Question about GE 30 in. Profile JP350 Electric Cooktop
One of my large burner not working - GE 30 in. Profile JP350 Electric Cooktop
  • 13 Answers
If you have the glass cooktop slide-in model, the problem is most likely the burner "ribbon' under the glass top for the small burner has come loose. I fixed mine with only a phillips-head screwdriver, needle-nosed pliers, and a 1/4" wrench (1/4" socket on the end of a nutdriver works better). Here are the steps I took to fix it: 1) Slide the oven out from the counter so the sides of the oven are clear of the counter top. 2) Remove the phillips head screws-1 on each side of the oven near the top/rear. These will be the only phillips-head screws you will need to remove. 3) Open the oven door and remove the 4 hex-head screws at the top/front/inside the oven- there are 2 on each side which follow the opening of the door. Then close the door. 4) Pull off the burner knobs by gripping them and pulling straight up. Don't worry, you will not break them but you will need to give them a good tug. 5) Remove the burner retaining nuts that are under the knobs-you may need a wrench to loosen them but only tighten them by hand when reinstalling. 6) Pull the face of the control panel away from the oven slowly until you see a ribbon connector on the right side and then disconnect the ribbon and remove the face plate from the oven. 7) Remove the 4 hex-head screws from the face plate bracket (the plastic part that was holding the face plate) and pull the bracket toward the front of the oven until it flops over and rests on the oven door handle. 8) remove the 2 black screws holding down the glass top-one on each side of the oven-the screw heads face the front of the oven. 9) Disconnect the two wiring harnesses attached to the cook top. Don't worry, they only fit one way so you don't need to label them. 10) Lift the cook top until the wiring harnesses are clear of the holes and place it upside down on a flat surrface. 11) Remove the two retaining bracket screws and brackets from each side of the non-working burner. 12) Slowly lift the burner and flip it upwards until you see the ribbon coils. It should not be necessary to disconnect any wires. 13) Look at the ribbon coils very carefully to see if any of them are disconnected from their main connection points. If so, feed the ribbon back inside the pinch point (you may need a small screwdriver to open the pinch point first) and then use a pair of needle-nosed pliers to pinch the ribbon to hold it in place. I had to use a voltage meter set in the OHM position to find where mine were disconnected. Once you pinch the ribbon end back into place, put everything back together in reverse order. If your burner still does not work, your burner knob switch may be bad. I hope this helps. Good Luck!
Posted on Jul 24, 2010
My large burner at the front does not work, yet when i replace it with\r\nthe large burner at the back it does not work , yet when you put the front burner at the back it works.
Your front burner is fine. Assuming you have an electric cooktop the problem is in the switch that controls that burner. The infinite control switch. Replace it.
Dec 07, 2010 | Jenn-Air Cooktops
Large electric burner will not turn on
you need to check the wiring to that burner it appears that there has been a short to the burner
Apr 04, 2010 | Jenn-Air 35 in. JEC9536ADS Electric...
My dual size burner only goes large no matter the
You will have to have the potentiometer switch replaced that controls the burner.
Aug 30, 2009 | Jenn-Air Cooktops
Burner is on high all the time
Is this an older unit - 5 years or more in use? Sounds like the burner element is shot. Check the Amana web site for a replacement.
Bill B.
San Antonio
May 12, 2009 | Amana Cooktops
Viking professional induction cooktop large burners defective
Throw your circuit breaker that leads to this unit for a few seconds, then reset the breaker This unit is very sensitive to power fluctuations.
Mar 07, 2009 | Viking 37 in. VECU165 Electric Cooktop
When the large burner is on, it keeps trying to ignite
Check that the burner orifice nozzle (the round thing that comes off) is properly seated on the burner manifold. Mine have a tab that must interlock.
Make sure all your burner orifices are CLEAN. Scrub them with a plastic kitchen scrubber, soap and water.
The way this works is, when a burner is turned on, the sensing mechanism for the spark control reads the ionization of the flame. No flame, no ionization, keep sparking so gas buildup is minimal in the area before a flame is ignited. )Kinda like the spark thingy's underneath the shuttle, without the ionization sensor's, just before it launches.).
Jan 14, 2009 | Dacor 36 in. EG366SCHLP Gas Cooktop
My electric stove top burner only works on high
This is for the glass top units. well i'm not sure if your problem is with your large or small single burner or the large expandable burner. If it's the large or small single burner replace the burner and if it the expandable also replace the burner. If you have a coil burner replace the infinite switch. Good luck hope this helps you.
Jan 09, 2009 | Jenn-Air JED8430 Electric Cooktop
Old Thermador cooktop continues to spark even after turned off
sounds like you have a bad switch. maybe on the large burner.. some of those switches can be replaced without the whole harness.
Dec 22, 2008 | Thermador PSC364GDZS Gas Cooktop
Electric cooktop burner malfunction
The outer ring of the element is most likely broken. You'll need to replace the element.
Apr 06, 2008 | Cooktops
GE 30 in. Profile JP350 Electric Cooktop Logo
489 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
