Question about Toshiba CZ36T31 36" TV
Bottom and top part of screen black
Only the middle part of the screen is viewable, if you let the T.V. warm up hitting it on the side clears the problem up.
I will purchase a new unit when my money situations improves..
  • 700 Answers
Follow John's advice.
Posted on Sep 30, 2009
  • fougzki Sep 30, 2009
    But commonly vertical IC is in a single line package. See the board marking usually sections are labeled. Look for vertical section then look for an IC within the mark section.
  • 647 Answers
This is an easy repair if you've ever soldered and would not be too costly for a repair shop to do it for you. The problem is a bad Vertical Output IC (usually mounted on an aluminum heat sink with the part on it labeled LA78?? ) and 1 or 2 bad capacitors. Some times you can even fix the problem by re-soldering the contacts of the IC- To find the IC follow the 4 wires that come from the Yoke (which is a contained coil of wires slipped over the neck of the picture tube(s)) back to the board. 2 of the wires go to the horizontal o/p and 2 to the Vertical o/p the thinner gauge wires are for the vertical.
My screen went black
If the bottom is black it's the lower buffer board and I believe that's the Y buffer board. Should have on ebay fairly inexpensive
Aug 11, 2014 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Samsung TSL2793HF - Slight Right Side Pincushion and Horz Line Bottom to Top Until the TV Warms up
Yes, this is rare but I have seen it before--not fixable if it is what I think it is----It is what is called a Dome effect---the shadow mask in the picture tube is actually contracting and or expanding depending on temperature---
Directly behind the phosphor coating (the stripes that you see on the screen) is a metal screen--the holes or perforations in it line up with the stripes on the phosphor screen.
Some masks either have a material or a defect causing the dome effect----Not likely to be anything else---a Pin amp problem will not usually act the way you describe but a shadow mask inside the picture tube will act exactly that way.
Dec 02, 2012 | Televison & Video
Big black square in middle of screen picture top to bottom about 36 " wide good audio and picture 6" on right and left side displaying.
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 26, 2012 | Hitachi 55HDS69 55 in. Plasma Television
Screen seems to have a black line down the middle left side of screen is non viewable
It happens when samsung g600 a get ribben slider problem. it needs to be change
Jan 07, 2010 | Samsung SGH-G600 Cellular Phone
The screen is blurry on the top, bottom and sides, but the middle is somewhat clear. how can i fix it? thank you for your time!
open the monitor a black EHT will found see the preset set it by screw driver on line see result on the screen the name on preset is FOCUS
Nov 13, 2009 | IBM E74 Monitor
52" Samsung that the top half of screen goes black.
the HDTV has a heat-related problem check your fans. Do they remove heat? the vertical chips paint the screen from top to middle and, middle to bottom so; your top to middle vertical chip is overheating as is your video chip; that is why you have "glitter" in the back ground. get rid of the heat or, bye,bye TV.
May 20, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Toshiba CZ36T31 36" TV Logo
166 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
