Question about Cameras
The camara no work
The camara lens does not go back in and it can''t take a picture or do anthing else because it turns blue or it just turns off
Gryfox
  • 216 Answers
SOURCE: lens problem
If you've replaced the batteries with fresh ones, it probably has a broken zoom assembly. It'll have to be replaced by a repair shop.
Posted on Dec 14, 2006
SOURCE: problem with lens
My camera turns on and the screen remains black. All settings show up on the display screen, but you cannot see anything but black. I can snap a picture and it takes a picture of solid black. I have exhausted the battery and fully recharged. I have formated the memory card and tried to restore all original settings to default. I have no idea what else to do. Can you help?
Posted on Sep 30, 2008
shockwave727
  • 262 Answers
SOURCE: Camara shuts off as soon as it turns on. Lens
I believed that you are using the battery came from the box the KLIC-7004 which is very good. Now since the battery indicates its charge, first thing you need to do is to removed the battery and Memory card, Now wipe the 3 metal contacts of your battery then reinsert only the battery in your camera then Turn It On. If the camera shuts off try to used 5V AC adaptor to Turn On the camera, If this failed to turn On using the AC adaptor It means the camera needs of service call Kodak Tech support toll free 1 800 421 6699 ext 12
Posted on Nov 09, 2009
  • 54 Answers
SOURCE: My digital camara no longer wants to work. The
The lens may have malfunctioned. It could be jammed, one of the plastic moving parts is broken, or the motor has malfunctioned.
You can try to open the r742 camera and swap out the lens with working set from another non-functioning r742 camera.
Posted on Nov 24, 2009
  • 411 Answers
SOURCE: Camara lens won't go back in
lena unit is bad,diassemble the lens unit,replace the broken/deformed parts,service all the parts,assemble to operate the camera.
Posted on Apr 09, 2010
Phillips Magnavox 9P6040 C104 tv color adjustment help
If you turn color off and stand back and examine the screen---if it is not black and white but yellow looking you have bad Glycol in the blue picture tube which is quite common.
Easy way to know for sure is with set on and rear cover removed peek with a small mirror at the three lens---don't touch anything with the set on===each tube red,blue, green should have a picture with the set on.
Likely you will find the blue one looks like a floodlight with little or NO image/picture.
May 18, 2012 | Hitachi Televison & Video
Oct 19, 2009 | HP Photosmart R742 7.0 Megapixel Digital...
THE LENS COMES OUT BUT GOES RIGHT BACK IN AND
I had the same problem. All I did was hold the lens out when it tun so that when it shuts off, the lens is still out. Then I moved it around a bit. Something was stuck in the lens and when I moved the lens around, it came out. So now it functions normally :] I hope I helped!
Jul 07, 2009 | Kodak EASYSHARE M1063 Digital Camera
TURN ON AND OFF
there is something in ur camara under the cage broken, very small pice, open it & take it out & close it again & it will work.
Dec 27, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
CAMERA LENS STUCK OUT
chech and make sure that your lens isnt bent to the side, because i had the same problem and as soon as i bent my lens back it turned on and worked like new
Aug 26, 2008 | Samsung S630 Digital Camera
The camara won't show a picture on the lcd screen
Your lens is Damage. Prevent nextime from sunlight , it damage your lens if not in use.
Dec 24, 2007 | Canon PowerShot A75 Digital Camera
My new digital camara
Your lens is jammed. The only way to fix that is to send it into casio.
Nov 06, 2007 | Casio Exilim EX-S600 Digital Camera
Error-C1
Dirt /dust in the lens and lens gear box ( this drives zooming only ) preventing optimum functioning. Lens cannot properly come on line ( shutter and diaphragh mechanism then do not come on line ) and the camera switches off. Solution : is ether replace lens unit or dismantle lens to clean out ( from gear box and the helicoil of the lens ).
Sep 03, 2007 | Kyocera Finecam S4 Digital Camera
Lens problem
Dec 13, 2006 | Canon PowerShot A520 Digital Camera
Cameras Logo
26 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
