Question about Ruud UBHC Air Conditioner
I have the same Ruud Achiever unit & it's not working.
The Furnace seem to start okay but fan does not turn on. I don't see any flame when it turns on. Where exactly is the ignitor located? What else could I check? ---Thx.
  • 34 Answers
There is a proofing safety switch that will not allow flame if the fan doesnt purge any gas from the unit first fan must come on for set amount of time first check that fan is good
Posted on Oct 10, 2009
  • 129 Answers
It sounds like it will need a hot surface igniter. This is the part that glows when furnace is turned on, and tells gas valve to release gas for it to ignite. At that point funace is lit, it heats up flame sensor witch inturn tells fan to start.
Posted on Sep 30, 2009
My ruud achiever 90 plus furnace wont run. thermostat shows system on, seems ok but furnace itself wont run. system has power.I can hear the power come on when I depress the access panel switch and also...
See if you can locate the control board. There should be an automotive push in fuse on it. It should be a small amp fuse around 3-5 amps. Check it and change if needed. You should be able to see if it is blown or not just by looking if you don't have access to a multi-meter.
The control board is usually located in the blower compartment. Thank you.
Jul 10, 2011 | Ruud Heating & Cooling
Ruud 90 Plus Achiever furnace starts, ignites, runs for 30 seconds, goes out, then does it again and again.
It would seem as though you have a bad flame sensor or the ground from the burner to the ignition control is bad...
Could be the ignition control also but not nearly as likely...
Pressure switch can also cause these problems...
Bottom line is that you will need to grab a meter and try to figure out what is causing the flame to cutout...
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Jan 14, 2011 | Heating & Cooling
I have a ruud 90 plus achiever gas horizontal furnace. the unit will run once i turn the thermostat off then on. it will cycle a few times go off and then will not come on. any suggestions?
Sounds like it could be a dirty or bad flame sensor.
When the burner lights ,there is a flame sensor in the flame and it is suppose to sense the flame and send a signal back to the control board which will keep the gas valve open, if it gets dirty or is bad it doesn't send the signal back to the board and the board will shut the gas valve off and after three tries it will lock out the furnace and you have to reset it to get it to work again.
The flame sensor looks like a wire and it's in the flame usually it will get gas deposits on it, then it won't work.
You can clean this sensor with an extra fine piece of steel wool, but before you attempt to do this DISCONNECT ALL POWER TO THE FURNACE.
Jan 04, 2010 | Ruud UBHC Air Conditioner
LP Ruud furnace achiever 90+. Strange problem.
Sounds like two problems. Not enough combustion air or a defective high temperature limit switch. You enclosure may not be getting enough outside air to properly sustain combustion. If the unit has a rollout thermostat it may be defective and stopping everything.
Oct 10, 2009 | Heating & Cooling
My Ruud Achiever 90 Plus not blowing cooled air
Look on the condensor, (outdoor unit) at the very bottom of the rear panel and you should find a red reset button. push it. If that does not solve the problem, and the outdoor unit is running (make sure both the fan AND the compressor are running) then you are looking at a low refridgerant issue and possibly dirty coils.
In that case, clean the coils and have refridgerant added.
Sep 23, 2009 | Ruud UBHC Air Conditioner
Ruud heater will not light consistently
Your furnace is going into a lockout condition, cycling the power resets the circuit board and it starts over. I will need to know approximate age and model of your furnace, it sounds like you have need to clean the flame sensor rod. However i need to know what i am working with.
Dec 18, 2008 | Ruud UBHC Air Conditioner
Ruud achiever 90 plus blower not working
does the furnace ignite?? your system may not have been lighting and has gone into ignition lockout count the codes of the led lights then remove panel led diagnostic codes are listed there.
if led codes indicate no problem verify capacitor is good and that mtr is getting 115 volts.
Sep 15, 2008 | Ruud UBHC Air Conditioner
Ruud achiever 10 seer air conditioner
It sounds like your condenser fan motor may be locked up or the capacitor that helps give the condenser fan motor a kick to get it started may be defective. Try turning your system on and using a long screwdriver try to push the fan blade on the condenser fan motor to see if it will run normally if you give it the starting boost it needs.If it does run at full speed and doesn't over heat or start and then slow down then you probably only need to replace a simple 10-12$ capacitor. If it barely turns, makes an odd humming sound or overheats etc. then you will have to replace the condenser fan motor. This is assuming that the outdoor condenser has the 220v supplied and the 24v supplied to the compressor relay, that the compressor relay is engaged and suppling 220v to the condenser fan motor.
May 28, 2008 | Ruud Matching Split Air Conditioner
Ruud achiever 90 plus gas furnace
The door, you mean the metal cover on the front? if you have the door off and push the safety switch in with your hand everything works fine? I need more info here, but if what I said is right, then the "door" isn't making good contact with the switch.
Mar 05, 2008 | Ruud UBHC Air Conditioner
Ruud UBHC Air Conditioner Logo
182 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
