Question about Yamaha HTR-6130 Receiver
There are no instructions on which ports to use for a mixer and a computer. Can't route any instruments through receiver/amp for recording purposes
    Scholar:
  • 89 Answers
A Home Audio Receiver is not meant to amp instruments. There are ways to do so using the record line in but you take a large risk of blowing the amp. May I ask what exactly you are trying to do so I can better assist you?
Posted on Oct 01, 2009
Can't hear playback through Headphone socket, only through speaker monitors!
i suggest you contact Behringer Customer Service for advixce. Without the setup in front of me, it's hard to figure out the wire routeing, switch positions, ect. that may be leading to this problem. As they would be the people most familiar with the gear, they'sd be the people to ask. http://www.music-group.com/support/behringer/askquestion
Oct 28, 2016 | Behringer Music
How do i connect my keyboard and my laptop?
Download USB MIDI driver for yamaha from yamaha website,and install to laptop.
Next:
Make sure the POWER switch on the instrument is set to OFF,then use an AB type USB cable to connect the instrument to the laptop.
After making the connections, turn on the power of the instrument.
Laptop will immediately notify that new hardwares is connecting and automatically install the drivers. Wait until the process is finish.
Thats all. In Ableton,the setting MIDI input must be set to USB MIDI.
Aug 19, 2015 | Yamaha PSRE413 Keyboard
No sound
This is not a powered mixer and so you must connect a power amp to the "line level" outputs of the mixer. Other "no output" problems could be related to buss assignments and other signal routing issues. Check for output by connecting "Main Out" left or right to a guitar amp input instead BUT turn all volumes down to zero before conductiong this test as guitar amps are designed for "Microphone" level inputs. Owners and Hookup manuals can be found here...
http://www.mackie.com/products/1604vlz3/
Sep 09, 2012 | Mackie 1604 Vlz3 16 Channel Mixer
Firewire inputs do not work
Check in the computer "Device manager" if a PC with windows, and see if there are any devices with an yellow "X" through them- the port may have an interrupt conflict.
Then check audio properties of the system to make sure the devices are selected and enabled, and their volume level is up- even if you are operating through the Mackie software console.
If a Mac- check the Chooser to make sure that input device has been selected.
Mar 30, 2012 | Mackie Onyx 1620i Recording Mixer
Can't route effects to two channels of my mixer. If I plug into input 1 of my power amp, I have effects. If i plug into input 2 of my power amp, I get no effects. I tried both Crown and QSC power amps. ...
The power amp is the final stage - the last output from the mixer goes to the power amps.
Its a routing problem - some mixers only allow certain routing and this could be affecting your FX routes.
All the FX - internal or outboard come before power.
Check the manual Check the aux send and returns Check if you need need stereo plugs for the send and return of FX.
Get back if still stuck.
Feb 26, 2011 | Lexicon MX400XL Dual Stereo/Surround...
How do I attach power amp to 1832 mixer
There are a number of configurations for a mixer like the 1832, the most common are PA system and Recording system. There are Main output jacks which carry the mix as summed in the main faders. These in a PA system would feed the pa amplifiers which drive the house speaker system for the audience. These connectors are XLR 3 pin type on the rear, intended for professional pa amplifiers which use balanced +4dbv line input level. Amplifier which have 3 pin XLR connectors for input signals can accept that high level signal. For home style HiFi amplifiers, the signal level is nominally -10DBv and balanced or unbalanced signal lines with 1/4in diameter phone plugs which are connected to the mixer by way of a second set of Main output connectors which are 1/4in phone jacks. Use whichever amplifier input level your amp has.
If you are not using it as a main PA house mixer, but using it for recording, the main output connectors go to a 2 channel recorder or computer sound card recorder. The power amp and your monitor speakers are connected to the connectors labeled "Control Room" (CTRL Rm). These output are useful for recording because the signal through the mixer can be monitored from several buses, Solo, main mix, selected by buttons provided. The buttons only affect the signal heard through the control room monitors, and not the main output which only sees the main mix so selecting "solo" does not interrupt the signal going to the recorder while the engineer in the control can be checking other signal paths through the board.
Jan 21, 2011 | Behringer Xenyx 1832fx Mixer 18 Input 32...
Can't send instruments (live or recordings) to the tape output.. (does not see signal in Cubasis)
Anything you hear in the mains SHOULD come out the "tape out" jacks UNLESS you have the "tape to mains" button pressed in. (That is for driving the mains from tape or CD) Remember these are line level signals.
Not sure about Cybasis? Is that Cubase software? If this is through a USB port, Cubase, if that is what you have, has to be set up to receive the signals onto tracks. There are a lot of things to NOT get set right with this program... Always use a set of headphones to verify that signals are coming through the mixer.
Apr 26, 2010 | Behringer Xenyx 1832fx Mixer 18 Input 32...
Iam trying to make my behringerXENYX 1204fx mixer, / connect
I have trouble my new behringer xenyx 1204FX VU led dead , like new VU it must play , how to repair this unit VU light
Mar 13, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Home stereo audio problems
Could be a bad patch cord, a setting on the mixer, a faulty mixer (unless it works ok with other amps), or a dirty control on the Sony amp if it has analog controls. Have you tried connecting other sources to the Sony?
Sep 27, 2008 | Audio Players & Recorders
Yamaha HTR-6130 Receiver Logo
44 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
