thermistor has exceeded 220 C.
Detail Code 0002:
Cause
The sub thermistor has detected overheating.
Description
The output of the sub thermistor has exceeded 235 C.
Detail Code 0003:
Cause
The sub thermistor has an open circuit
  • The sub thermistor has an open circuit.
  • The SSR has a fault.
  • The DC controller PCB has a fault.
Description
I would suggest calling the copier repair personal.
Feb 21, 2014 | Canon imageRUNNER 400S Copier
Hi - We have an error code on a Canon Model 2800 : E000001-0002 Any ideas on how to fix the problem? Thanks! Paul
E001
0000 The main thermistor detects 250°C or higher.
0001 The main thermistor or the sub thermistor detects overheating (hardware
circuit detection).
0002 The sub thermistor detects about 295°C or higher.
Main cause The fixing film unit is faulty (i.e., the thermistor has a short circuit). The
main power supply PCB is faulty. The DC controller PCB is faulty.
Caution To clear the error, execute the following in service move:
COPIER>FUNCTION>CLEAR>ERR.
Action
1. Fixing film unit
Check the interval between pin 1 and pin 2 and between pin 3 and pin 4 of
the connectors (4-pin) of the thermistor for electrical continuity. Is it 0 ?
(short circuit)?
YES: The thermistor has a short circuit. Replace the fixing film unit.
REF.
If the thermistor has a short circuit, the indication in service mode
(COPIER>DISPLAY>ANALOG) will be as follows from the start: FIXC=250°C
for the main thermistor; FIX-E=310°C for the sub thermistor.
2. Main power supply PCB, DC controller PCB
Try replacing the main power supply PCB. Is the problem corrected?
YES: End.
NO: Replace the DC controller PCB.
BUT FIRST: under service mode *28* copier, function, clear , err turn off and on maybe it will work.If it works check that you have good air flow around the copier.
Apr 19, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Car AMP from subs making noise and only from AMP
There may be a cracked solder joint on the main PCB.
also - check the wiring.
There should be no noise if the radio is off.
When it's on - remove the RCA cables... and see if the noise persists.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 11, 2009 | Hifonics XX-Zeus Car Audio Amplifier
I Have a D52W20 that will not turn on. The cycle
It seems that you are having an issue with your ballast. This is one one the common symptoms they have when they're becoming faulty.
Oct 30, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Model 52" hd RCA tv Will not go on.hit power button green light keeps flashing.will not stop
These units are famous for bad capacitors in the power supply. When the capacitors go it causes voltages to fluctuate out of range. You have to remove the deflection PCB to repair this. Also look for loose connections at the high voltage transformer. This can be a dangerous circuit to work on. Have a repair shop check it out for you. Thanks
Oct 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
D52W20 Circuit Diagram
what cuircit are you searching for power defelection, sub power, convegence power convegence amp, crt boards, signal board
Oct 23, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20
That board is called a Green Kine Drive pcb. The part number is 266860.
Oct 18, 2008 | RCA HD52W58 52" TV
RCA D52W20
0cc3c24.jpg CPi50 is on the right CP114 is one the left and the flyback is at the lower left hand side black transformer
Sep 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV turns OFF and ON
No it is not. There is no fransfer of memory for the power module, but there is for the control module (main pcb). RCA also has a problem with 2 connectors that go bad. One on the power pcb and the other on the convergence output pcb. They are white in color. The good ones are black in color. Look for the 2 ribbon cables that connect from the main pcb to the power pcb and see what color the connectors are.
Apr 23, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture Color
http://www.partstore.com/ModelDetai...close=1&exact=1
What do you think "CRT ASSY, Projection: Blue" might be?
CRT ASSY, PROJECTION: BLUE
RCA Part Number: 258486
RCA Model: D52W20
52" CRT BLUE P16LTG00BMB, DELTA 250
They want $183,
Jan 08, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
23 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
