Question about General Electric GE SmartWater Household Water Filtration System - GNWH38F
Where is the schematic for Ge water dispenser model GXCF20E , water dispenser is not cooling
Honeywell ct87n wiring schematic
These are color codes wires for terminals that control fan relay,start,stop, temp-up/down ect. Also you can trace out those wires, Where they are going and what terminal on the wiring schematic they control.
Jun 27, 2014 | Honeywell Ct87n "the Round" Heat/cool...
Ice maker not working just changed the filter water works but ice maker not working
Check the plastic lever on the door. It usually moves closed when the door is shut to turn ice maker on. The lever can freeze and stop the ice maker.
Sep 23, 2013 | Whirlpool Gold GI6FARXXF 25.5 cu. ft....
Sunbeam hot/cold water dispenser is leaking from looks like copper tubing that goes to tank. Model # ylr-5-87h3 what could my problem be
Broken solder connection.
Continual expansion and contraction of metal due to hot and cold extremes will cause metal fatigue. The most vulnerable place is at the join. Other places can fail, but usually the solder join will fail first.
Buy another one and support economy.
Make sure next unit is connected to cold water line, and not hot water line. If hot water dispenser is connected to Hot line, then it will cause water heater to run each time water is drawn through dispenser because cold water immediately enters tank.
http://waterheatertimer.org/Water-heater-dip-tube.html
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html#h-c
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html#pot
You might also consider installing small tank under counter. Tanks are less glamorous than hot water dispensers but tanks are more reliable long term than instantaneous water heaters.
May 28, 2013 | Water Heaters
Insinkerator hot tap faq
Check all the connections, take the cover off after you shut down the power. If the connectors are not leaking, replace it
May 04, 2013 | In-Sink-Erator InSinkErator HC-WAVESN-SS...
GE Water Cooler Cold Water does not come out, Why?
It works like a fridge or ac. When its charge gets low it can't cool. It will cycle on and off as freon goes around the circuit. Must be leaking around seals or crack in line. A good ac man could check its pressure to determine. Also, thermostat could be going bad, I would check that as well.
Feb 17, 2013 | GE Profile PXCF22RBS Hot and Cold Water...
Keep getting a f9 and f10 code . how do we fix what do they mean
1) F9 and F10 appear to be element failure/ Call for service
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html#error
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html#element
2) Copy following link for more GE Hybrid Geospring resources:
http://waterheatertimer.org/GE-heat-pump-manuals-by-date.html
3) Call GE and they will tell you to call for service:
1-888-443-4394
4) 2009 service manual says you can clear fault codes by pressing Filter, Lock, Vacation button sequentially within 3 seconds. Scroll to clear all fault codes using arrow keys. When that is highlighted, press Filter, Lock, Vacation again.
Others report this does not work, so it may depend on model. Or maybe buttons need to be pressed simultaneously.
5) GE does not want folks working on their own water heater.
Do not buy expensive water heaters you cannot fix yourself.
Average service call for GE heat pump is $400 which helps defeat anticipated savings from buying hybrid.
Jan 26, 2013 | General Electric GE GeoSpring Hybrid Water...
What is recovery on a GE 40 gal gas water heater model PG40S9b
GE is made by rheem-so it should be around 38-41 gal per hour-should be on nameplate by gas valve
Jan 26, 2011 | General Electric GE SmartWater Household...
General Electric GE SmartWater Household Water Filtration System - GNWH38F Logo
469 people viewed this question
Top General Electric Water Heaters Experts
paulcarew
Donni Steen
Are you a General Electric Water Heater Expert? Answer questions, earn points and help others
